Old 04-19-2010, 04:19 PM   #1
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
LSR Performance Billet Toe Links now available!!
Billet rear toe link for Camaro SS and V6 models. Crafted from billet 6061 aluminum for strength and beauty. These replace the factory, stamped steel, toe links and provide decreased unsprung weight and increased stiffness to improve suspension response.
They also include significantly firmer bushings to reduce suspension compliance, and prevent excessive toe deflection upon cornering, braking, and acceleration. Designed using Finite Element Analysis to optimize strength to weight. Easy to install and require no permanent modifications to the car.
Product Highlights
* 40 percent less weight than the stock link. 1.2 vs. 2.0 lbs
* Reduced toe deflection in cornering, acceleration, and braking
* Slots machined into part to retain ABS wire clip location and function
* Lifetime warranty on links, one year warranty on bushings
* Does not require alignment following installation
Meister@Torq is offline   Reply With Quote
Old 04-19-2010, 08:37 PM   #2
55Designs
Drives: 2010
Look nice but do you think these have more or equal torsional strength than steel?
55Designs is offline   Reply With Quote
Old 04-22-2010, 07:01 AM   #3
2quick
Drives: none
Sorry it took so long to get ananswer to this but, this is what the engineers said.
The toe link is not really a torsional member. It’s mainly loaded in tension/compression. As the suspension compresses and rebounds the knuckle does rotate a little due to the angling of the virtual lower control arm and that rotation does impart a small amount of torsion into the arm but the amount of rotation is small and, thus, so is the induced torsion. If it were loaded in torsion by any significant amount, it would be round like driveshafts and axles.
The smallest cross-section of the billet links is double what the smallest cross-section of the OEM part is and our material strength approaches that of typical stamping steels. Similar strength combined with more cross-sectional area means a stronger part.
I think this answers your questions. If you have anymore ill be glad to try and get a nswer to them. Thanks for asking.
2quick is offline   Reply With Quote
Old 04-30-2010, 08:50 AM   #4
2quick
Drives: none
Hope that this was helpful.
Old 04-30-2010, 10:20 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Those are purdy
Old 04-30-2010, 10:58 AM   #6
2quick
Drives: none
Thanks radz
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
No More GM Performance Division... leviticus88 General Automotive + Other Cars Discussion 1 02-19-2009 04:04 PM
Hardcore racers rejoice!! GM Performance Parts to offer new Camaro body in white radz28 5th Gen Camaro SS LS LT General Discussions 23 12-22-2008 10:57 AM
