HURST
Old 04-02-2010, 02:05 PM   #1
bryant_man
Drives: 2010 Camaro 2SS
Skip shift problem?
Ok I installed skip shift eliminator from SLP today. Installation was as easy as it gets but for some reason it wont let me shift into reverse while its installed. Anybody had the same issue?
bryant_man is offline   Reply With Quote
Old 04-02-2010, 02:21 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
You have it in the wrong plug. Should be on the Driver's side towards the top of the trans.
http://www.camaro5.com/forums/showth...ght=skip+shift
Build Journal
Old 04-02-2010, 02:24 PM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Old 04-02-2010, 03:21 PM   #4
SS Matt
SS Matt's Avatar
Drives: 2010 2SS/RS, LS3, M6, CGM
Yep, wrong plug!
SS Matt is offline   Reply With Quote
Old 04-03-2010, 12:00 AM   #5
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Turn the directions over, there is a nice black and white picture of what plug you need to plug the skip-shift into. You most likely plugged yours into the reverse lockout plug...
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 02:45 PM
SLP Skip Shift Eliminator Sajonf Transmission / Driveline 2 11-15-2009 11:19 AM
Skip Shift on V6? Beemer Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 1 09-18-2009 03:22 PM
SLP Skip Shift Eliminators Available @ MarylandSpeed! MarylandSpeed V8 Bolt-Ons & Tunes 0 09-18-2009 02:50 AM
Avoid skip shift in the break-in? Vash Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 7 05-27-2009 11:39 AM
