Rick@Livernois
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 04-04-2010, 02:05 PM   #1
ittybittyfds
ittybittyfds's Avatar
Drives: 2013 Victory Red ZL1 M6 #495
just picked up 67 camaro need some engine help
just baught a 67 camaro. Engine block is a 1983 350 block. dont know if its a 2bolt or 4 bolt. in 83 there were both. Heads are 327 double humps/camel humps, Straight Plug version.
its got a Crane/Cam dynamics street plus Cam
valve adjust int .022, valve adjust exh .024
valve lift int .493, exh .512
tappet lift of .050
ground lobe 112 degrees
Edelbrock Torker intake
Holley 670 street avenger carb
Hedman Headers.
HEI distributor.
3:73 rear
Compression unknown
Valves unknown
rockers unknown.
I went to tune it up yesturday and removed the plugs.
According to Autolite the plugs i am supposed to use are PN# 85
14mm thread, 9.5mm reach.
Plugs I removed were PN#36 and dicontinued. replaced with 46
18mm thread, 11.6mm reach. Also the 46 series plugs were for Ford Applications
Any gear heads out there have any idea why these plugs would of been used?
also want know know if there is a valid reason why the PCV vacuum shouldnt be connected from the head to the carburators PCV vacuum port?
2013 Victory Red ZL1 M6, Roto-Fab CAI,
ittybittyfds is offline   Reply With Quote
Old 04-04-2010, 02:30 PM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
You need plugs to match the cylinder heads. I don't know for certain which head casting you are running but if they are truly double hump early style heads (291's for example) the 85's should be good. A head casting number would help nail it down.
-Mark.
Old 04-04-2010, 02:56 PM   #3
ittybittyfds
head casting number is located on the surface under the valve cover...right????
Old 04-04-2010, 03:56 PM   #4
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Yes it is.
-Mark.
Old 04-04-2010, 04:03 PM   #5
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Sounds like whoever built the motor did a reasonable job of matching the components. Match the plugs to the heads and compression ratio. Normally aspirated SBCs are very forgiving with plugs.
As far as the PCV, it has two purposes: across the board it will lower the positive pressure of ring blowby in the crankcase and under higher vacuum conditions it helps the rings seal better.
The BEST Break for a new car. "very long" Darin Morgan General Automotive + Other Cars Discussion 346 02-04-2010 07:49 PM
4 SEMA CAMAROS finally unveiled by GM! (hi-res images & details) FenwickHockey65 Camaro Photos | Spyshots | Video | Media Gallery 237 11-03-2008 11:39 PM
