Old 10-01-2008, 10:02 PM   #1
Tom_K
Tom_K's Avatar
Drives: 1968 Camaro SS
Smile LS3 gasoline
Will the LS3 and L99 run on regular unleaded or is it mandatory that it use premium?
Tom_K is offline   Reply With Quote
Old 10-01-2008, 10:03 PM   #2
EllwynX
EllwynX's Avatar
Drives: 2010 Camaro SS
Everything has said Premium is 'Recommended', not mandatory.
It will work fine on Regular, but with a slight loss of mpg and power from what I've been told.
EllwynX is offline   Reply With Quote
Old 10-01-2008, 10:05 PM   #3
o2camaross
o2camaross's Avatar
Drives: 2010 2SS/RS & 04 silvy
with such a high compression ratio, i wouldnt even think about running anything less than premium. just my $0.02
o2camaross is offline   Reply With Quote
Old 10-01-2008, 10:27 PM   #4
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
or your $0.60 (because of gas prices)
Old 10-02-2008, 02:49 AM   #5
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
my gas prices are 3.55 for premium right now so i cant complain
but it has a knock sensor to tell when the fuel is lower octane so it knows to retard the timing so it wont damage the engine. so you can run any fuel you want in it (minus diesel unless your feeling lucky)
headpunter is offline   Reply With Quote
Old 10-02-2008, 03:09 AM   #6
fbird777
SOM WS6
fbird777's Avatar
Drives: 2002 SOM Trans Am WS6
Your lucky, our regular is $3.69. I will be putting 93 octane in my Camaro for sure.
fbird777 is offline   Reply With Quote
Old 10-02-2008, 03:17 AM   #7
_GTO_
_GTO_'s Avatar
Drives: holden commodore
The HSV (Holden Special Vehicles) Use the LS3 engine in there new E Series and they recommende the 98 ron(octane) fuel .
Here what they said ''The use of 98 RON fuel is also now recommended over 95 RON. Thus the actual power increase is likely to be less than 10 kW'' (10 kw = 13.4 hp ) .
But i think they gonna make somthing to reduce the octan for the LS3 in the US .
_GTO_ is offline   Reply With Quote
Old 10-02-2008, 11:03 AM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
premium is recommended. That means it is a recommendation. You could try running midgrade as a compromise
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-02-2008, 11:06 AM   #9
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
premium or tune for E85
Old 10-02-2008, 12:23 PM   #10
headpunter
headpunter's Avatar
Drives: Man
dont run e85 in it without getting a rebuild to change the seals. e85 will eat your gaskets and seals in the car causing major problems
Old 10-02-2008, 12:32 PM   #11
MCPOAJ
Drives: LS2 FD RX7
please... don't put that sludge in you new camaro... think about it if you camaro was going to buy you would you wanna be fueled with piss or moutain dew??
MCPOAJ is offline   Reply With Quote
Old 10-02-2008, 12:50 PM   #12
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
I would love to convert my SS to E85 if I could get equal or better performance numbers. That would be fun at the track because some people are convinced that performance cars just can't run on ethanol.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 10-02-2008, 01:07 PM   #13
dvnt88
Kickin' Assphalt
dvnt88's Avatar
Drives: 1997 Z-28 30th Anniversary Ed.
Ditto, better to pay a few bucks extra at the pump then get hit with a damaged engine down the road. Not saying that it will happen, but the engine was designed to run on higher octane to ge the best performance out of it and why is it that everyone is soooo concerned about a few extra bucks at the pump? The car is gonna MSRP between 30K-35K (guesstimation) and is the price you pay for the car you decide to drive.
Just my .02c, but come on, it's a friggin hot rod, not a Yugo. ")
"KICKIN' ASSPHALT"
dvnt88 is offline   Reply With Quote
Old 10-02-2008, 01:40 PM   #14
camaro1
camaro1's Avatar
e85 is one of the best fuels to come out.
you need to do some reading on e-85 and not just listen to internet myths,, converted my equinox to e85 a few months ago and running great at $2.60 a gal.
i also had my v8 s-10 running on e-85 for a while and no problems, and it is over 105 octane for $2.60 a gal,, cant beat that
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 10:21 AM
LS376/480 EFI LS3 Gen IV V-8 NOODLESgoneWILD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-04-2008 09:14 AM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
Trees in Your Tank? The Future of Green Gasoline: Earth Day Extra Scotsman General Automotive + Other Cars Discussion 7 04-23-2008 08:43 PM
