Old 04-01-2010, 09:35 AM   #1
recontango
recontango's Avatar
Drives: Synergy Green
Tire Pressure Monitoring Trouble
I have read many threads on here related, but none seem to contain the exact answer for what to do when your car at start up says Service Tire Pressure Monitoring System with the big wrench. When this happens, it wont allow you to do a reset to get back into learn mode and just dashes are shown by each tire. I have nitrogen in my tires, so it isnt easy for me to let pressure out and add back at home. Is there another way to reset the system by pulling a fuse or will the dealership have to take care of this? Sorry for starting another thread about this, but couldn't find what I was looking for.
recontango is offline   Reply With Quote
Old 04-01-2010, 09:51 AM   #2
ron10
Drives: 2010 2SS IOM L99
i think your dealer will have to deal with that problem.
my problem,is the sensors give me bogus pressure.i put 36lb.in tires and sensors read out 33 to 35lbs.i just don't worry about it.
Old 04-01-2010, 10:06 AM   #3
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
I changed out from my winter tires to summer tires this weekend. I had to do the reset, and I found it was far easier to let the air out of each tire than to try and pump them up.
Also on my 2LT, when the car goes into learning mode, the turn signal for the tire it wants to learn will be illuminated. For example the drivers front amber turn signal next to the headlight is first lit up, followed by the passenger front.
I set the pressure in my tires according to the sensors as the gauge on my compressor was a bit off.
skuttduck is offline   Reply With Quote
Old 04-01-2010, 10:24 AM   #4
venice17517
venice17517's Avatar
Drives: 2010 Camaro
The dealer has a tool to do the reset and is only takes 5 min.
venice17517 is offline   Reply With Quote
Old 04-02-2010, 01:06 AM   #5
autopat
autopat's Avatar
Drives: 2010 IOM 2SS
Discount can do it too
So many projects... so little time.
2010 2SS, IOM, IOI, CGM stripes, L99
1999 Astro van, LS
1995 Saturn SC2
1994 Saturn SC1
1992 Saturn SL2
1991 Daihatsu HiJet
1981 C10 Beater, with a heater, er..A/C
1973 Nova SS, 385 stroker, TH400, FOR SALE! (soon)
1966 Suburban, LS bound! Still in a million pieces
1965 C-10, Short, Wide, Big window, all roller 355
autopat is offline   Reply With Quote
Old 04-02-2010, 01:18 AM   #6
FANTA-Z
FANTA-Z's Avatar
Drives: 2010 SSRS
I had the same problem with mine and I did the reset with letting the air out of the tires and it worked perfectly. I had all the dashes as your stating as well. Just go into the menu and select the reset. The horn will honk twice and then you start with the driver front. Let the air out and after about 10 seconds you will hear the horn honk. Move to the Passenger front and do the same. When you hear the honk go to the passenger rear........hear the honk and go to the driver rear and after that honk you will get two more honks and this lets you know that all are done. Then you can go back and air the tires back up to where they need to be.
Glenn
2010 Camaro 2SSRS Inferno Orange Metallic
FANTA-Z is offline   Reply With Quote
Old 04-02-2010, 10:15 AM   #7
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Another thing to note, the passenger brake must be applied in order to do the reset steps. Always start at the front driver's tire and work your way around the car clockwise.
Fquick.com/NineBall
Old 04-02-2010, 05:45 PM   #8
JProberts
Drives: 2SS RJT RS/Sunroof
Another question?
When switching tires from stock rims to aftermarket rims should the TPMS always be transferable to the new rims?
Is there ever a case where you need to order new TPMS becasue of adding new rims? My thought was you should be able to use the TPMS from the original wheel as long as the person changing the tires from the old rims to the new rims don't screw them up. I am correct here?
Can the experts here educate me please.
Thought I would pay the price and have the dealer swap the rims for me in case anything went wrong with the TPMS I could hold them responsible and not the rim provider.
Sorry if this was asked already and I missed it.
Thanks
JProberts is offline   Reply With Quote
Old 04-02-2010, 06:13 PM   #9
Nine Ball
Nine Ball's Avatar
You cannot reuse the rubber stems on the factory TPMS sensors. Those get chewed up if you try to remove them, likely to cause a slow leak on the next set. Most tire shops sell replacement rubber stems. They attach to the sensor with a screw, very simple. Your sensors themselves usually have a life of 8-10 years.
Fquick.com/NineBall
Old 04-02-2010, 06:31 PM   #10
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is online now   Reply With Quote
Old 04-02-2010, 06:53 PM   #11
Nine Ball
Nine Ball's Avatar
Oops, I meant parking brake. It is on the passenger side, LOL
My car won't show the reset option unless the parking brake is pulled up.
Fquick.com/NineBall
Old 04-02-2010, 06:55 PM   #12
JProberts
So the sensors themselves aren't an issue, just the rubber valve stems which don't cost much anyway.
Thanks
Old 04-02-2010, 07:02 PM   #13
RickRay
INJACC
RickRay's Avatar
Thanks..I'll have to try the Hand Brake next time...
I just press the reset button and it beeps twice ...then I wait a few minutes and it resets to 32 lbs ( My tires are actually at 32 and will bring them up to 36 next week) Question they way I do it is it at 32 cause I didn't do it tire by tire and it goes to the default reading? Also what is the tire pressure for the 18" & 19" tires..20" is 36>>.
Old 04-03-2010, 04:44 PM   #14
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
Thanks
Right, I pulled mine off last week, after I took out the screw they popped right off. Like stated its the valve stem that you have to replace because you have to cut the bulb to remove them (atleast if youre doing it the correct way). They were $8 for me at the dealer ship. Putting them back in on Tuesday when I pick up my rims from the powder coater.
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Colorado members check in here 2010 SS RS USA - Rockies / Midwest 8831 01-04-2018 08:56 AM
correct tire pressure? captains1 Wheels and Tires Talk Sponsored by The Tire Rack 9 03-10-2014 05:03 PM
Correct tire pressure Heelhook22 Wheels and Tires Talk Sponsored by The Tire Rack 34 12-21-2009 05:07 PM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 04:34 PM
Tire Pressure Monitoring Dentyneice Wheels and Tires Talk Sponsored by The Tire Rack 8 08-14-2009 07:42 AM
