Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 04-09-2010, 12:08 AM   #1
76z28
76z28's Avatar
Drives: 1976 camaro
2006 gt?
so i have a camaro last time i ran a 14.3 as my fastest with some lean problems.... and 3.42s so trapping in second and starting off well before the power band
going back in may and my friend might take his 2006 gt
i now have gotten the lean problem fixed, 4.56s with posi i did spin a little before installed and a better exhaust installed and hoping to go low to mid 13s with kinda newb driver(myself) and the other being newbish himself lol
anyone think i can give it a good run for the money, i dont plan on blowing the doors off but i still think it would be a good race
76z28 is offline   Reply With Quote
Old 04-09-2010, 12:19 AM   #2
a_Username
a_Username's Avatar
Drives: 2010 2SS Camaro
Do you own an SS?
a_Username is offline   Reply With Quote
Old 04-09-2010, 12:34 AM   #3
76z28
76z28's Avatar
Drives: 1976 camaro
no, 75 type lt z28 with
flat topped single sided valve relief pistons
trick flow 195 heads at 62cc so its around 10.7:1 compresssion
3000 stall converter
got rid of quite a bit of weight such as air and all that, jack, spare tire, weight of heads, wind shield wipers
turbo 350 with 4.56 posi
cam is 246/254 duration at .050 and .495 lift and .510 lift
both intake first and exhaust second
Old 04-09-2010, 04:17 AM   #4
a_Username
a_Username's Avatar
I saw that in your profile thing but I was thinking 14.3 was 2010 V6 Camaro times lol. Then I saw you talking about modifications, so then I thought you might have had a SS that you ran in bad weather conditions lol.
If I remember correctly, the 05-09 GTs usually run around high 13s. So, it seems like you'd be able to take him if the GT is stock. Has your friend done any modifications of his own?
Old 04-09-2010, 04:22 PM   #5
SWAT 79
SWAT 79's Avatar
Drives: 2005 Cadillac CTS
The 05-09 gts are good for 13.5 to 13.6 quarter miles, with as good as 13.3x if the driver is excellent (glory pass was 13.28), with that said you shouldn't have a problem taking him, I'd say you could get low low 13's out of that car.
SWAT 79 is offline   Reply With Quote
Old 04-10-2010, 12:55 AM   #6
76z28
76z28's Avatar
Drives: 1976 camaro
nope stock mustang
Old 04-10-2010, 12:56 AM   #7
2SSARMY
Drives: 2SS/RS
Most out on the track will be running 13.8-15.0~ Best GT time I've ever seen on the track was a 13.7 by a 2006 GT with slicks.
2SSARMY is offline   Reply With Quote
Old 04-10-2010, 01:42 AM   #8
76z28
76z28's Avatar
Drives: 1976 camaro
no way a 2006 gt ran a 15....
Old 04-11-2010, 07:51 PM   #9
SWAT 79
SWAT 79's Avatar
False, You must have a horrible da and high altitude. Get to the track more, mustang gt's are solid mid 13 second cars, not far behind your l99 camaro.
Old 04-11-2010, 08:25 PM   #10
2SSARMY
Drives: 2SS/RS
Been out on the track 4 straight weekends. GT's are not running all that well. The best GT run I've seen out at the track is a 13.7.
Then again, finding people with regular street cars who know how to shift at the track is pretty rare.
Old 04-11-2010, 10:50 PM   #11
SWAT 79
SWAT 79's Avatar
Good point, but a lot of the tracks are also seeing camaro's running slow times too, and vettes, and gt500. Average times for competent driver (I do not fall into that category at the track) are mid 13's.
Old 04-11-2010, 11:16 PM   #12
2SSARMY
Drives: 2SS/RS
I by all means agree. Just remember, there's a time you SHOULD run and a time you ACTUALLY run. My best time has been a 13.4 when I should be running 13.0-13.2. Just saying.
Also, you're right. At the track on friday a GT500 was running 13.9 lol and a z06 was running 12.9. Was pretty funny how I beat a GT500, even though the guy clearly had NO idea how to shift.
Old 04-12-2010, 12:25 AM   #13
Sax1031
Drives: 2000 Mustang GT
I've seen ZO6s and Vipers in the 14s. Definitely hysterical shit.
Sax1031 is offline   Reply With Quote
Old 04-12-2010, 12:28 AM   #14
2SSARMY
Drives: 2SS/RS
I think my laugh of the year goes to a Acura RSX with the license plate BOOSTED and a high wing spoiler running 20.5~
