Caryle Racing
Old 04-12-2010, 10:16 PM   #1
nalinc23
nalinc23's Avatar
Drives: 2010 2SS/RS 6MT
JL Clean Sweep
This is the first car I'm considering changing out the stock speakers, buying an amp, but leaving the stock headunit. I am quite picky though and wanted to know if products such as the JL Clean Sweep really do sound just as "clean" as a high quality aftermarket headunit?
Has anyone changed out the components/added an amp and one of these? If so are you happy? My last car had Memphis Pro components and the one before that Boston Acoustics Pro Series (not to be confused with the BA stockers) and I miss the clarity.
'10 2SS/RS 6MT, Silver Ice Metallic/Black, CAI Inc Intake, Magnaflow 3'' Catback Exhaust 16483, Llumar 35% Tint, Headlight Armor 20% for Fog/Side/Tail Light Lenses
nalinc23 is offline   Reply With Quote
Old 04-13-2010, 08:42 PM   #2
nalinc23
nalinc23's Avatar
Bump...anyone?
Old 04-13-2010, 08:50 PM   #3
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
the JL cleansweep is awesome, but use it with the signal summing interface also. Makes a huge difference. I am going to have a true SQ competition car with the factory head unit. But i will be switching out the JL audio pieces once the JBL MS-8 interface comes out, it auto does speaker distances, EQ, Frequency adjustments etc to make it the perfect in-car SQ system.. Google the MS-8 should be out in June.
then i will say bye bye to my JL stuff.
The 2010 Sin is offline   Reply With Quote
Old 04-13-2010, 09:01 PM   #4
2010 BADSS
2010 BADSS's Avatar
Drives: 2010 2SS/RS IOM
Hey, sorry I didn't see your 1st post. When I first got my Camaro, I replaced the front speakers. Still not enough bass. So then we decided to add and amp replace the 6x9's and add JL audios stealthbox with their 12 in sub. Because of the way the stock 6x9's are crosswired for bass, we also added the clean sweep to "detune" the factory stereo. I must say, with this setup, it sounds like an aftermarket setup. My only complaint is that I now have two controls for volume. It works optimally if I set the factory volume to about 15 then control the clean sweep volume to do fine adjustments. However, if I want a minimal volume I have to lower the factory volume to about 10-12 for everything to be balanced. It really is Awesome and better than I ever thought the stock stereo was capable of sounding, and now I'm pretty used to adjusting it with the two volume controls. IMHO this minor inconvenience is definitely worth the quality of sound I'm getting!
LPE 650 BHP package
Dual disc clutch set
Borla catback exhaust-S type
DSS 9" rear with 3.90 gear
Pfadt suspension/Hotchkiss chassis brace
Forgeline Wheels VR3S/Nitto tires
Beware of the LPE Sisterhood
2010 BADSS is offline   Reply With Quote
Old 04-15-2010, 09:37 PM   #5
nalinc23
nalinc23's Avatar
Wow shows how much I know, I didn't realize the Clean Sweep had volume control I thought it was just a signal processor that cleans up the crappy stock headunit's signal going out to the speakers/factory amps. I could see that being annoying b/c you basically lose steering wheel controls for VOL?
Old 04-16-2010, 12:40 PM   #6
2010 BADSS
2010 BADSS's Avatar
No, all the steering controls work the same. I have a switch for my amp/clean sweep that has a power on/off function as well as output level. In a way it is similar to having a volume control on a subwoofer so you can fine tune the level for different genres of music or talk radio without having to go to the trunk. You could just pick an output level that works well for most genres, leave it there and control everything through the factory stereo. The way mine is set up, if I have the amp/clean sweep off completely the factory system only controls the center speaker. Once its on, I can set the output level. At low levels the center channel dominates, at higher levels the other four speakers and subwoofer dominate. Initially, I had to play with all the controls till I figured out where I like it. Now I pretty much know, and really it's not that complicated, but since I never had one before it took some getting used to. The sound is phenominal. It is crystal clear at all volume levels if set up right, and goes as loud as any aftermarket setup I've ever had!
LPE 650 BHP package
Old 04-16-2010, 04:00 PM   #7
loopback
SoCal C5 Family Member
loopback's Avatar
Drives: 2010 Black 1SS
Upgraed mine with JL 3sixty. For that you do need some equpment to tune but it sure does sound nice.
Comlete upgrade was:
72sq Ft of Dynamat Extreme (mega pack)
Rockford 3SIXTY.2 integrates to existing head unit and sound processing.
Rockford AMP 4x100w T6004
Alpine AMP 1x1000W PDX11000
Focal Components in the front KRX 2-way
Focal COAX in the back KRC 2-way
JL Stealbox with 3-10W3
loopback is offline   Reply With Quote
Old 04-16-2010, 04:06 PM   #8
I'm happy with my BA system.
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 120 07-31-2016 06:37 PM
Stoner Invisible Glass Reach & Clean Tool Replacement Bonnets At ProperAutoCare.com Angelo@Autopia Wash/Wax/Detailing and Cosmetic Maintenance Parts 2 02-16-2010 10:35 AM
JL Audio Clean Sweep Lightson357 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 01-19-2010 03:14 PM
Anyone else having trouble keeping the interior clean?? Betsi1214 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 24 12-06-2009 12:18 AM
Mr Clean Auto Dry & waterblade? Matt'sSS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 3 08-17-2009 01:19 PM
