HURST
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 04-14-2010, 07:48 PM   #1
ittybittyfds
ittybittyfds's Avatar
Drives: 2013 Victory Red ZL1 M6 #495
Fuel Sending Line leak
Ok all
i could use some guidance
i have found a leak in what appears to be in the fuel sending line
what is my next step to fix?
do i need to Drain the Tank or can it be fixed with Gas in Tank?
is fixing this semi easy or should i have somebody do it?
Secondly
how the hek do you troubleshoot electrical problems on these cars
i have a good alternator and a brand new battery (2nd battery already)
how do i determin what is draining the battery
2013 Victory Red ZL1 M6, Roto-Fab CAI,
ittybittyfds is offline   Reply With Quote
Old 04-15-2010, 01:36 AM   #2
09'Z28
The "Mad Hamster"
09'Z28's Avatar
Drives: '71 Camaro, '90 mx5, '71 2002
I don't know about the sending unit but for the power drain make sure everything is bolted on to the alternator tightly, yes I know it sounds stupid but I know two people that had charge issues just because the ground needed to be tightened about a half turn more.
09'Z28 is offline   Reply With Quote
Old 04-15-2010, 07:59 AM   #3
ittybittyfds
what do you mean whane you say...Power Drain?
Charge issues?
Old 04-15-2010, 12:15 PM   #4
My 76
Drives: 1976 Camaro
Can you cut out the section of line and replace it with rubber fuel line ? From the picture its kind of hard to tell whats what.
My 76 is offline   Reply With Quote
Old 04-15-2010, 01:21 PM   #5
LookingGlass
Future Chevy Owner
LookingGlass's Avatar
Drives: Impatiently waiting!!!
Send a message via Yahoo to LookingGlass
It is tough to tell with that pic. But I dint think it can be adressed without draining the tank, unless you can clamp off the lines some how. It may be in your best interest to just replace it as a whole. That's what we did. Actually we did all the lines! What a pain.
LookingGlass is offline   Reply With Quote
Old 04-15-2010, 08:21 PM   #6
09'Z28
The "Mad Hamster"
09'Z28's Avatar
Charge issues?
you said something was draining the battery, I meant power as in electrical
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 02:51 AM
FS: New Venom 424cc 40lb/hr High Flow Fuel Injectors tooNz213 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 12-23-2009 03:53 PM
New item - Auto Meter ecometer fuel mileage gauge - plug and play @ PFYC.com Redshift Audio / Visual / Electronics/ Gauges / Nav 0 07-01-2009 09:56 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Less Fuel and More Safety TAG UR IT General Automotive + Other Cars Discussion 2 10-14-2007 01:12 PM
