JDP Motorsports
Old 04-01-2010, 06:58 AM   #1
RBC2010SSRS
RBC2010SSRS's Avatar
Drives: 2010 SS RS 6spd. 402 rwhp
DIABLO Predator tune, CAT delete??? is there a variable adjustment for this?
I read all the tunning posts I could find. From what I understand Getting the LTFT's around 0 to -2 is the idea for the fuel mixture.
I selected all the variables to watch on Real time read or whatever, was reading around -6 and -7 for the two FTFT readings on the first few runs. I adjusted the injector slope 7% up and ran the test three more time's and had the readings averaging -1 and lower on both.
What else is there to tune besides the fuel mixture?
Got the Shift skip eliminated (THANK GOD).
My Cats are cut out so what adjustment should i make there?? I read something about extra fuel to cool the O2 sensors and cats, sooo could i go lean??
LS3 dreamin
RBC2010SSRS is offline   Reply With Quote
Old 04-01-2010, 08:08 AM   #2
aj2ssrs
Drives: IOM 2SS/RS
With no cats you are going to throw a check engine light. Unfortunately there are no user adjustable parameters to compensate for no cats, you would need a custom tune for that. Also, I was told that adjusting your injector slope is not the proper way to tune the car. I originally played around with the ltft's with my Trinity but reset everything when I was told it wasn't the right thing to do. Jannetty Racing installed a set of lt headers and dyno tuned my car using Diablo's tuning software. I can now revert back to the stock tune if need be and than re-install my custom tune afterwards. If I were you I would call Ted at Janetty Racing and let him set you up with an e-mail tune. You won't have to chase your ltft's because the way you're doing it now, they will change with different weather conditions.
aj2ssrs is offline   Reply With Quote
Cats or Cat delete??? ratlover Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 03-14-2010 03:42 PM
stock cat back w/ muffler delete for sale 2010SSRS V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 02-11-2010 07:09 PM
Cat delete vs high-flow cat? triq033 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 02-03-2010 04:26 PM
Muffler Delete Cat Back For Sale - $125 PU only! Legend V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 15 12-25-2009 09:20 PM
