Old 11-13-2010, 02:49 PM   #57
jfish7
Fish
jfish7's Avatar
Drives: 2010 Camaro SS
Just ordered the PDIM unit and steering wheel controls. Can't wait to install into car. However, I am a female that never has done any of this before. I will be following the step by step instructions posted on this site. Will let everyone know how things turn out.
jfish7 is offline   Reply With Quote
Old 11-13-2010, 07:47 PM   #58
2010IBMSS
2010IBMSS's Avatar
Drives: 2010 camaro SS RS
let us know if you need any help...It is pretty easy to do.
2010IBMSS is offline   Reply With Quote
Old 11-15-2010, 01:28 AM   #59
2010IBMSS
2010IBMSS's Avatar
**UPDATE****
I have learned that if your PDIM stops working, you DO NOT need to disconnect the battery at all!
all you have to do is pull out (F13) fuse labeled "DISPLY 10A" on the side fuse box by the driver side. This will reset the radio.
As per the shop manual, the fuses description is as follows:
T11 Multimedia Player Interface Module (USR), A20 Radio/HVAC Controls
My USB port stopped working, the radio showed "NO DEVICE FOUND" and then I unplugged the USB flash drive and tried to plug it in again, but nothing happened. I also tried to plug the "AUX" cable in and...nothing.
After a quick Fuse pull, everything worked again. I hope this helps, I started hating disconnecting the battery all the time it quit working.
Old 11-22-2010, 04:56 PM   #60
JSC81
JSC81's Avatar
Drives: 2010 1SS/RS M6
17. Perform the radio calibration upgrade. This will allow the radio to recognise the PDIM. This is required on all vehicles that have not had the PDIM installed before.
18. Perform a PDIM calibration upgrade. This will ensure the PDIM has the latest level of software available.
So "17" Is getting it sent from GM?
And... "18" Is performed by the service technician?
Just asking because I just had to leave my car overnight because the technician was mentally challenged. Even after giving him the instructions he tried to blame wiring of course although I pointed out I had power. Then he went on to say that the tech he talked to for what I believe was 17 in the instructions wasnt required..... READING COMPREHENSION..... Jesus where do they hire these people from!?
JSC81 is offline   Reply With Quote
Old 12-12-2010, 11:08 PM   #61
afireinside
Firefighter/Medic
Drives: 2010 Camaro 1SS LS3 IOM, 2008 Z71
nice pics wonder w all the issues if its gonna be worth it for my 1ss....
Mods: LSR Sway Bars, LSR Short throw shifter, MPD1 spoiler, Heritage Grille, 5% Limo tint
afireinside is offline   Reply With Quote
Old 01-04-2011, 09:37 PM   #62
SSilver5gen
SSilver5gen's Avatar
What comes in the package? Just a new harness?? Do you have to cut into the center console for the port?
SSilver5gen is offline   Reply With Quote
Old 01-04-2011, 09:42 PM   #63
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
http://www.camaro5.com/forums/showthread.php?t=45256
PDIM accessory kit comes with the following
No cutting is necessary, there is a replacement plug that has the USB port and AUX in.
Old 01-04-2011, 09:49 PM   #64
SSilver5gen
Awesome thank you!!
Old 01-07-2011, 08:47 PM   #65
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2010 Summit White Camaro SS/RS
You don't need to plug anything into the back of the radio do you?
gl2filmerguy is offline   Reply With Quote
Old 01-08-2011, 01:52 PM   #66
slick rick
SoCal Mayhem
slick rick's Avatar
You plug the harness into the disconnect that is on the passenger side of the console. Nothing new needs to be plugged into the back of the radio. You can review the install instructions here: http://www.camaro5.com/forums/attach...9&d=1254768031
Old 01-09-2011, 02:38 PM   #67
Coop
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
Old 01-22-2011, 04:22 PM   #68
gl2filmerguy
Ok just installed mine. Very straight forward. Hardest part was trying to do it in 10 degree weather in a garage with no lights :0
I'm gonna get my radio programed soon hopefully.
Old 01-29-2011, 11:34 AM   #69
Daniel92
Drives: 2010 camaro ls
with the steering wheel controls added to my ls wil it be ablle to stream music wirelessly or do i need this usb thing added?
Daniel92 is offline   Reply With Quote
Old 01-29-2011, 11:45 AM   #70
jtzako
Drives: 2010 IBM Camaro SS
Controls alone do not do anything for you. You need some method to hook the phone/music player to the car. The PDIM is what adds the usb port. There is also a way to add bluetooth but I havent done that one.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Pfadt Race Engineering DIY Drop Spring installation procedure PfadtRacing Suspension / Chassis / Brakes 20 09-23-2011 09:31 PM
PDIM / USB port firmware update done in Houston? rolnslo USA - Texas 28 02-09-2010 03:46 PM
USB port stopped working philthy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 85 11-11-2009 06:14 PM
USB port intermittent... shall we compile a list of PDIM failures? JDBeck23 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 49 09-01-2009 01:57 AM
USB Port location/relocation 2ssJB Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 15 05-01-2009 04:28 AM
