JUICEDMOTORSPORTS
View Poll Results: Which is the your supercharger of choice as a bolt on for a 100% bone stock L99 A6 ?
Kenne Bell 52 17.22%
Magnuson TVS2300 125 41.39%
Vortech V-3 Si-Trim Supercharger Kit 26 8.61%
Magnacharger Intercooled Supercharger 19 6.29%
L99 ProCharger High Output Intercooled P1SC Kit 22 7.28%
Edelbrock E-Force Supercharger Street Legal Kit 41 13.58%
My choice is not listed. I will post my choice on the thread. 26 8.61%
Multiple Choice Poll. Voters: 302. You may not vote on this poll
Old 04-19-2010, 11:17 AM   #15
2KWIK4U
2KWIK4U's Avatar
Drives: 1969 Camaro and 2014 Camaro vert
I think most of the superchargers are putting out about the same for a stock application, with that said I do like the Edelbrock design. My car (I am waiting for the convertible) I am looking seriously at a turbo setup. Either way you go to get the full potential you should have dyno tune done just to make sure it doesn't fly apart at high speeds.
I would enjoy first then add the upgrades
JMO
Danny
Danny
" I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I require the same from them" -John Wayne "The Shootist"
2KWIK4U is offline   Reply With Quote
Old 04-19-2010, 12:01 PM   #16
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
I am going to recomend the TVS2300 for you because of price, availability, reliability, and ease of use. I also believe it will be capable of meeting your performance goals. None of the blowers you have listed would disappoint thought. Here are the answers to your questions that I feel comfortable answering:
First does the AFM on the L99 have to be turned off? If the AFM needs to be turned off, do the AFM lifters need to be swaped out?
You can keep your AFM in the car but if it is in your budget I do recomend you have it deleted and replace the lifters as they are the weakest link in your motor. Thats not to say you might not get 200,000 problem free miles from them, its just comforting to know your valvetrain is safe.
I like the superchargers that go on the top of the motor mostly for the look like the Magnuson TVS2300. Is that Maggie for short ? (you never know!!)
Yes same thing.
From what I understand the ones that bolt on like alternators like procharger and vortec claim to get more power because they can run intercoolers or because the run coolerGive me the pros and cons of both types of systems.
They are capable of producing more power but if you prefer the top mount blowers and don't need the extra power capacity than go with what you like. Procharger and Vortec are centrical superchargers and they build most of there boost in the upper RPMs
Does GM honor the factory warantees with the the Edelbrock E-Force Supercharger Street Legal Kit For Camaro ?
No, you will have to say good-bye to your factory drivetrain warranty in most cases. Gotta pay to play.
Which superchargere is the easiest to maintain? and lasts the longest? So I don't have to mess with it? Set it and forget it !
The Maggie definately meets those criteria better than most.
Which one can use the factory airbox?
Several of the top mounts give you that option.
What is a SAFE bolt on option that won't blow up anything on my car?
All of them in stock form are pretty safe. Its upping the boost that kills things.
What is a SAFE level of boost for the motor, tranny, and rear end?
6-7.5psi is your safe zone. You can run more but the risk goes up.
Will the supercharger be safe for a car with 30K to 60K miles on it?
Yes
Which kits require no modifications or the least modifications?
They all require some mods but top mounts are on the lighter end.
Will the stock fuel system need to be modified for my goals?
That will be dependant on your tune and boost levels.
Which will I be able to get parts for the easiest? and for years?
All the big name companys will be no problem.
Can the tranny and the rear end handle it?
As long as you don't start pushing huge power they will be ok. Most people are making 500-550RWHP through the A6 with no issues.
Can I keep the traction control system ??
Yes
Can I keep the stock GM tune??
Nope, it has to go bye-bye.
Are they all liquid cooled ??
I don't believe so.
Is the thing noisy ? I'd like a quiet one.
The Maggie and Edelbrock would probably be the quietest.
Who would you purchase from?
All the vendors who spend time posting results, feedback and advice here deserve our consideration first IMVHO.
I hope this helps you sir.
