Old 04-01-2010, 08:21 PM   #1
B.Buster
B.Buster's Avatar
Drives: 2010 AquaBlue 2SS/RS
Tire pressure monitor CEL after tire change
Just changed my front tires and rims. Set my tire pressure at 36#s all the way around. Started car and all pressure read between 35 and 37 which has been normal. Drove car about 25 miles and info screen says to have tire monitor system serviced. Tried relearn 5 times and it didn't work. Have a helms manual but it says use the dealer scan tool. Is there another way to fix? Thanks in advance
B.Buster is offline   Reply With Quote
Old 04-01-2010, 08:40 PM   #2
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
After you told it to relearn, did you lower the tire pressure in each wheel starting on the front drivers side until the horn beeped?
Sterling is offline   Reply With Quote
Old 04-01-2010, 08:42 PM   #3
ron10
Drives: 2010 2SS IOM L99
if you have to take it to the dealer,it is a 5 minute fix.
Old 04-01-2010, 08:59 PM   #4
B.Buster
B.Buster's Avatar
Did not try this. Will try this tonight . After front left which next (total order please).
Old 04-01-2010, 09:03 PM   #5
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Front left, front right, rear right, rear left.
On my 2LT the turn signal is illuminated for each tire it is expecting to learn.
skuttduck is offline   Reply With Quote
Old 04-01-2010, 09:08 PM   #6
B.Buster
B.Buster's Avatar
Just found order in my Helms . Just got the service manual yesterday and haven't had time to go though it . Thanks
Old 04-01-2010, 09:45 PM   #7
B.Buster
B.Buster's Avatar
Worked like a charm . Set all to 36#s. Light is off and info center is clear. Pressures still read between 35 & 37. All set at 36# with a race tire gauge that reads to tenth #.
Tire Pressure Monitoring Trouble recontango Wheels and Tires Talk Sponsored by The Tire Rack 16 12-04-2011 09:15 AM
Anybody pulling their hair out to due wheel or tire change with your braking sensors! noom1108 Wheels and Tires Talk Sponsored by The Tire Rack 10 09-26-2009 09:21 PM
Tire Pressure Monitoring Dentyneice Wheels and Tires Talk Sponsored by The Tire Rack 8 08-14-2009 07:42 AM
Tire Pressure Monitoring System-Inside or external monitors? Fogey 5th Gen Camaro SS LS LT General Discussions 11 05-19-2009 11:50 AM
I think i'm done waiting. pinkcamaro10 Off-topic Discussions 332 05-13-2009 05:56 PM
