sjm autoprod
Old 04-02-2010, 09:42 PM   #1
Inferno2SSRS
Jim
Inferno2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS Orange
Send a message via AIM to Inferno2SSRS
Corsa L99 Install Problem
I just installed the Corsa 14952 for the L99 engine, and did everything as instructed and it sounds great at idle. But when I shift the car into drive or reverse there is a sound coming from the center of the car of metal hitting metal. I assume its the Tunnel Brace and the XO pipe hitting, but wanted to see if anyone else has had this issue and what is the best way to the correct it. Thanks any input would be appreciated.
ARH 1 7/8 with Cats, Corsa Cat-back, Roto Fab CAI, and Jannetty Tune, L99
Inferno2SSRS is offline   Reply With Quote
Old 04-02-2010, 10:54 PM   #2
FSTORG5
Fast Orange
FSTORG5's Avatar
Drives: 2012 ZL1
It is a little difficult to get the resonators up high enough. Especially just using jack stands. Mine dropped a little after a few miles and rubbed a little. I took it to a local muffler shop and on the rack they were able to get it in the right position. Took them 5 min. and they didn't charge me anything.
I was assuming that you didn't forget the spacers to drop the cross brace and give you a little more clearance?
FSTORG5 is offline   Reply With Quote
Old 04-02-2010, 11:01 PM   #3
Inferno2SSRS
Jim
I got the spacers in place, I figured it had to do something with the clearance thanks
Old 04-02-2010, 11:26 PM   #4
Scrappy Doo
Scrappy Doo's Avatar
Drives: Taylor Made M1
I added a couple washers to mine, no more rattle.
Or you can change tunnel braces if you want.
Scrappy Doo is offline   Reply With Quote
Old 04-03-2010, 01:38 AM   #5
Inferno2SSRS
Jim
I think I'll try the washers first and see how that works, I don't want to buy a new tunnel brace for 200 dollars the reason I installed it myself was to save the money on the install. Thanks for the input guys.
Old 04-03-2010, 02:02 AM   #6
Drigar
SYSADM
Drigar's Avatar
Drives: 2010 Camaro SS/RS,CGM,A6
I had to add 3 washers to each side as well.
Drigar is offline   Reply With Quote
Old 04-03-2010, 02:22 AM   #7
Inferno2SSRS
Jim
Thanks again, I thought I had something wrong with my system.
Old 04-03-2010, 12:34 PM   #8
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
So, is it fixed? If so, what fixed it? The washers?
Old 04-03-2010, 12:52 PM   #9
Rich1
Rich1's Avatar
Drives: 2010 Camaro 2SS/RS Victory Red
I did not need the extra washers on mine.
Rich1 is offline   Reply With Quote
Old 04-03-2010, 02:14 PM   #10
Inferno2SSRS
Jim
I'm going to install the washers in a few hours, ill post the results after.
Old 04-03-2010, 06:48 PM   #11
Inferno2SSRS
Jim
It worked, so far so good. Thanks for the advice.
Old 04-05-2010, 11:51 PM   #12
Inferno2SSRS
Jim
So after taking it out for a long drive the banging sound came back. I called up Corsa Tech Support today, and told them about the problem. They told me to loosen the bolts from the beginning of the catback and before the tunnel brace, than stick a 2 inch thick piece of wood under the xo pipe between the pipe and the tunnel brace. Than he said to pull the exhaust outwards a little more about a 1/8 of a inch it came out. Next I used a lift to push the xo pipe up a little more and hold it in place. Than I tightened everything back, and it was good to go.
Corsa said this is a very common problem, I'm a little surprised they haven't suggested this in the directions. But I just wanted to share the info for people doing their own installs in the future. This system rocks!!!! And highly recommend it, I can't wait to do LT's.
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 69 08-19-2017 11:09 PM
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 02:25 PM
Corsa L99 14952 Inferno2SSRS V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 8 07-20-2010 06:31 PM
Maggie install (automatic L99) Easy racer778 Forced Induction - V8 27 04-26-2010 06:04 PM
Corsa LS3 on a L99 with AFM tuned out? duffmobile Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 03-09-2010 01:52 PM
