JDP Motorsports
Old 04-05-2010, 04:54 PM   #1
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Header question
Ok we pretty much all know that if you put on long tubes you need to do a tune or it will cause the check engine light to come on. We all know that a tune will void your warranty and most accept that as par for the course and could care less. My question is that once you put long tubes on and tune will you pass an emissions test? I believe some have said you could fail a visual inspection but if they just plug in and run it will it detect somethings not right or will the tune adjust it so the emissions machine detects no problems? Eventually I'll be getting headers either shorties now or LT's when my warranty is toast, but if they will fail it (the long tubes) I'm not gonna even bother. Whats the point if you can't drive it on the street right? Also I know the jury's out on weather shorties help or even hurt so don't even go there. I'm more concerned with the long tubes.
9/26/09 Took delivery!
Old 04-05-2010, 08:53 PM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Depends on what type of emissions test they do. If they do the sniffer test it will pass if you drive it for 20-30 minutes and get the cats good and hot first. If they do the code test (where they plug in and check for any codes related to the cats) you will fail. Getting a tune makes it so you pass both tests.
Old 04-06-2010, 01:55 PM   #3
RamAir02
Black/Black 2SS/RS
RamAir02's Avatar
Drives: '10 SS/RS M6, '07 ZX6R
I have Dynatech Headers and no tune and have never had a CEL come on!
Even the install instructions from Dynatech said you will not have a check engine light after install.
2010 SS/RS M6
Barton Short Throw, Halltech Yellow Jacket, BC Racing Coilovers, Dynatech LTs, SLP PowerFlo Axleback, JRE tune
12.58@111 1.88 60' (prior to tune)
Previous Cars: 1999 Trans Am, 2000 WS6, 2005 CTS-V
RamAir02 is offline   Reply With Quote
Old 04-06-2010, 02:05 PM   #4
A.R. Headers
A.R. Headers's Avatar
Drives: Pontiac G8 GT
RamAir, If they're long tubes the light will come on eventually. My G8 went 3 months before I saw it.
V6Sonoma, A savy tuner can get you through the inspection without issue. Most mod friendly dealers won't void you warantee because of tuning.
Nick
www.AmericanRacingHeaders.com
100% USA MADE
A.R. Headers is offline   Reply With Quote
Novice Header Question Inferno2SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 03-21-2010 12:19 AM
question about LT header codes-- AdamCzap Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 03-08-2010 06:29 PM
Header question brtaus Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 02-26-2010 04:35 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
LT header and exhaust question upstateny Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 02-02-2010 10:23 PM
