Cold Air Inductions
Old 03-16-2007, 07:33 PM   #1
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Callaway C16
Callaway C16
When even a Corvette isn’t enough, call Reeves
By MARK VAUGHN
AutoWeek | Published 03/12/07, 3:22 pm et
AT A GLANCE:
2007 CALLAWAY C16 CHEVROLET CORVETTE
AVAILABLE: Now
PRICE: $120,000 base, $192,000 as tested
DRIVETRAIN: 6.0-liter, 616-hp, 582-lb-ft supercharged V8; rwd, six-speed manual
CURB WEIGHT: 3375 lbs
0 TO 60 MPH: 3.3 sec (mfr.)
FUEL ECONOMY (EPA COMBINED): 22.5 mpg
What could a Corvette owner want that’s not already in the fabulously fast standard-issue General Motors Chevrolet product? Fer cryin’ out loud, the thing’s already got 400 hp in base trim and a whompin’ 505 hp as a Z06. And since it weighs just a little more than 3000 pounds wet, it can spank the decals off almost anything that lines up against it. What more could any sensible Corvette luster seek?
More everything, that’s what.
Callaway has been giving Corvette owners just what they love and lust after for 20 years, and non-Corvettes for another 10 years before that. Reeves Callaway started in his garage in Connecticut in 1977, making turbochargers for various performance cars. Then, in the late ’80s, a particularly well-done Alfa supercharger caught the eye of Corvette chief engineer Dave McLellan. That led to the fearsome twin-turbo Callaway Corvettes of 1987-91, including the all-conquering, 254-mph, twin-turbo Sledge Hammer. From that slobbering beast came the SuperNatural LT1-based naturally aspirated Corvettes (AW, Jan. 25, 1993), followed by the C12 homologation cars that allowed Callaways to race at Le Mans and now this, the C16.
Bill Delaney
Callaway supercharged GM's 6.0-liter aluminum-block V8 to boost output to 616 hp and 582 lb-ft of torque.
The 16 in its name does not refer to cylinders, as many people who saw our test car assumed, but to the car’s spot in Callaway history. This is the 16th project to come out of the Old Lyme, Connecticut-based supercar maker. Given the marque’s powerful history, this one is a somewhat more subdued version, if you can use the word “subdued” in the same sentence as “616 hp.”
The heart of the Callaway conversion is an Eaton/Magnuson roots-type supercharger that bolts nicely on top of the 6.0-liter aluminum V8 Chevrolet engine (a kit for the 7.0-liter Z06 is in the works). The engine has the same 4.00-inch by 3.62-inch bore and stroke, and it wasn’t necessary to change the compression ratio. Callaway also adds higher-flow injectors. That gets horsepower up to 560 at 6200 rpm and torque to 500 lb-ft at 4750 rpm.
That’s for the base C16, which you could glibly call C16 Lite. But the base C16’s 560 hp is probably not going to be enough, is it? So Callaway has an option package that adds unique cylinder heads, larger intake and exhaust valves and Callaway-specific rocker arms and pushrods, all of which bring power up to 616 hp at 6200 rpm and torque to 582 lb-ft at 4750 rpm.
Bill Delaney
The spartan interior of the stock C6 is extensively retrimmed for use in the C16.
It’s not at all unmanageable. With only 7.5 psi of boost max, Callaway didn’t even have to rebuild the bottom end of the motor.
“It’s not a big stress on the components,” said Pete Callaway.
Yes, there’s a Pete Callaway, son of Reeves. He started working in his dad’s shop at age 11 and is now West Coast rep for Callaway Engineering, setting up Chevrolet dealers to service and sell C16s. Like his dad, he is tall, polite, soft-spoken and knowledgeable, not at all what you’d expect of a “tuner” proffering 616 hp of anything.
He gave us a walkaround of the car outside the Callaway family compound deep in the heart of Orange County.
“The C12 was the total package. You could only get one trim level, and that had everything on it,” he said. “With the C16, you can do just the brakes or just the suspension or whatever you’d like. The C16 is essentially a menu for all the components.”
There are a lot of components.
For brakes, you can leave the standard Z51 four-piston calipers that GM puts on Corvettes, or you can upgrade to Callaway six-piston front and four-piston rear grabbing 355-mm by 32-mm discs.
The suspension is a collaborative effort with Eibach. You still have the SLA upper and lower A-arms and transverse leaf springs, but Callaway added double digressive shocks and Eibach springs. The dampers adjust 10 ways for jounce and 10 ways for rebound, allowing you to come up with a track setting and a commuter setting, for instance. Ride height adjusts more than 2 inches.
“We bring the spring rate up a little bit,” said Callaway.
Our test car rode on Michelin Pilot Sport 275/30ZR-19s front and 325/25ZR-20s rear, mounted on Dymag wheels with magnesium centers and carbon fiber outers. Callaway is working with Yokohama on a 345/25 for the rears that should be available in early 2008.
Bill Delaney
The C16 feels tighter, stronger and faster than a stock Corvette, yet it's still easy to drive in commuter traffic.
