Solo Performance
Old 04-10-2010, 10:47 PM   #1
jordan 572
jordan 572's Avatar
Drives: none
2 amps 1 sub
I have a 13w7 dvc 3 ohm sub. i also have one jl 1000/1v2 and one jl 500/1v2. i am using the two amps to power the one sub. I just need to clarify one simple question. How do I connect to the sub from the amp? Just put both positives wires from each amp into one positive jack on one of the vc and the opposite vc put the two negatives into that. then bridge the two vc from negative to positive? Like this diagram except with two amps.
http://a248.e.akamai.net/pix.crutchf...2-ohm_mono.jpg
jordan 572 is offline   Reply With Quote
Old 04-11-2010, 07:18 AM   #2
Sheitskees
Drives: 2006 Cobalt SS
I don't know much about stereo install but it says your URL is invalid...
Sheitskees is offline   Reply With Quote
Old 04-11-2010, 10:04 AM   #3
Eric Baker
Drives: Black/Black 2SS/RS 6M
Don't run two different amps to one sub, you'll end up ruining your sub. They must be the same. BTW that 1000/1 is plenty for that sub, basically made for it. If you wer to run two amps to one sub, you'd just hook up each amp to each voice coil, so one amp to coil 1 and the other to coil 2, pretty simple. It's the level matching that's the tricky part, which can't be done with two amps of different power, especially of such different power as 500W and 1000W.
Eric Baker is offline   Reply With Quote
Old 04-11-2010, 12:39 PM   #4
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
What he said!!
PacMan
mrray13 is offline   Reply With Quote
Old 04-11-2010, 12:55 PM   #5
third1
speed freak
third1's Avatar
Drives: 2012 Cadillac Escalade,10 IOM 2ss
That would not be good. Everything must be equal to biamp a speaker.
Current:2012 Cadilac Escalade.2011 CVO StreetGlide cammed,tuned&loud. 2010 IMO/IO,custom stripes,GFX,sunrf,solo exhaust,JBA shorties,rotofab,Jannetty tune,Pfadt,JLw6 Audison&Hertz,7/4/09 2GIFKIEJ6A9123779Del 7/10/09 Former Camaros 72 LT1 Z28, 86 z28
third1 is offline   Reply With Quote
Old 04-11-2010, 12:58 PM   #6
jordan 572
jordan 572's Avatar
Drives: none
anyone here know any amp that can put out 1500 watts at 3 ohms or around that?
Old 04-12-2010, 09:35 AM   #7
mrray13
mrray13's Avatar
With a rating of 3 ohms, you'll need an amp that has a regulated power supply, ala JL. That means it can make the same power at various impedance. JL, PG and a few others have them. Google regulated power supply amplifiers, you might come up with something.
Otherwise, look into something that can do 2kwrms at 2ohm. Wiring up to 3 will not hurt the amp, it will only mean you aren't using the amp to it's fullest potential. Might be the best option, as there should be plenty of amps in the power range, with that impedance.
PacMan
whats the difference between full digital amps and other amps? G.E. Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 01-27-2010 04:59 PM
whats the difference between full digital amps and other amps? G.E. Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 12-06-2009 06:13 PM
Group Buy - Custom Speaker Boxes, Amps, Subs (Updated post 25) TAG UR IT USA - Texas 41 10-19-2009 09:56 PM
**Alpine Amps For Sale** tones2SS Members Classifieds - Non-Automotive 8 10-03-2009 03:20 PM
