| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
![]() Drives: 2lt Red jewel vin#6632 Join Date: Apr 2009
jl stealthbox install
Finally got the jl stealthbox install done with 500/1 amp. Sounds great but need to figure out how to stop my rearview mirror from shaking so bad, cant even use it.
![]() Drives: Black 2ss 6m with cyber grey strips Join Date: Mar 2010
really nice
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
turn the radio down.
shakes crazy at 18
400HP used to be enough..
Drives: 2010 2SS rs manual Join Date: Aug 2009
You should add the remote bass control like I am doing. It's a single knob control you can mount up front and allows you to adjust the boost of the subwoofer. It plugs into the JL amp (there is a phone plug jack for it). Also, check the settings on the amp. Infrasonic filter should be on, freq at 30. Bass EQ to ON. "Q" at 1.6, center freq to 60. Amp LP filter to 12db. Filter freq to 80.
Hope this helps.
Currently in the fleet... 2010 ZR1 Corvette, 2011 Cadillac CTS-V, 2010 Camaro SS single turbo, 1967 Camaro SS350, 1969 Camaro SS427.
Stock is boring! |
#6 |
did you use a line input off of one of the back speakers as your source?
#7 |
had it installed dont know what they did
#8 | |
#9 |
![]() Drives: 2SS Camaro Join Date: Oct 2009
Really nice setup. If you dont mind me asking, how much did the stealth, amp and install run you? They did a nice job with the amp. I want to get that done for my car too.
Thx! |
#10 |
#11 |
Anthony Cascio
Comments on your J.L. Audio Subwoofer Amp Install
I also recently purchased the J.L. Audio Stealthbox with single 12” subwoofer & the 500/1v2 monoblock subwoofer amplifier for my Summit White Camaro 2SS/RS. I’m doing my own install and appreciate your installation photos. I have the system hooked up & running. My amp is currently sitting on the floor of the trunk & I like the location of your amp inside the trunk, under the the rear window panel speaker deck. Your photos indicate the your amp is mounted horizontally, upside down. The amp installation manual rates that as “Fair” for cooling efficiency. Installing the amp horizontally, right side up, is rated “Good” for cooling efficiency. You may want to question the installer as to his/her reason for installing the amp in a less desirable position for heat dissipation. Perhaps he/she liked being able to view the three indicator lights on the top of the amp by having them face down towards the floor of the trunk, rather than up where they would be difficult or impossible to see, since they would be very close the rear window speaker panel. Excessive heat build-up can lead to degraded performance of the amp, according to J.L. Audio. My preference will be to install the amp in the same location as yours but with the amp right side up & with the controls/switches/wiring side of the amp facing towards the back of the vehicle so I have direct access to that side of the amp and can view it from the rear of the vehicle. Your installer opted to install the controls/switches/wiring side of the amp facing forward, possibly to better hide the wiring from view & to shorten the wiring runs.
#12 |
R.I.P. jesserayjames
looks awesome
#13 |
Holy crap! $1800!?!?
MBRP Catback/Magnaflow Resonated X/Airraid V2 CAI/Dash ABL/Interior LEDs/Custom Paint/Jet Coated American Racing LT Headers/High Flow cats/Trifecta Tune |
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
#15 | |
![]() Drives: 2011 Camaro 2SS/RS Black on Black Join Date: Aug 2010
#16 |
| Thread Tools | |
| DIY Hurst Short Throw Shifter Install - Pix and Video | TAG UR IT | Camaro DIY & HOW-TO instructions & discussions | 77 | 04-28-2013 09:10 PM |
| DIY : Install headers on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 43 | 12-20-2012 08:41 AM |
| DIY : Install Performance Swaybars in 2010 Camaro | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 16 | 09-12-2011 09:41 AM |
| Complete SubThump install from a Novice | Susantroy1 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 62 | 09-06-2010 03:17 AM |
