ADM PERFORMANCE
Old 04-18-2010, 01:30 PM   #1
alex33x
Drives: 2013 Camaro ZL1
Hotchkis Max Brace and Exhaust issues.
So I installed my Hotchkis max brace and I been hearing this knocking sound, from underneath which I think is the exhaust pipes hitting the middle mpart of the hotchkis. Anyone else had this issue?
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 04-18-2010, 01:40 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
This is a known issue when installing a aftermarket exhaust with the stock piece but haven't heard of it with a aftermarket chassis brace. It doesn't happen to everyone but it does for some. From the pics of the Hotchkis brace, it looks like you could put a couple washers between the tunnel brace and the side pieces to give you some extra room.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 04-18-2010, 03:03 PM   #3
grocerygetter
instigator
grocerygetter's Avatar
that's why I modified my own. LOL...I didn't want to pay someone for their brace and then have to make it work anyway.
Cheap easy fix...go to Lowe's and get some 1" wide flat steel and drill holes to match the bolt pattern. Put some Rustoleum paint on it...few coats...let it dry and bolt it back up. That long flat surface underneath the brace will keep everything functioning as it should. Take one of the bolts in with you...Lowe's has those in stock in stainless in longer lengths.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 04-20-2010, 11:36 AM   #4
alex33x
Iguess I'll put it up in a ramp and see what I can do about it.
Old 04-23-2010, 01:50 PM   #5
Hotchkis
Drives: 1st through 5th gen Camaros
We have tested our brace with the stock exhaust as well as three major aftermarket brands, however it would be very difficult to test all the exhaust systems on the market. Please take some pics and PM them to us and we'll see what we can do to help.
Hotchkis is offline   Reply With Quote
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
Exhaust coupling and tunnel brace torque specs???? Jeffro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 04-09-2010 02:41 PM
Hotchkis Chasis Brace or Springs? caverman Suspension / Brakes / Chassis 12 03-24-2010 11:53 AM
LMPerformance, Hotchkis 2010 Camaro Chassis Max Brace LMPerformance V8 Bolt-Ons & Tunes 0 01-05-2010 12:17 PM
