| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
![]() Drives: black 2010 2ss/rs camaro Join Date: Oct 2009
Our Twin Turbo Kit
Hey every one we are going to start work on a twin turbo set up. We want to see what turbo you guys would rather use, the Garrett GT37r or Turbonetics Hurricane Ashly CBB. With these turbos we will run duel 50mm Synchronic Wastegate and a Synchronic BOV. We ourselves are looking to put over 800 whp with this kit and a few other support mods. We are going over ways to make a top of the line kit and keep cost low. All you turbo junkies post what you would like to see in this kit!
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: a Jet :-) Join Date: May 2009
Looking forward to more info! |
Both are very close in price both are ball bearing both are great turbos the GT37r is a little more in price. This is going to be a very fun kit! We are look through everything to make a very good price kit that is good for up to 1000 HP! And with this ket just to let you guys kno you will not need a boost controller the wastegates have controller between 5 and 20 psi i dont know who would be going over 20 psi.
#4 | |
Yes im going to take a look into that. That one is really long just going over the pipping in my head to make everything fit with the most ease i dont want to make a hard install.
#6 | |
Good luck |
#7 |
We are looking for a intercooler that will not be covered like in other kits we might use a GT3582r instead of the GT3788r Less lag and can still get 1000 HP with them. Z_Rocks What do you think of the GT35R?
#8 | |
Another thing to consider (and I haven't really investigated the space) is the following issue which also might affect your decision on the turbo. Let's say looking at the new BMW turbo series, they're bringing the turbo very close to the engine to a) minimize the latency b) to get the most charged energy released from the engine. Porsche does the same thing. On the Vettes, APS and TTi did the same by connecting the turbos directly to the manifold, rather than with the other kits, placing them under the car. This is something that I'd also take into consideration, if there is room for the turbos to be on the side and connected to the (custom) manifold. This will also bring the turbos closer to the front of the car for shorter air intake and shorter connection to the intercooler. I always liked the APS (Z06 model) design and had a great response. When I look at some of the other kits and if you add up the length of all the pluming, there is a lot of distance that the air needs to travel before getting to the engine. If I were you, I'd look at the design out of the box rather than the conventional design of putting two turbos under the car with lots of tubes running... Otherwise you're not bringing anything unique to the table. Just my two cents and I don't mean any disrespect to other kits or yours. Here we're trying to collaborate and build something better. I think once you figure out the positioning and overall air travel distance, then you can figure out the Turbos that would satisfy that need. That's how I'd approach it! ..Ben |
#9 |
Yes we are trying to do something like the aps style the less Tubeing the better! I was looking over the APS Zo6 and thats what we want but better.The GT35r Will Fit and can handle 1200 FWHP. My Biggest problem is finding the right intercooler we might have to go with a full customs intercooler. We are trying to have it when you order the kit you can pick from 3 boost settings and we can send a tune for that boost setting and set the wastegates for you. The more you tell us what you want the better. Thanks for your help Z_Rocks We are looking into everything you are talking about to make the best Kit out there!
#10 | |
#11 |
Thanks Z We want to do this kit right i have looked all over for a good intercooler that will fit right and handle the hp if you see any let me know.
#12 | |
![]() ![]() Drives: C63 P31 Join Date: Feb 2010
I'm excited to see this kit. |
#13 |
The closest i have found so far is this one
![]() The core it self is only 6" tall but the end tanks are 3 inch so overall its 12" the flow rate is great on this with 1492 CFM and at max flow only 1.5 psi dropim trying to find away to make it fit right. I could of made a short long one but with it that long there would of been a psi drop of over 8! so we can not do it like that. From the front cross bar to the bottom of the front bumper is about 7 1/2" and 1 1/2" of the core might be covered but if its set back as far as it can the whole core should still get air! Let me know what you guys think. |
#14 | |
Ok Bill, are you saying you want to put this behind the bumper or below or above? I didn't get that clearly from you. perhaps you can do a drawing and post it. But the IC looks very good. |
#15 |
Part of it would be behind most of it would be below the cross mount trying to keep a good gap between the cross mount and the IC there would still be air flow behind the cross mount. There is very little space with this car im not worried about blocking the radiator the IC does not stop air flow to it. or i can set it up vertically where most of it sticks out top same core but both inlet and outlet or on the same side.
#16 | |
![]() Drives: 2010 LSX shootout champions Join Date: Apr 2010
#17 | |
![]() Now let me ask you this, and your answer "Could" answer your own question. Would you like to have a twin set of girls on your both sides or would you rather to have a single big & hot one on the top of you...? (we're talking turbos)
#18 |
Yes with the new technology out there big turbos spool much faster then in the past and you get i have to say have one of the best if not the best single turbo kit out there. But twins are still quicker to spool and its a differnt drive then a single. with twin keeping them low keep down temp lower center of gravity and gives a very clean look. And so far as we see we will be able to make this kit and be around the price of a single.
#19 |
And what Z said haha!!
#20 | |
![]() Drives: corvette Join Date: Oct 2009
We love the twin's for a street car, if done on paper FIRST then built ...well, the end result is crazy.... ![]() hey Z if the high and low pressure zones in front fascia of a car with the hood down work well (the camaro is great)your intercooler will not need to be 100% exposed in the vision but LOOKS COOL...the most important thing Is the righ size for your application (big or small) and efficiency !....$10,000 a day wind tunnel is the next best thing to sliced bread!!! Last edited by Will@Apf; 04-21-2010 at 04:03 PM. |
#21 | ||
I think you two guys (Will & Bill) should put your heads together with all your experience and knowledge. Best wishes! |
#22 | |
#23 | |
#24 |
Yea lol we were thinking of merging the two pipes from the turbos and having the piping come up the right side trying to keep it simple with as little piping as posible. Will, all your input is welcomed in no mean we are the turbo experts but we just want to be able to put out a kit thats well built.
#25 |
Okay i think i found what we are going to do was going ovwer this all day we are going to use a 2 in 1 out like this one.
![]() The 2 in we are going to have faceing down not on the side and we are looking into tilting the radiator back almost like vararam and having the intercooler piping go over the radiator. the piping can be very straght forward. with the set up like this it will be a very clean set up and wont realy have to move things around other then the radiator. the top opening is bigger then the bottom aswell. Very close to the vett aps set up. |
| Thread Tools | |
| 2010 Nickey Super Camaro Twin Turbo edition. | NickeyChicago | 5th Gen Camaro SS LS LT General Discussions | 134 | 07-03-2010 08:29 PM |
| STS Remote Mount Turbo Kit for V6 | ZNOLMT | Forced Induction - V6 | 102 | 06-09-2010 12:18 PM |
| STS turbo kit for us 6'rs.... | devildoc | Forced Induction - V6 | 31 | 03-06-2010 01:22 AM |
