JDP Motorsports
Old 04-01-2010, 09:00 PM   #1
cbrniner
cbrniner's Avatar
Drives: 2010 2SS/RS - Rally Yellow
Need Help !!! Magnaflow Exhaust
Okay I installed an Axle Back Comp Exhaust on the camaro , started up while still on the Jack stands to hear it and water dripping out of 2 of the joints ....What do I need to do ....Please help
Ive tightened up pretty good ...so what did I do wrong ???
cbrniner is offline   Reply With Quote
Old 04-01-2010, 09:17 PM   #2
strobi
MJ STROH
Drives: 2010 Camaro 2LTRS
try the U clamps instead....they usually seal tighter, and you can crank them down more..and make sure your pipe is inside the joint by at least a half inch.....If I remmber correctly...there are some slots in one of the pipes..make sure they are well up into the other pipe and put the clamps forward of those slots
Sometimes it takes a little time for them to seal, run it for a while and see if it dissapears, if not, take it down to the muffler shop and have it welded
strobi is offline   Reply With Quote
Old 04-01-2010, 09:24 PM   #3
cbrniner
cbrniner's Avatar
I didnt get the U Clamps ....ill run it tonight for a bit see if cooling and heating takes care of it , if not off to the muffler shop and have it welded
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 559 02-15-2018 03:00 PM
Custom Magnaflow Exhaust buddylok Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 49 05-16-2016 12:02 PM
RATING HEADERS??? SAUCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 12-02-2011 09:21 PM
Magnaflow Direct-Fit Highflow Converters for the SS (LS3 and L99)! JDP Motorsports Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-24-2010 05:03 PM
Exhaust - New 3 Inch Magnaflow Cat-Back Available GFT V8 Bolt-Ons & Tunes 8 07-02-2009 08:12 PM
