| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
U235 is fun!
Drives: CGM 2SS/M6 Join Date: Apr 2009
overheating amp
and it cuts off to cool down. Prolly means I need a bigger amp? I have 12inch sub in a subthump box and bought that Quartz amp from his site.. Think maybe 300w.. That bitch gets hawwwt! though.. hehe I don't really rattle the car going down the road but I do like my music.. hehe
What do you guys think? |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2LT SIM/RJT Join Date: Apr 2009
Could be a couple things, first thing I would check is the ohm rating on the sub and the amp. Maybe someone with more knowledge can help but that is my first guess.
![]() Drives: 2010 Camaro 1SS Join Date: Mar 2010
Tape your wires... often times the amps shut off because two wires touch. make sure they are completely taped and arent jumping a spark from remote to grnd...
Rhymin and Stealin
how long before it get too hot and shuts down?
if it plays at all it is not the power wiring. but it does sound like you have it wired at a resistance that is too low for the amp to run stable.
Bryan
![]() ![]() Enchantment Editions Arc Audio Competition Team Image Dynamics Elite Sound Performance Team Team Stinger |
![]() Drives: 2011 IOM 2SS RS M6 Join Date: Feb 2010
I would check the ohm rating on the sub. As also check where you have your amp located, if it can "breathe".
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 1LT RS Rally Yellow Join Date: Oct 2009
![]() OP, post the specs on the sub and the amp. We need to know coil impedence as well as the amp's ratings. If sub/amp are impendence matched, make sure you have enough wire. What gauge did you use to wire up the amp? Where is your ground located? I, too, think it's an impedence problem. But we will cover all the bases, just in case, lol.
#7 |
U235 is fun!
thx guys for the replies..
I think this is my amp http://www.onlinecarstereo.com/CarAu...rt_DSC280.aspx and my speaker http://subthump.com/product_info.php...roducts_id=123 it did fine thru the winter but with hotter temps it will play for about 20mins.. It does get pretty hot as I've felt it.. I have the gain turned up maybe 2/3-3/4 but have a remote volume that rarely will be turned up past halfway. oh yea..I have the speaker bridged on the amp.. One channel pos and other chan neg.. Can't recall how I hooked up the speaker.. but a 4ohm sub is a 4ohm sub, right? If it had 2 sets of connects, could I have hooked it up to 2ohms? It hits pretty hard for a single.. I think its just the quality of the box.. |
#8 |
What size wire gauge do you have, and where is ground located.
#9 |
U235 is fun!
#10 | |
Wrong sub. Dual 4 ohm, wired parallel with be 2ohms. So if that's what you have, and that's how it's wired, that's the problem. You are overdrivng the amp. You need a single 4ohm or a dual 2ohm sub wired is series, and you'll be fine.
#11 |
Helping Build America
Drives: 2010 2SS/RS,LS3 2006 Colorado Join Date: Aug 2008
Not trying to sell the product, but i've got 2 Alpine PDX amps in my Colorado and 1 that will be going in the Camaro. They never get hot and the power rating is TRUE rms. Actually they come with the bench test cert in the box. The PDX 1000.1 sub amp actually tested 1147 amps rms. It's pushing two Pioneer 10" subs and never gets hot plus they take up half the space of other OVERRATED amps. They cost more but they do deliver.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
#12 | |
In theory even 10 gauge wire would be enough to power 320watt. Specially if it is wired real close to the battery in the trunk. Anyhow, I agree with your assessment. |
#13 | ||
The amps power rating will have nothing to do with this. If your sub and amp are wired up with the correct, matching impedance, then the amp won't overheat. Well, it shoudln't, unless you are clipping the hell out of it trying to be the loudest guy on the block. Or youhave it shoved in a hole with no air. Quote:
I would never use 10g, even if it is supposed to handle it, lol. That's speaker wire! 8 gauge minimum, and in this case with the battery in the trunk, I wouldn't be afraid to run it. The subs power rating won't matter in this case either. It's voice coil configuration will. A power rating is a good estimate for what it can handle thermally, and even then, only look at the RMS rating. Peak is bs.
#14 |
U235 is fun!
Lets say I did hook up the sub for a 2ohm configuration.. I can just hook up one of the 4ohm channels to have a 4ohm configuration, right? Even if its a dual voice coil? That just gives you the option of 2 or 4ohm connects, right?
#15 |
CorkTulsa.com
Drives: 2010 2SS BLK, 2013 2SS CRT Join Date: Feb 2010
if you only hook up one voice coil you will fry your subwoofer. both coils must be used at all times.
#16 |
CorkTulsa.com
Here you go bud.. wire it like this:
#17 |
CorkTulsa.com
This will save you some sad burn up of a good COMP sub. or a 2 channel amp.
#18 | |
By the way, 10 gauge wire = 30 amp, and it runs my home central air conditioner. So that should give you an idea of what it is capable of. ![]() I have my 2 old PPI art series amps run off of a single 8 gauge wire in my camry. Been like that for 10 years now, and never blown the 30 amp fuse. |
#19 |
CorkTulsa.com
I have double 0 gauge in my camaro to a 4 gauge distribution block. A 10 gauge wire in a house with direct current is different than the delivery from a battery/alternator def. takes a larger cable in a vehicle.
#20 |
CorkTulsa.com
TREEFROG. Make sure you have a really good ground as well. I would try to use 8ga. at least.
#21 | |
I was saying since the battery is in the trunk, the sub and amp are probably about 3 feet away, you could get away with running 10 gauge wire. So running too small a power wire is probably not the issue. I don't recommend using 10 gauge wire anyhow. That's all. |
#22 |
CorkTulsa.com
:-) treefrog i hope you get this worked out..
#23 |
U235 is fun!
Thx for the info! Really appreciate it.. Plan on getting this fixed upped as soon as I can 8)
#24 | ||
Never run a dual coil sub on a single coil. Bad things can happen!!!! Quote:
It's more of a personal preference I do it that way. All based upon personal experience, nothing more, nothing less, lol.
#25 |
![]() Drives: Dodge Stratus Join Date: Oct 2008
Try using a 10 gauge speaker wire that 16 gauge is just too small. I think the amp is trying too hard to push the signal thru the wire, therefore over heating. Just my .02
| Thread Tools | |
| Amp install- how to (w/pics) | ASTEDA | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 54 | 04-21-2013 06:23 AM |
| Amp install - how to (w/pics) | ASTEDA | Camaro DIY & HOW-TO instructions & discussions | 28 | 01-27-2013 03:07 PM |
| Stereo GUIDE ALL READ | WildBeast15 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 29 | 09-11-2010 01:14 AM |
| Adding an Amp to the BA system... | ZZcamaro | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 1 | 07-09-2009 11:52 AM |
