JDP Motorsports
Old 04-11-2010, 09:00 PM   #1
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
Speaker/Sub install
So I need to decide how to wire my new sound system...
I have 6.5in RE Audio component speakers for the front and RE Audio 6x9s for the rear. Also going in will be either an RE Audio 12" or (2) 10" subs in sealed enclosures.
Now, I'll be using a line out converter to connect the amp(s). But how should I wire it all up?
Should I wire my speakers into the stock head unit, i.e. not amplified? Or should I leave all the stock stuff unplugged and run from line out to amp and then to speakers, i.e. amplified?
I have a 2 channel and a 4 channel amp so I've got lots of configurations available.
Give me your inputs please.
terry_b is offline   Reply With Quote
Old 04-11-2010, 09:01 PM   #2
Indpowr
Drives: Corvette C6
I would personally run the amps...A lot more power than stock
Old 04-11-2010, 09:27 PM   #3
terry_b
terry_b's Avatar
But would wiring be an issue? I mean running all those wires from amp to speakers... I want it to look nice, not cybernetic.
Also, tips on wiring my Subs. They are 4 ohm dual voice coil which can be
wired to 2 ohm or 8 ohm. Amp is stable at 4 though. should I just wire one voice coil?
Old 04-11-2010, 10:13 PM   #4
third1
speed freak
third1's Avatar
Drives: 2015i Cadillac Escalade,10 IOM 2ss
You can run the sub at 8 ohms but the amp will only run at 1/2 the rated power. Try hooking it up in 2 ohm to see if the amp will power it. My amp was stable at 4 ohms but I wired my JL w6 for 2 ohms and my amp is handling it.
Current:2015i Cadilac Escalade,2016 Lexus RC350,2011 CVO StreetGlide cammed,tuned & loud. 2010 IMO/IO,custom stripes,GFX,sunrf,solo exhaust,JBA shorties,rotofab,Jannetty tune,Pfadt,JLw6 Audison&Hertz,7/4/09 2GIFKIEJ6A9123779Del 7/10/09
Former Camaros 72 LT1 Z28, 86 z28
[SIGPIC]
third1 is offline   Reply With Quote
Old 04-11-2010, 10:21 PM   #5
terry_b
terry_b's Avatar
Would there be any negative impacts doing it this way? What is the concern with "stability" as it applies to the amp?
Old 04-12-2010, 08:29 AM   #6
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
DO NOT wire just one coil! That can, and most likely will, kill your sub. Either grab a 2 ohm stable monoblock, or pray your electrical can feed the extra current needed to supply a 2 channel amp wired to 2 ohm mono to keep it from becoming an electric skillet, lol. And possibly cooking the amp.
PacMan
mrray13 is offline   Reply With Quote
Old 04-12-2010, 03:42 PM   #7
terry_b
terry_b's Avatar
Ok, well I believe I have solved the problem by getting a different speaker. The new one is 2 ohm per coil so I can wire it to 4 ohm total and it'll work perfect, yes?
Old 04-12-2010, 04:31 PM   #8
mrray13
mrray13's Avatar
Yep, that'll work, lol!
PacMan
speakers, wiring
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 69 08-19-2017 10:09 PM
DIY : Install Performance Swaybars in 2010 Camaro Nine Ball Camaro DIY & HOW-TO instructions & discussions 17 09-14-2015 12:36 AM
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 01:25 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
