Solo Performance
Old 04-07-2010, 04:24 PM   #1
motor1
motor1's Avatar
Drives: 2010 Camaro 1SS/RS/M6.....no longer
Need help with trunk question please
I installed an NLP spoiler and I was VERY careful in tightening the bolts. My question is: Does your trunk feel COMPLETELY flat across the trunk from one side to the other where it meets the spoiler? I did not pay much attention prior to removing the factory spoiler. Now I have two small areas that are lower than the rest of the trunk line where it meets the NLP spoiler (2 center bolt arear). As I said I was very careful using a 1/4 inch drive so I do not see how i could have pulled down the trunk causing it to crater in. Any input would be greatly appreaciated.
motor1 is offline   Reply With Quote
Old 04-07-2010, 04:34 PM   #2
garcmol
garcmol's Avatar
I don't have a spoiler. There is a little dip on both sides of center of the truck. The very edge is flat. You're not seeing things! I don't think you damaged anything
Old 04-07-2010, 04:39 PM   #3
motor1
motor1's Avatar
Thanks, having a black car makes your mind play tricks on you. I appreciate your time.
Old 04-07-2010, 05:28 PM   #4
motor1
motor1's Avatar
I also realized after the fact that I do npt recall observing any padding around the studs preventing rain from going into the trunk. Guess its coming off again, GRRRRRRRRRRRR.
ported subwoofer box that fits in the trunk? 1badtie Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 24 10-16-2011 10:09 PM
KW V3 Coilover Question, Setup & Trunk Access Mark-HD Suspension / Chassis / Brakes 6 03-22-2010 04:29 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Simple Question about trunk button Caution 5th Gen Camaro SS LS LT General Discussions 12 01-02-2010 10:44 PM
Gap below trunk lid scorpio 5th Gen Camaro SS LS LT General Discussions 8 09-24-2008 10:09 AM
