Old 04-13-2010, 07:34 PM   #1
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Billet Pedal Install - sorry no how to pics / only final result
Sorry I forgot to take pics as I went along but totally forgot. If there is anyone in the Dallas area that wants to do this I'd be more than glad to help out and document with pics and full details.
The foot rest and gas pedal use self tapping screws so you just screw them in. For the clutch and break pedal, you have to pull off the rubber pad and then drill 3 holes in the pedals. Then you put bolts through and tighten the locking nuts on the back. It really isn't that bad of an install..
So it would be something like this.
Prep - put down paper or anything you like to catch the metal shavings from when you drill into the break and clutch metal pedal. Make sure you have good lighting so you can see well
1.) Pull off the rubber pad from your break pedal and your clutch pedal. NOTE: Good idea from Grinder19 :
One thing I found helpful was to put masking tape over the pedals before placing the billets in place to mark the holes for drilling.
Made it real easy to see those marks come drill time.
2.) Put the billet pedal over the metal pedal on your clutch and make a mark in the 3 areas you want to use to bolt down. I chose the top outer 2 and the middle bottom hole.
3.) With a small drill bit, drill holes in the three areas you have marked. After I drilled each hole, I put the billet pedal up to see if all was still lined up.
4.) With a larger drill bit, make the holes larger. I matched up the drill bit to the screws before hand so I had an idea of what size I needed. I then backed down one size as I didn't want to make it too large. I would then test fit the bolts and see if I needed to go a bit larger. I don't remember which I ended up using, but I think it was 5/32 or 11/64 .. Please go small and then up it if you have to, don't take my sizes above as gospel!!!
5.) Repeat 2 - 4 for the break pedal.
6.) Line up your gas pedal. With a phillips head screwdriver and one of the self tapping screws, screw in one bolt. (I used the one of the bottom 2 holes). Don't completely tighten down. Make sure all is lined up and repeat on one of the top holes. Complete buy doing the same with the other 2 holes (one top and one bottom) and tighten.
7.) Basically repeat step 6 for the dead pedal (foot rest).
8.) Put the billet pedal on the break pedal and put the bolts through the holes and tighten with the included allen wrench. I used a socket and ratchet on the back to hold the nut tight. Repeat for each bolt.
9.) Repeat step 8 for the clutch pedal.
10.) Grab a cold one and relax NOTE: I did step 8 and 9 last so that you don't have the billet pedals in your way if you need to get around down there. The pedals are very functional and grab pretty good
Took about 1 hour for the install.
Thanks,
Crowley
Crowley is offline   Reply With Quote
Old 04-13-2010, 08:22 PM   #2
Grinder19
Grinder19's Avatar
Drives: 2008 Pontiac G8/2010 2SSCamaro
Good write-up my friend. I installed similar pedals myself. One thing I found helpful was to put masking tape over the pedals before placing the billets in place to mark the holes for drilling.
Grinder19 is offline   Reply With Quote
Old 04-13-2010, 08:25 PM   #3
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
That is a real good idea !! I'm going to add the suggestion.
thanks,
Gary
Old 04-13-2010, 10:00 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Grinder.....are these the same pedals as Crowley's. I would actually prefer to get them without the Lingenfelter logo.
Build Journal
Old 04-14-2010, 08:20 AM   #5
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Just by looking, they do appear to be pretty much the same, but only without the logo on the foot rest .. I'm sure Grinder can chime in and PM you where he got them. You might check out the interior vendor area on here as well.
thanks,
Crowley
Old 04-14-2010, 10:34 AM   #6
lrc250
480 HP 2010 2SS
lrc250's Avatar
Drives: 2010 Camaro 2SS
I'm pretty sure he got them from www.billetanything.com as I did. See this thread http://www.camaro5.com/forums/showthread.php?t=65601 which has a 10% coupon code you can enter.
Without data you are just another person with an opinion.
1100 :10/15/08
3000:3/2609
3300:4/18/09
3400 (broadcast)April 25, 2009
3800 (produced):May 4, 2009 #7470
4200 (Shipped): June 1, 2009
5000 (At Dealer) June 9,2009
374.9 rwhp & 371.7 rwtq - bone stock @ 85 deg.
lrc250 is offline   Reply With Quote
Old 04-14-2010, 10:57 AM   #7
Camaro21
Drives: SOLD - 2013 M6 ZL1
Nice Job Crowley !!
Camaro21 is offline   Reply With Quote
Old 04-14-2010, 12:26 PM   #8
Buffnshine
So Cal Camaro5 Race Team
Buffnshine's Avatar
Drives: '10 SS/RS, '06 HHR, '70 El Camino
nice write up, looks great. Looking forward to getting just cant decide if want them plan or not. Is all the hardware included?
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet
Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels
Buffnshine is offline   Reply With Quote
Old 04-14-2010, 01:07 PM   #9
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
All screws, bolts and nuts are included. An Allen wrench is included for the bolts.
Old 04-15-2010, 12:24 AM   #10
Grinder19
Grinder19's Avatar
I got mine from billetanything.com. You get a camaro5 discount code for 10% of too. The link lrc250 posted here has their 10% off note. The coupon code is "camaro5". Easy job to install, less than 30 mins.
Old 04-15-2010, 12:42 AM   #11
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Hey! I resemble that!
Nice job!
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
FINAL Production 2010/2009 Camaro! (PICS) rray200 Camaro Photos | Spyshots | Video | Media Gallery 799 05-20-2011 12:48 AM
Request: Billet Grill pics... Shaggy Camaro Photos | Spyshots | Video | Media Gallery 38 11-04-2009 10:45 AM
pics of ground effects install arabicame Camaro Photos | Spyshots | Video | Media Gallery 8 05-12-2009 04:16 AM
Where are the final pics? Sierra 5th Gen Camaro SS LS LT General Discussions 34 07-10-2008 03:46 AM
