HURST
Old 10-06-2008, 05:18 PM   #1
DOOREV800
DOOREV800's Avatar
Drives: 2010 Camaro SS LS3
keyless entry programming
I have a 95 Camaro and want to program another key fob. Anyone know the procedure?
DOOREV800 is offline   Reply With Quote
Old 10-06-2008, 05:25 PM   #2
CamaroScotty
Drives: Your new SLP Camaro!
Send a message via Yahoo to CamaroScotty
I don't have the 1995 - this is for a 1996, you could try it...
1. Turn the ignition switch to the OFF position.
2. Remove the RADIO fuse.
3. Cycle the ignition switch from the OFF position to the RUN position (as far as you can go without cranking the engine) 3 times within 5 second ending in the RUN position. The vehicle will verify entry into the programming mode by locking then unlocking the door locks.
4. Press and hold both the LOCK and UNLOCK buttons on the first transmitter for approximately 15 seconds. The vehicle will verify programming by locking then unlocking the door locks. Your new remote has been accepted and all existing remote codes have been erased.
5. Repeat the previous step for each additional transmitter (including any existing transmitters). You may program up to 4 transmitters. This must be done before the RADIO fuse is reinstalled.
6. Place the ignition switch in the OFF position. IMPORTANT: The remote keyless entry system will not be operational if the radio fuse is open.
7. Replace the RADIO fuse. If at any time it is necessary to restart the procedure, turn the ignition OFF and proceed again with step number 1.
CamaroScotty is offline   Reply With Quote
Old 10-07-2008, 09:09 AM   #3
DOOREV800
DOOREV800's Avatar
Cool, I will try it tonight. Thanks Scotty!
Old 10-07-2008, 10:36 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
WOW! Good man!!! Scotty can even be your Service Advisor
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 10-07-2008, 12:07 PM   #5
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
'95 and earlier are OBDI computer-systems. Any techniques used on 1996 to present vehicles probably won't work, because the newer OBDII system was instated -- so be careful. But I suppose it's worth a shot since you're on that borderline...
Old 10-07-2008, 12:41 PM   #6
CamaroScotty
yep...my sources only go back to 1996.....but I furgured it was worthwhile...I'll dig a little more...
Old 10-07-2008, 12:46 PM   #7
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
http://shbox.com/1/4th_gen_tech2.html#1995keyless
yotaman96 is offline   Reply With Quote
Old 10-08-2008, 08:54 PM   #8
DOOREV800
DOOREV800's Avatar
yup does not work just for the record. going to try yotaman96 advise. i'll keep ya posted..
Old 10-08-2008, 09:06 PM   #9
DOOREV800
DOOREV800's Avatar
ok that link did the trick. You just have to jumper #8 and #4 terminals at the dlc. Thanks people!
Old 10-08-2008, 11:24 PM   #10
yotaman96
yotaman96's Avatar
No problem. That site has lots of info for your car.
LOL, a whole Wikipedia entry on Rice-burners Mr. Wyndham General Automotive + Other Cars Discussion 8 12-02-2007 10:36 AM