The entire car is wrapped in the wild Tangelo from House of Kolor fiberglass bodywork you see here, though you don’t have to get orange. The only original exterior parts are the roof, decklid and mirrors. Everything else is all Callaway, from the big hood bulge to the uniquely subtle strakes that form faux C-pillars in back.
On the road, the C16 immediately feels even tighter, stronger and faster than a stock Corvette. It’s everything buyers love about that car and more. While roll, dive and squat are mighty hard to sense in a standard Vette, they’re almost entirely absent in a Callaway. And yet the extra power and torque are there anywhere on the tach, especially from launch.
Our car had the optional racing seat, awkward to get into but one of the most comfortable and secure buckets we’ve ever sat in.
Just as with the regular Corvettes, this one was easy to drive in typically lousy commuter traffic, even easier since the one-to-four shift lockout had been disconnected mysteriously in our car.
It would have been fun to tabulate lap times back-to-back between our 616-hp C16 and a Z06 straight from Bowling Green. But a tough schedule meant only a single afternoon in the Callaway and no time for a Corvette loaner from Chevrolet. We have no doubt the C16 would hold the edge, but it sure would have been a fun day finding out.
If you own a Z06, we suggest buying one of these, too. Then send us your results.
Callaway is taking orders now and needs about two or three months’ lead time. Order now (www.callawaycars.com), and yours should be ready for track days once spring rolls around. Prices are about $190,000 total for a fully loaded honker.
KILLER74Z28 is offline   Reply With Quote
Old 03-16-2007, 08:03 PM   #2
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
No thank you.
I can think of ALOT of better cars for $190K.
Moose is offline   Reply With Quote
Old 03-16-2007, 09:46 PM   #3
Casull
Casull's Avatar
Drives: Chevy Silverado
Originally Posted by Moose View Post
No thank you.
Can't agree more! Especially when that thing is rated at 616 hp.
IMO if I wanted to spent an exorbanant amount of money to soup up a corvette I would send it to Lingenfelter where, for around $100,000 total, I can get a 725HP TT Vette.
I dunno, that thing just like looks wierd to me.
Casull is offline   Reply With Quote
Old 03-16-2007, 10:10 PM   #4
Moose
Moderator
Moose's Avatar
If rumors are true, and Chevrolet produces the new Corvette SS, or whatever Chevrolet calls it, for about $90K less, you can have a Corvette with more HP than the Callaway. Plus, it'll look ALOT better.
Old 03-20-2007, 09:46 AM   #5
35th02ss
35th02ss's Avatar
Drives: 02 SS
Nice looking car, but I agree with Ed. Rather have a Corvette SS
35th02ss is offline   Reply With Quote
Old 03-20-2007, 11:23 AM   #6
LowRider
LowRider
LowRider's Avatar
Drives: 1992 Camaro Z28 & 1996 S-10
Send a message via AIM to LowRider Send a message via Yahoo to LowRider
Damn I really like that, but I think I agree with you all I would go with the Corvette SS,"Z07",Stingray, or whatever the hell they arer going to call it.
LowRider is offline   Reply With Quote
Old 03-20-2007, 11:57 AM   #7
OverAnxious
OverAnxious's Avatar
Drives: 1967 RS/SS L78 Coupe
Send a message via AIM to OverAnxious Send a message via Yahoo to OverAnxious
Callaway cars have always been for the people with the $$ to not have a showroom stock vehicle. It's all about the custom ride
Anyone remember when someone at Callaway wrecked one of the very first C5 Corvettes to hit the streets
Joe
Over Anxious - 1967 Camaro RS/SS L78
5th Gen Camaro BLOG // My eBay auctions
OverAnxious is offline   Reply With Quote
Old 03-21-2007, 09:02 AM   #8
Urthman
Future Camaro Owner
Urthman's Avatar
Drives: 2010 Jeep Wrangler Sahara 4dr
Pppffffffttt. No way would I buy that thing. $190k? Are you kidding me?
Urthman is offline   Reply With Quote
Old 03-23-2007, 02:24 PM   #9
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
personally I think it's ugly. and for about 110k less I can buy a z06. then with only 10k I can make it have a hell of a lot more power
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 03-23-2007, 04:28 PM   #10
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I'll admit, you could make it more powerful, but how much more...from what I've read on the Z06, that would be hard to do
Old 08-06-2013, 02:22 PM   #11
Stevew
Stevew
Drives: 2012 Camaro 2SS and 2012 Corvette
I have 2012 vet with auto and 2012 SS with manual. I am not use to driving with paddle shifters and prefer the manual in my Camaro. I find that a just drive the vet in the regular mode rather than sport.
Stevew is offline   Reply With Quote
Old 08-06-2013, 02:48 PM   #12
trewyn15
trewyn15's Avatar
Drives: 2004 Monte Carlo LS
That thing just looks weird IMO some of the older ones were much nicer
2004 Monte Carlo LS - 1966 AMC Rambler Rebel Classic - 2000 Trans Am WS6
trewyn15 is offline   Reply With Quote
Old 11-20-2013, 02:35 AM   #13
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Thank God, some real purists in this thread. Other than a DCT as discussed, I can't believe anyone would want an auto Vette. Unless you have a medical condition, intend on making the car a dedicated drag car, or have to share it with your spouse that doesn't know how to drive stick, get the M7.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