Robert91RS is offline   Reply With Quote
Old 04-19-2010, 12:55 PM   #17
obzidian
obzidian's Avatar
Drives: 98 camaro turbo
If i was going to go SC, I would go the Whipple 3.4L route! Hope that helps but I'm a turbo kind of guy and if you didn't go, the TWO fastest camaro's out there were turbo cars!
obzidian is offline   Reply With Quote
Old 04-19-2010, 03:01 PM   #18
Granatelli
Drives: 2SS Victory Red
I am sure you will get good advise from eveyone else
Granatelli is offline   Reply With Quote
Old 04-19-2010, 03:11 PM   #19
Granatelli
The Whipple is not there yet in terms of a complete and proven kit and you can make 900hp with a TVS2300
Old 04-19-2010, 03:57 PM   #20
Vinz68
Vinz68's Avatar
Drives: 68,69,72&10 Camaro's 12 CTS-V
I think a Maggie will work great for you. I had alot of other work done at the same time so I don't really know what just a Maggie on a totally stock car would be like. My car put down 635 hp 595 tq to the tire and I'm very happy with it...
Vinnie
Vinz68 is offline   Reply With Quote
Old 04-19-2010, 04:45 PM   #21
HaddadMotorsports
HaddadMotorsports's Avatar
Drives: Camaro
[QUOTE=2010 Bumblebee;1732016]
NO, magnacharger's tune leaves it intact, most have my customers including myself have opted to turn it off.
what happeneds when boost for 8 cylinders gets pushed into 4 cylinders when the AFM is on?
Not possible unless somebody really messes up your tune, this tuner should be shot however. I'm not going to get into all the parameters that are required for DOD/AFM to be active but, simply put you will not make boost anywhere near any of these parameters.
or are those valves open and just no fuel is being pumped in?
DOD actually disables the lifters and the injectors, hence killing that cylnder
If that's the case wouldn't a supercharger dry the cylinder walls?
Not the case
NO
This answer is a complex one. However all of these systems are intercooled and/or aftercooled. If you want my take on this question please feel free to call me. There are benefits to each system.
(meaning this one does not void the GM 5y/100,000m warantee)
Not that I know of
Magnacharger all the way
Which one can use the factory airbox? Does anything have to be moved?
Magnacharger, things always have to be moved, ie. we have to move your intake manifold to the garbage can
There are a lot of answers to this question, It all depends on what your going to do with the car, what octane you have available, how good your tune is etc.
Boost is somewhat irrelevant, Efficiency is very relevant, We've made 800rwhp on 11lbs, we've also seen cars have trouble making 500rwhp on 11lbs, in this particular scenario your tranny and rear end would be fine at 11lbs assuming you made 500rwhp, at 800rwhp forget about it. . The moral of the story is horsepower is more relevant than boost.
Will the supercharger be safe to put on a car with 30K to 60K miles on it?
Yes
Magnacharger
You will need to upgrade injectors. The Magnacharger somes with that
Magnacharger, vortech, ati, have been around for many years and i don't think any of them are going anywhere any time soon.
Do I need to drill the crank ? and how? is it easy if needed?
Yes you should pin the crank, again the magnacharger comes with a pinning kit. Its a relatively pain free operation, and its hard to mess up with the supplied jig.
Yes, we've been beating up on theses car and the G8's for several years now and havn't lost one yet. In fact i had my car making 650rwhp on slicks for around a month, car is still my daily driver and I havn't touched any of the factory long block or drivetrain
Yes
NO, unless you like holes in your pistons
The magnacharger is an air to water system, not sure if anyone offers an air to air system yet, but I'm sure it exists.
Which kits are you all using ?
Whatever is right for the customer
What are your HP ratings?
HP is relevant to $. So how much you want to spend = HP, for a million $ I'll set you up with a nice 2000rwhp daily driver on pump gas.
What do you run at the track?
This question is somewhat irrelevant. If i run 11.8's at California speedway, I'll probably run 11.3's at atco. Not mention are we talking about winter or summer.
A TVS 2300 is all but non existent on a stock car
Who have you purchased from? or would you purchase from?
I hear Haddad Motorsports has great customer service, and there prices can't be beat.
How much did your supercharger cost you start to finish??
Feel free to give us a call
Any regrets ???? Final tips or Suggestions ?
My only tip is that anyone with questions regarding any of these boosted systems should give us a call, its what i do for a living, and I won't bs you. There is logic to everything I say and do, and if we Don't know something I'll get you in touch with the guy that designed it.
I think my first step will be to reinforce the car first.
None of the reinforcements should void my warantee, I think.
And they probably need to be done anyway.
