Old 04-04-2010, 06:38 PM   #1
Merlinnnn
Drives: 2011 Mustang GT
Anything wrong going with 2" headers?
Just curious - I know I don't need them now but who knows what the future holds. If anyone who has 2" headers could chime in and tell me if they have felt any loss of torque, clearance issues, etc. it would be appreciated.
Merlinnnn is offline   Reply With Quote
Old 04-04-2010, 06:57 PM   #2
blackedout010
Drives: on order black 2010 2ss
if it were me power loss or not!! if theres even the slimest of chance you may ever a some cubes to your motor then id say yea go ahead and get em... i learned the hard way years ago on my 02 ss i went through 3 sets of headers and if ida bought the big boys to begin with ida saved around $2500..
blackedout010 is offline   Reply With Quote
Old 04-04-2010, 06:58 PM   #3
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
ARH 2 inch did the best in Ted Jenetty header test. Not by a landslide but they did make the most power. Very little more money than the 1 7/8 and the 1 3/4. Worth it in my opinion. Easy install especially on a lift. I had mine coated as well to keep the new look in the engine compartment. Good Luck
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 04-04-2010, 07:09 PM   #4
Tmedlin
Drives: 2006 z71 tahoe
overkill unless you plan on getting a cam and a blower later on. 1 7/8 LTs are plenty sufficient for 600-650rwhp easy
Tmedlin is offline   Reply With Quote
Old 04-04-2010, 08:42 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
As long as the price difference between the 1 7/8 and 2in is nothing, go for the bigger ones. At least for the ARH's, the 2in showed a near identical powerband as the 1 7/8 and had a few more peak HP and Tq. The choice is yours. Either set will do you well.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 04-05-2010, 12:50 AM   #6
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
The real question is, what one sounds better =D
SleepWarz is offline   Reply With Quote
Old 04-05-2010, 01:39 AM   #7
wbt
Drives: 2010 Challenger R/T;2011 Mustang GT
Ted's results with the ARH headers:
1.75 long tube headers w high flow cats Peak 401.1 HP 403.8 TQ
1.75 long tube headers w high flow cats Average 281.2 HP 363.9 TQ
1.875 long tube headers w high flow cats Peak 406.8 HP 407.5 TQ
1.875 long tube headers w high flow cats Average 283.7 HP 366.6 TQ
2.0 long tube headers w high flow cats Peak 411.7 HP 408.9 TQ
2.0 long tube headers w high flow cats Average 288.1 HP 368.1 TQ
wbt is offline   Reply With Quote
Old 04-05-2010, 02:04 AM   #8
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I have the 2" Stainless Works LT's and I'm completely happy with them.
I too, wondered if going with the larger diameter was going to make me lose some power. I even asked Stainless about it. They didn't have an answer saying they hadn't had the opportunity to test out the different sizes on the same car. They said the difference would likely be minimal. Well, as you can see with the tests, the gains are minimal.
I love my long tubes. At first, I thought I lost some of the low end. Then, after breaking in the engine (as anyone out there will say), it got better and better.
The best part about the 2" headers? You won' have to get anything different once you decide to finally supercharge later down the road!!! yes, I plan to...but haven't a clue when that would happen....
Old 04-05-2010, 02:32 AM   #9
chappy48
chappy48's Avatar
Drives: 2010 Camaro Auto 2SS/RS
People here sight Ted's test to say 2" are the best, but he actually recommended the 1 7/8" headers for most people. 1 7/8 headers are better down low, and match 2" headers for just about all of the power band for less $. Unless you're planning on building a track car and spend all your time at peak hp, you'll be perfectly fine getting the 1 7/8 headers. Really, you can't go wrong with either size, but if you don't plan on racing the car a lot and spending most of your time around 5000 rpm, why spend more money on the 2" headers?
Built by Jannetty Racing
670rwhp/649rwtq...Scariness to be determined.
Jannety Racing forged 416.
TVS2300 Supercharger w/Maggie Max Stage 2, 3.6 Pulley, Innovators West 8 rib conversion, OD rear Cog belt drive.
Jannetty Racing Rough Idle Cam, LS3 Conversion.
Jannetty Racing built 6l80e Trans, Jannetty Racing Custom Converter, Built rear diff w/ 3.45 gears, DSS driveshaft and 1400 hp axles.
ADM Twin Pump Fuel System, ADM CAI, Dynatech 1 7/8" Coated Headers, Borla "S" Catback.
Custom 18" Forgestar F14's, Nitto 305/45-18 DR's
chappy48 is offline   Reply With Quote
Old 04-05-2010, 08:47 AM   #10
Levi_Engle
Drives: 2010 SS Camaro
Well the way I see it, if one day you decide to Supercharge it and you have 1 7/8" headers, NOW you are forking out more money when you could have just got the 2" headers that are like...$70 more...if that. So I'm going with the 2" headers.
Either way, if you're going to be spending almost 2 grand, what's another $70 which may save you thousands in the long run?
Levi_Engle is offline   Reply With Quote
Old 04-05-2010, 09:00 AM   #11
Whiskey Tango Foxtrot
Drives: 2010 GT500
You dont need 2" headers just because your going with a supercharger. Lets not pretend that 1 7/8s is an economy car exhaust manifold. Most of you going with 2" will never really need it.
Whiskey Tango Foxtrot is offline   Reply With Quote
Old 08-25-2016, 03:15 PM   #12
NicKey
Drives: Nickey Super Camaro
NicKey Performance tested on the Wegner NASCAR certified engine dyno with both the LS3 and LS7. We use 2" on most all LS7 builds and 2" on most LS3 / LSA FI builds and 1 7/8ths on L99/LS3 N/A builds up to 600hp.
Also, your exhaust system after the header collector can have an impact on the overall power results as well.
NicKey is offline   Reply With Quote
Old 08-25-2016, 04:30 PM   #13
GodWentPunk
GodWentPunk's Avatar
Drives: 2015 2SS White Convertible CE/INDY
Took 6 years for that answer.....
K&N Blackhawk CAI, Muffler Delete, Range AFM, Bigworm Blackout kit, ZL1 Rims, Phantom Grills
GodWentPunk is offline   Reply With Quote
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 100 11-13-2010 04:51 PM
The truth about Shorty Headers JoshJ81 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 33 02-20-2010 02:44 AM
2010 Camaro American Racing Headers FREE Shipping MoranoRacing V8 Bolt-Ons & Tunes 2 02-10-2010 09:45 PM
Doug Thorley headers and axle-back ROCKS! SPANKT U Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 01-07-2010 11:36 AM
2" Headers Vs 1 7/8" Headers...Your Opinions PLEASE!!!!! Mr. Brownstone Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 29 11-18-2009 01:00 PM
