BORLA
Old 04-05-2010, 08:36 PM   #1
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
? about ticking sound w/ Long Tubes
If I get down on the side of the car where the cats are you hear a ticking sound, IMO it doesnt really sound like an exhaust leak, but one of my friends swears it is
Are there any specific symptoms of a Exhaust Leak?
How do I check for one?
I know the car is running rich because I have alot of build up at the tailpipes, but there does not appear to be any buildup at the connection points
Does anyone else have a similar sound with their LT's?
I dont know if this is relative or not, but I cleared my o2 sensor codes a while back, after about 3 weeks or so the light returned, so I ran the car with it on for another month or so. I again cleared the code, and this time it returned within 2 days.
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 04-05-2010, 09:02 PM   #2
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
My Doug Thorley's have a faint ticking, but the CEL gonna keep coming on till ya get a tune.
csjcsj is offline   Reply With Quote
Old 04-05-2010, 09:03 PM   #3
Jeanius
Jeanius's Avatar
Yea I dont really care about the CEL, Im just concerned about the ticking, and was thinking if there is a leak would that trip the CEL faster?
TRADED: 2016 2SS M6
Old 04-06-2010, 12:02 AM   #4
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
I dont know if this is your problem however my 69 Camaro ( 396 bigblock ) with hooker supercomp longtubes has the same sound. I once thought there was a leak down below by the collector then when you get down and listen its like someone has a screw driver and it hitting the headers.
I asked a few people and heard the same thing from everyone
High compression header ping NORMAL
Jekyll-N-Hyde is offline   Reply With Quote
Old 04-06-2010, 12:17 AM   #5
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
The sound you are hearing is the sonic pulse of each cylinder's exhaust stroke "pinging", or impacting on the side of the relatively thin wall of the header tubes. My 68 Camaro had this sound and I loved it! To me it sounded like a lot of steel shot bouncing off a steel plate, and had an almost hissss sound to it. That's my 2 cents anyway.
Meh
My 5th is offline   Reply With Quote
Old 04-06-2010, 07:05 AM   #6
Russell James
Russell James's Avatar
Drives: Camaros
Inherently noisy valve train amplified by thin walled exhaust. Thick cast iron manifolds masks the sound, but once you have headers on there, tick tick tick. Mine does the exact same thing. My Silverado does the same thing. My Harley does the same thing. Although I recently solved my Harley (which use small block chevy roller lifters) tick with a set of better lifters.
IMHO the Gen IV motor family could use some more refinement in the valve train dept. In this day and age of advanced computer engineering, sound labs... is it too much to ask for lifters that don't tick?
If the aftermarket has a better lifter, I'll probably be swapping lifters some day in mine with a nice cam.
The exhaust pulse in the header tube is different, that is not an objectionable tick. The tick is clearance in the valve train. I could hear mine slightly when stock. As soon as I put the headers on, holy crap this is one ticky valve train.
Old 04-06-2010, 12:47 PM   #7
Jekyll-N-Hyde
There you go Header PING
Old 04-06-2010, 01:35 PM   #8
Jeanius
Jeanius's Avatar
Thanks!
TRADED: 2016 2SS M6
Old 04-13-2010, 04:16 PM   #9
Jeanius
Jeanius's Avatar
Hey fellas, I had my car tuned today and the tuner said that for sure I have an exhaust leak.
How do I find it?
TRADED: 2016 2SS M6
Old 04-13-2010, 04:20 PM   #10
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
You should see carbon build up if there is a leak.. My car makes the same noise in the same location as you described, I would not worry about it. Just keep an eye out at all connection points to see if there's any black stains
Black 2SS RS LS3 Inferno Int. Powdercoated 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Tuned by Doug Ring at ECS. 472RWHP/445RWTQ.Dynapack Dyno.
MrGazinya is offline   Reply With Quote
Old 04-14-2010, 04:21 AM   #11
NinoSS
Drives: 2SS/RS CGM LS3
http://www.camaro5.com/forums/showth...hlight=Hissing
Se the link above, I had this bigtime on my SRT8.
All this said, I'm getting LT's again. I can't leave that much easy power on the table...
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 04-14-2010, 05:32 AM   #12
ebbett21
ebbett21's Avatar
Drives: E2 HSV LS3
mine ticks quite loud at idle on one sideonly where the cat area its just pulsating exhaust gases it sounds unusual but my tuner said its common on aftermarket long tube headers so sleep easy mate you not thre only one
ebbett21 is offline   Reply With Quote
Old 04-14-2010, 11:16 AM   #13
Ivan @ Southwest Speed
No ticking whatsoever with my Doug Thorley Long Tubes!
Interesting!
-Ivan
Old 04-14-2010, 06:03 PM   #14
Jeanius
Jeanius's Avatar
Thanks guys, is there any other ways to check other than looking for the soot around the connection points?
I want to make sure
TRADED: 2016 2SS M6
Long Tubes or Mid Length Headers? TAG UR IT Off-topic Discussions 15 12-24-2010 08:43 PM
Doug Thorley Long Tubes Herron Performance V8 Bolt-Ons & Tunes 9 12-12-2009 12:31 PM
Dynatech Long Tube Package With Corsa Exhaust tbyrne V8 Bolt-Ons & Tunes 2 09-19-2009 09:44 AM
Dynatech Long Tube Headers - Next Batch Shipping Soon! tbyrne V8 Bolt-Ons & Tunes 0 09-16-2009 01:02 PM
Exhaust sound bulldog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-07-2009 03:43 PM