The zeta platform is one of the most rigid GM has ever produced and reinforcements are not typically needed unless we're going to push the limits.
Thanks
Mike Haddad
HaddadMotorsports is offline   Reply With Quote
Old 04-19-2010, 04:55 PM   #22
Granatelli
It is not alwasy about the cheapest price - it is about service too.
Old 04-19-2010, 05:28 PM   #23
bumblebeecamaro
Car Lover By Nature
Drives: Mini Cooper S
get the Maggie TVS2300, a good set of long tube headers (like the Dynatechs) and a good cold air intake like the ADM and you'll be all set.
bumblebeecamaro is offline   Reply With Quote
Old 04-19-2010, 05:46 PM   #24
Granatelli
GMS air intake with Maggie TVS2300
Old 04-20-2010, 06:03 PM   #25
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
tvs 1900
i wanted a 2300 but was asked to give the 1900 a test. First impression is this is all i need,i bought this car to develope the bolt in 9 inch rear kitt we have ,i wanted a lil more punch without needing a fuel system and a big clutch to hold it.. The 1900 is a great blower at a great price.If i can answer any questions give us a call
Hendrix-Engineering is offline   Reply With Quote
Old 04-22-2010, 11:47 AM   #26
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
TVS2300 track times & TVS2300 w/traction control "on"
Hello,
Thanks for all the great answers! If anyone else wants to answer those questions feel free to post your answers ! More info & opinions are welcome.
Some new questions;
1/4 MILE TRACK TIMES
What will the car run with a TVS2300 @ 6psi with the Magnuson tune that comes with the unit on a 100% stock 2010 camaro ss?
(more or less, or estimates)
What will that same car do with the TVS2300, CAI, tune, & short headers?
TRACTION CONTROL ISSUES
What happeneds to a 2010 supercharged camaro ss L99 A6 with 6psi of boost when you floor it with the traction control in the "on" position?
Does is just not go anywhere?
Does it go and then bog down?
Does it go better than stock?
Is it a pain/annoying to drive?
TUNE QUESTIONS
Right now the car has two modes "D" & "S";
Can you have one tune for the "D" mode & one tune for the "S" mode ??
What happends to those two modes after the maggie tune?
What happends to those two modes after any tune?
Do the "D" & "S" modes get lost in the tune?
Which mode does the tune reside?
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 04-22-2010, 12:14 PM   #27
HaddadMotorsports
Drives: Camaro
Originally Posted by 2010 Bumblebee View Post
Hello,
Some new questions;
What will the car run with a TVS2300 @ 6psi on a 100% stock 2010 camaro ss? (more or less, or estimates)
Mid 12's bad track hot day, low 12's good track good day.
What will that same car do with the TVS2300, CAI, tune, & short headers? (more or less, or estimates)
A couple of tenths faster than previously stated. Long Tube headers are where its at though, LT's will put you in the 11's all day anywhere.
It still works about the same. If you get rid of torque management it starts having a little bit of trouble keeping up. More importantly what are you doing at full throttle with traction control on?
It'll pull timing and/or throttle until the tires stick again.
Kind of
Turn traction control off, and it won't be a problem. It was designed for snow/ice, that the only time it should come into play.
TUNE QUESTIONS
Yes a good tuner can do that for you
Magnacharger doesn't do much for the tranny, for many good reasons. However there a good results to be had in the hands of a professional
When a car is tuned the only parameters that get changed are the ones being requested. I.E. if i want to change timing, thats the only part of the tune that changes.
Hope this helps
Thanks
Mike Haddad
Old 04-22-2010, 01:42 PM   #28
JJ2010
Drives: 2010 Camaro SS
Hope this helps
Thanks
Mike Haddad
Great answers.....
JJ2010 is offline   Reply With Quote
Opinions please - GMPP and dealer sheild protection options? Litd 5th Gen Camaro SS LS LT General Discussions 3 12-22-2009 08:47 PM
Suspension Work in the morning. I have few options need opinions 55Designs Suspension / Brakes / Chassis 1 10-30-2009 05:59 PM
OPINIONS NEEDED on options! Jackied 5th Gen Camaro SS LS LT General Discussions 29 10-13-2009 08:20 PM
Narrowed down my color options, would like some opinions! Ant 5th Gen Camaro SS LS LT General Discussions 13 01-21-2009 09:38 PM
