Cold Air Inductions
Old 04-15-2010, 04:24 PM   #1
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Just rear drop springs?
I got my rear drop springs in and Im thinkin about not putting the fronts in. I like how it looks this way with both wheel wells the same height. I am concerned about how it will handle however. I also replaced the sway bars with SS sway bars. Any input would be greatly appreciated.
ROD1 is offline   Reply With Quote
Old 04-15-2010, 07:40 PM   #2
ROD1
Retired
Old 04-15-2010, 07:44 PM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I'd love to help you man but I really just don't know the answer. It seems like the car would ride really weird and it might be hard to align this way.
Old 04-15-2010, 07:46 PM   #4
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
pics, bro..
Old 04-15-2010, 07:47 PM   #5
mdinferno
mdinferno's Avatar
Drives: 2010 IBM 2LT/RS
I am also interested in seeing pics
mdinferno is offline   Reply With Quote
Old 04-15-2010, 08:02 PM   #6
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
I did the exact opposite.
I put in the droped front springs, and left the back up.
Your car will not handle well when cornering.
My car handles so much better with the front droped, and the stiffer springs and sway bars really help the car not roll over.
stratman2SSRS is offline   Reply With Quote
Old 04-16-2010, 02:28 AM   #7
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
You have reduced the balance. but you need to determine this. Take it out in a open parking lot a play
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 04-16-2010, 07:37 AM   #8
ROD1
Retired
pic
pic
Old 04-16-2010, 07:43 AM   #9
ROD1
Retired
mike
dms
Will do! I read that the fr/rr weight ratio is 52/48. By dropping the rear springs it should shift the ratio closer to 50/50 and isnt this ideal for handling or is it just a starting point?
Old 04-16-2010, 10:58 AM   #10
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
IMO it looks much better level. Don't worry about the naysayers, your car isn't going to mis-handle. The drop itself is nothing to worry about from a handling standpoint, put a few bags of groceries in the back and you would have practically the same weight shift. What you also get when installing lowering springs is increased spring rates. Generally increasing rates on one end of the car only is a no-no but in this case it actually works for you. The 2010 already has a problem with excessive understeer, by increasing the rear rates you are actually helping to correct this. Increasing rates in the front only just contributes to the already-bad understeer problems....
BMR guy is offline   Reply With Quote
Old 04-16-2010, 12:57 PM   #11
ROD1
Retired
Great info. I did a test drive and really pushed the Gs and it felt great! No under/oversteer. Felt like if it was gonna break loose, the whole car would slide, not one end or the other. I feel good about it. One last question, since changing the rear springs and both sway bars to the heavier V8 stock bars, Should I still invest in a 4 wheel alignment? BTW do you have a price for a complete kit of the "stiffening parts" you produce for the rear and the pan as well as shock tower brace?
Old 04-16-2010, 01:10 PM   #12
looks good
Old 04-16-2010, 01:39 PM   #13
Info@PeddersUSA.com
Your Camaro will handle better with the back end lower than the front. But you will not be able to get to a 50/50.
Lowering the front end will decreasing understeer, but changing the relationship of front coil rates to rear coil rates by increasing front and not the rear, will increase understeer.
Now what needs to be done is to road test it and see if it meets your needs. If so, then be happy with your decisions
mike
dms
Old 04-16-2010, 04:19 PM   #14
ROD1
Retired
mike
dms
Done! It is perrrrrrrrrrrrrrfect. I did get it a little loose once but it was slideways! It was just startin to rain but....Thanks for every1s input, I really appreciate it! Cam5 peeps are the chit!
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 10:58 PM
Factory savings direct $185 Drop Springs Granatelli Suspension / Chassis / Brakes 16 02-22-2010 03:09 PM
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
Drop Springs PonyCrusher Suspension / Chassis / Brakes 1 12-03-2009 05:00 PM
Pfadt drop springs & sway bars installed! POWERFREAK Suspension / Brakes / Chassis 25 11-16-2009 04:07 PM
