SDTW Custom Wheels & Tires
Old 04-09-2010, 07:35 PM   #1
Jarhead
Semper Fi Camaro
Jarhead's Avatar
Drives: 2010 1SS/RS Aqua Blue LS3 Gauge PKG
Rear Diff Oil Change @ 2465 Miles
Hello all, I have attempted to document what I found when I changed my Rear Diff Fluid. I will begin with posting pictures and a brief narrative of my findings. These pics were taken with my cell phone, not bad considering. I did not attempt to show the actual procedures of the fluid change, just what was found in the oil/on drain plugs.
The process I followed is as follows:
-Before and After pics of Filter used.
-Location of Drain and Fill plugs.
-Draining the fluid.
-Drain Plugs after Removal. (For Identification the upper plug seal is raised on the plug.)
-Drain Plugs after being Cleaned.
-Filter right after draining.
-Old Oil
-Particles found in filter.
Pics of the filter before being used.
Drain Plug Locations: Drivers side of Diff.
Lower First then Fill Plug.
Draining the Diff
Plugs After being Removed
Filter Right after draining
Upper plug Gunk
Lower Plug Gunk
Filter after drain 5 min Wait time.
Old Oil, Looks very nasty and dirty,
Mileage at time of change.
Based upon my findings I conclude that the fluid is very nasty in appearance and that it was not highly contaminated with metal particles.
Other than a few very small metal shavings I did not discover a high amount of any particulate matter.
After cleaning with brake parts cleaner I discovered about 7-8 tiny slivers, actually much less than I anticipated to find.
Please feel free to ask any questions. I will be screening the gunk off the plugs via a coffee filter to see what I find there.
I hope that this helps!
Robert
Jarhead is offline   Reply With Quote
Old 04-09-2010, 08:11 PM   #2
SA CHEVY
"HILLARY"
SA CHEVY's Avatar
Drives: "HILLARY" :D
Very nice write up man, I'd been waiting for someone to do the fluid change and take pictures with a filter. Kudos to you and I will definitely be doing mine within the next 500 or so (sitting at just over 1,300 right now).
2010 Camaro SS2 L99 Aircharger, Straightpiped, DT long tubes, Dyno tune by Cal Speed
384 HP & 392 Ft/Lbs. 13.203 @ 107.13 mph at Camaro5FestII
SA CHEVY is offline   Reply With Quote
Old 04-10-2010, 04:57 AM   #3
Stingr69
'69 Owned Since '79
Stingr69's Avatar
The fluid was odd colored from the set up paste they used at the factory. It would not have caused any grief.
-Mark.
Old 04-14-2010, 12:35 PM   #4
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
This is straight from a GM bulletin which should be available at your GM dealership. Just ask the service manager.
“American Axle uses a white or yellow gear “rouge” or marking compound when the tooth contact pattern on the gear is inspected. The white marking compound in particular colors the fluid a milky or semi-metallic gray, … the coloring only lasts between 1,000 and 5,000 miles and then the fluid appears normal. If the customer does not comment of any noise concerns please do not attempt any repairs for the discolored fluid on vehicles under 5,000 miles..."
That all said I still plan to change mine around the 1500 mile mark to get the oil and any slivers of metal out of the rear end while still early in its life.
I do like some of the tips that I have read so far on how to change the fluid. I will be looking for the pump to help get the fluid into the case.
Not sure which fluid I will be using, that research is still on going.
Good luck to all those who change their own fluid.
Old 04-14-2010, 01:13 PM   #5
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Changed mine at 12K and did not look bad or have much metal in it. Did stink though.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-02-2010, 01:25 PM   #6
Mojave
2016 Camaro SS
Mojave's Avatar
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8
Thanks ! I am in the process of changing mine right now.
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4)
Some AutoX Mods Planned
https://www.youtube.com/c/MojaveKY
https://www.instagram.com/mojaveky/
https://twitter.com/MojaveKY
Mojave is offline   Reply With Quote
Old 05-02-2010, 09:39 PM   #7
LT1Jeep
Ecstatic Camaro SS Owner
LT1Jeep's Avatar
Drives: Jeep(s) [1in pieces] and 2010 SS/RS
the posi friction material can also make the oil look shiny like metalic paint. if there anent large metal pieces, i wouldnt worry too much. the gunk on the plug magnets is also common. but nice to see someone who cares enough to change the oil so early. :-) what oil did you replace it with?
LT1Jeep is offline   Reply With Quote
Old 05-03-2010, 02:57 AM   #8
Ronn
Ronn's Avatar
Drives: 2010 Camaro
Not as bad as I thought it was going to be, thanks for the pics.
1SS / RS / M6 / IOM / Black rally stripes / Polished wheels
It's a high school prom, it's a Springsteen song, it's a ride in a Chevrolet...
Ronn is offline   Reply With Quote
Old 05-03-2010, 07:24 AM   #9
Mojave
2016 Camaro SS
Mojave's Avatar
Went royal purple
Old 05-03-2010, 01:06 PM   #10
gearhead440
gearhead440's Avatar
Drives: Yellow 2SS, 6 speed manual
Replaced mine at 500 miles with Royal Purple. My plugs looked just like yours and color of diff fluid was the same. A hand pump worked wonders to get the fluid into the rear.
gearhead440 is offline   Reply With Quote
Old 05-03-2010, 08:42 PM   #11
Jarhead
Semper Fi Camaro
Jarhead's Avatar
After I let it sit for a few days the sediment on the bottom was unreal. I poured it out and there was a layer of sludge like covering the bottom. The best description is it looked like an oil slick covered the bottom of the pan.
I'm real glad that I changed it.
Old 05-06-2010, 07:26 PM   #12
tom692010
Drives: 4 wheels
Originally Posted by Mojave View Post
Went royal purple
what's the part # Or what he label say?
tom692010 is offline   Reply With Quote
Old 05-07-2010, 07:36 AM   #13
jtzako
Drives: 2010 IBM Camaro SS
I havent had a chance to get under there and check mine out.. but how do you get the new fluid in there? Is there a special funnel or pressure gun you'd need since its under the car?
jtzako is offline   Reply With Quote
Old 05-07-2010, 08:21 AM   #14
Sponge60
OBX
Sponge60's Avatar
Drives: 2010 2SS / RS, Black on Black, L99
Try this.
Glenn Rainey
Outer Banks, North Carolina
Sponge60 is offline   Reply With Quote
3000 miles time for an oil change Gnarlygianni Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 28 03-10-2010 02:57 PM
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
Oil Change at 500 Miles? red71cheyenne Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 01-10-2010 11:01 AM
Car "waking up" after oil change..is this due to the fuse pull? CamaroFemme 5th Gen Camaro SS LS LT General Discussions 6 10-05-2009 03:44 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
