Old 04-02-2010, 10:03 PM   #1
BSPOT
Drives: 2010 Camaro 2SS
Strange Dyno Graph
after getting the car dyno'd the noticed the x axis on the read out was "time" and not engine speed or rpm's. the range goes from 0 to 19.3 seconds (im guessing seconds anyway). does anyone know why they did it like this and what the significant is, if any, of the time?
BSPOT is offline   Reply With Quote
Old 04-03-2010, 12:47 AM   #2
barrylnv
barrylnv's Avatar
Drives: 2010 2SS IMB LS3/M6
Sounds like your tuner / dyno shop didn't change the X-axis into RPM or wheel speed. All dynos will measure the time of the dyno but obviously it is meaningless. Most tuners save every dyno pull so I'd go back to them and ask for your plot with something meaningful on the X-axis and if you plan to post it here for consistency sake please have them plot with SAE correction and smoothing of 3. That'll allow you to compare to most on here though more and more post the pretty uncorrected (gotta love low temps in the winter) or STD corrections, various or no smoothings, and even shifts in the plots making huge spikes. But anyway, your dyno shop should be able to give you a better plot no prob.
2010 2SS LS3/M6 Imperial Blue
650HP LPE Package - 576.3 RWHP, 91-tune
4.10 Richmond Gears
ZR1 Clutch / LPE Flywheel
LPE IBM Coil Covers
Thorley Shorty Headers
Borla 140280 Cat-back
ADM Boost Gauge
MTI Shifter
Hotchkis Sway Bars
LPE Floor Mats
SRP Heel-Toe Pedals
barrylnv is offline   Reply With Quote
Old 04-03-2010, 09:41 AM   #3
BSPOT
very cool man thanks
Old 04-03-2010, 10:26 AM   #4
BSPOT
Here is a copy of the dyno readout. Opinions?
Old 04-03-2010, 11:41 AM   #5
barrylnv
barrylnv's Avatar
Yeah, they just need to give you a different X-axis variable, either RPM (preferred) or wheel speed and from that you can calculate RPM. Since they plotted HP and TQ on same scale the point at which the lines cross is 5252 rpm since HP = TQ*RPM/5252. Overall your numbers are very strong but I don't see a correction factor listed and at your location on that date it is going to be less than 1.0 (I think, I'd have to calculate to be sure) which means your SAE numbers would be a bit less than shown.
4.10 Richmond Gears
LPE IBM Coil Covers
ADM Boost Gauge
MTI Shifter
Hotchkis Sway Bars
LPE Floor Mats
SRP Heel-Toe Pedals
Old 04-03-2010, 11:57 AM   #6
kelley@vectormotorsports
Drives: 2009 Pontiac G8 GT
I have done this by accident also. There are three buttons for the x-axis, RPM, MPH & Time. The graph looks the same so it is easy to miss.
Your graph is still saved and can be printed with the correct x-axis.
kelley@vectormotorsports is offline   Reply With Quote
Roto-fab CAI dyno results Roto-fab 1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 102 07-30-2016 07:21 PM
Official JBA Shorty Dyno Graph JBAGREG V8 Bolt-Ons & Tunes 49 02-08-2010 10:03 AM
TSP Induction Pics & Dyno Graph Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 01-15-2010 03:22 PM
Dyno graph and video's of stock/tuned vs. headers gomer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 12-20-2009 05:09 PM
LS3 Tune Only Results .. Also stock LS3 vs. L99 dyno graph LPFSTheFett Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-05-2009 07:04 AM
