View Poll Results: Which is the your supercharger of choice as a bolt on for a 100% bone stock L99 A6 ?
Kenne Bell 52 17.22%
Magnuson TVS2300 125 41.39%
Vortech V-3 Si-Trim Supercharger Kit 26 8.61%
Magnacharger Intercooled Supercharger 19 6.29%
L99 ProCharger High Output Intercooled P1SC Kit 22 7.28%
Edelbrock E-Force Supercharger Street Legal Kit 41 13.58%
My choice is not listed. I will post my choice on the thread. 26 8.61%
Multiple Choice Poll. Voters: 302. You may not vote on this poll
Old 04-22-2010, 02:20 PM   #29
JohnInSoCal
Drives: RJT L99 500HP
Mike at haddad did my L99, it's at 8lbs boost with long tubes. He had S & D setup differently so that S has quicker shifts. I haven't run 1/4 mile yet, but it gets to 60 MPH in 3.8 seconds as my best run so far, haven't tried a 0-60 run in a while. With stock tires, traction is an issue. I always drive with TC off so timing is not pulled. I leave stabilitrack on for safety but it has never kicked in, I don't let it get too sideways and the car tracks fairly well after the rear end kicks out a little bit at first after losing traction but then it straightens up. I have about 3K miles on it since the mods and zero issues.
JohnInSoCal is offline   Reply With Quote
Old 04-22-2010, 03:44 PM   #30
Granatelli
Drives: 2SS Victory Red
And what kind of power did your car dyno at?
Granatelli is offline   Reply With Quote
Old 04-22-2010, 08:18 PM   #31
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
1/4 depends on a lot of things from how well you drive, DA, track surface ect. Take a look at the official track times and look at the mods for a feel.
Traction control on mine after the work is kida like hitting the rev limiter, when you break loose it will pull power. With it off you can about spin as much as you want, depending on your tires and road surface, you really have to drive it.
Mine is M6 so I cant help you on the Auto tranny side.
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 04-23-2010, 01:49 AM   #32
JohnInSoCal
500 at the wheels, only had 800 miles on it at the time car is running great with 4000 miles on it now, probably a little stronger since it's more broken in now.
Old 04-23-2010, 03:24 AM   #33
Granatelli
OK -I will dyno your car for free. 8lb and headers. right? I am only 6 miles from Magnuson
Old 04-23-2010, 11:45 AM   #34
Jeremy@HOB
Jeremy@HOB's Avatar
Drives: 2010 Camaro SS
The only L99 car that we've done we put a ProCharger D-1SC with Kooks Long Tubes, High Flow Cats, and Magnaflow Catback. That car at 8lbs made 524rwhp and 518rwtq. Majority of the Gen5's that we've done have been M6 LS3 cars.
Jeremy@HOB is offline   Reply With Quote
Old 04-23-2010, 12:08 PM   #35
Granatelli
How much power did this car make N/A? What kind of dyno was it tested on
My guess (XYZ) I would be interested if you really know
Old 04-23-2010, 01:34 PM   #36
JohnInSoCal
oxnard ? I live in corona too far. 8lbs, kooks headers+exhaust and rotofab CAI, custom tune. Why do you want to dyno my car ? Not believing 500 HP ? Pretty much in line with other cars with same mods.
Old 04-23-2010, 04:43 PM   #37
Granatelli
I ran the numbers and I guess will all the other mods it can do it. I more than anything want to see how my dyno stacks up. We are a bonded dyno and must calibrate every 30 days to keep the certificate. We are also the Mustang Dynamometer dyno rep for So Cal. All too often we dyno a car at 440 and the customer says it can't be because they just made 500 at XYZ dyno. I look like the bad guy because the other dyno guy fudged his numbers
like the dragon guy that claimed a 250hp increase at 5psi with no intercooler. It can't be done. 320 RWHP can't turn into 570 at 5 psi RWHP - Sorry
This is no reflection at any one person - But as we release our Twin Turbo kit for the 2010 Camaro - i want to compare real numbers. We are will to sell a few of the first kits at a small discount to get them in teh hands of others - we know word of mouth will travel faster then any advert or article
Old 04-24-2010, 12:02 PM   #38
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
Magnuson TSV2300 vs Edelbrock E-Force
Hello,
Thank you all again !! More questions of course.
It seems the Magnuson TVS2300 is the most popular and the Edelbrock E-Force is too new for popularity at this point. What are the major differences between the two?
I was reading in the forum that the Edelbrock E-Force starts to build back pressure in its self after 5000 RPMs which would lead me to believe there is no more potential than what it is. That being said, it seems the maggie has more boost potential into the motor, but would be irrelivant for my goals. However you know that people always wany more and more HP.
The Maggie has a jack shaft, right? That is the side shaft the goes to the belt in the back, right?? The Edelbrock E-Force does not. Are there problems with jack shafts ?
Also I read the Edelbrock E-Force has a boost bypass valve to keep the pressure low during normal driving. I guess that would be like a kind of waste gate. They say it's better for fuel milage. Is it? And is it better for logevity?
Does the Maggie have a boost bypass ?? or is it pressure all the time ?
Whats the fuel milage on the maggie (6psi) and the Edelbrock E-Force (6psi)??
What about the stock torque converter? Can it handle it ??
Thank you.
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 04-24-2010, 05:38 PM   #39
Jeremy@HOB
Jeremy@HOB's Avatar
If I remember correctly that car made 335 stock. I'd have to confirm on Monday. We have a DynoCom dyno.
Old 04-24-2010, 07:00 PM   #40
L99
L99's Avatar
Drives: B On B L99/SS2 Ground effects
Love the intake pipe!
GMS air intake with Maggie TVS2300
L99 is offline   Reply With Quote
Old 04-26-2010, 02:10 PM   #41
Granatelli
$299.00
Old 04-26-2010, 05:42 PM   #42
racer778
Camaro Sold
racer778's Avatar
Drives: 2010 camaro 2SS/RS
Wow I'd like to get mine dynoed and tuned for Free. my other dyno numbers are posted on the thread Maggie install (easy). Taking it to the track Saturday. Granatelli do you carry smaller pulleys as well? BB I will post my numbers from the track after this weekend for you. Any other questions let me know. I am not a professional tuner installer by any means. Air Force
racer778 is offline   Reply With Quote
Opinions please - GMPP and dealer sheild protection options? Litd 5th Gen Camaro SS LS LT General Discussions 3 12-22-2009 08:47 PM
Suspension Work in the morning. I have few options need opinions 55Designs Suspension / Brakes / Chassis 1 10-30-2009 05:59 PM
OPINIONS NEEDED on options! Jackied 5th Gen Camaro SS LS LT General Discussions 29 10-13-2009 08:20 PM
Narrowed down my color options, would like some opinions! Ant 5th Gen Camaro SS LS LT General Discussions 13 01-21-2009 09:38 PM
