JUICEDMOTORSPORTS
Old 10-08-2008, 06:57 PM   #1
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Wideband a/f question
So one of the first things im going to do is get a wide band a/f guage in this sucker..
My question is where would be the optimal place for the sensor.. I am assuming as far down the headers as possible but before the cats?
I would share my list of things.. but my car is going to surprise quite a few after i get it... I am thinking outside the box.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 10-08-2008, 08:10 PM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
well knowing what is involved in the application would definately help....
headpunter is offline   Reply With Quote
Old 10-08-2008, 08:22 PM   #3
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
We want to hear your box-annihilating ideas before we give any recommendations.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 10-09-2008, 09:45 AM   #4
The_Stache
SoCal Race Team #13
The_Stache's Avatar
For arguments sake lets just say I am going to need a wideband a/f guage... where on a normal exhaust would you mount the wideband o2 sensor?
I have been told now that wide band o2's need to be heated or as close to the collector as possible (to heat them). I didn't know that.. SOOO on to more research..
Old 10-09-2008, 09:46 AM   #5
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Custom setup, will be using a pressurized charge.. that's all I will say.
Old 10-09-2008, 12:20 PM   #6
Speedy1975
FASTER!
Speedy1975's Avatar
Drives: Challenger Hellcat, 2SS Camaro
I have a LC-1 wide band in my 4Runner. It was mounted in the down pipe before the cat. It's elf heating as all oxygen sensors are AFAIK.
The question on the Camaro would be what pipe to put it in so that it's sniffing both banks of cylinders since it's dual exhaust. If the H pip is before the cats, that'd be a good spot. If not then IDK.
-Speedy
2016 Go Mango Challenger Hellcat (PB E.T. in 1/4 Mile 10.51 @131.36)
2016 Hyper Blue 2SS Camaro (PB E.T. in 1/4 Mile 12.093 @114.43MPH bone stock)
Speedy1975 is offline   Reply With Quote
Old 10-09-2008, 02:37 PM   #7
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
generally, there is a wideband bung on one side or the other, but not both sides of an exhaust system... it is accepted that what is happening on one side is happening on the other side, since most stock, or close to stock, injection systems do not have per cylinder tuning... so if bank 1 is running rich, its likely that bank 2 is running rich, as well.
putting the wideband in a location that is before the cats is the key here... you put it behind the cats, you get a false reading... alot of exhaust setups that I've seen with a custom hole for the wideband sensor have the bung on the passenger side, but I've seen some on the driver's side as well as some on the collector before the I pipe... but that's not going to work on a car with true duals, so its really just easier to use a location close to the collector of the long tubes, if you have them, and before the cats, if you have those, too.
and most new widebands are set up to be self heating... some of the older ones needed to be heated, so proximity to the headers was a must.
got tequila?
SilverTurtle is offline   Reply With Quote
Old 10-09-2008, 05:05 PM   #8
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
mount before the cat, after the y-pipe... or if you are running true duals with an x-pipe, mount it in the x-pipe.
I piss excellence
and fart awesomeness
Old 10-09-2008, 07:16 PM   #9
Chocolate Apocalypse
Full Fledged Member
Chocolate Apocalypse's Avatar
Drives: '00-Z28
Why not just get a PLX setup and use the wideband sensor in place off the stock narrowband piece?
'98 Dodge Avenger - Beater
'72 Cutlass - Toy
'00 Z28 - REDRUM - 12.312@111.62 DA:2500' blowing through TC, new TC installed, 11s here I come
Chocolate Apocalypse is offline   Reply With Quote
Old 10-09-2008, 07:30 PM   #10
The_Stache
SoCal Race Team #13
The_Stache's Avatar
from what i under stand the reading from a wideband is not compatible with stock ecu's therefore you end up throwing codes/going into limp mode.
Thanks Silver this was exactly what i have been looking for. (Same for you camarospike) I knew I could count on you guys.
Old 10-09-2008, 08:04 PM   #11
CamaroSpike23
Truth Enforcer
thats what we're here for.
i was going to make the comment that the 4th gens got lucky with the aftermarket ORY's as most came with a bung already installed after the collector for the wideband.
I piss excellence
Old 10-09-2008, 08:14 PM   #12
AirGoya
AirGoya's Avatar
Drives: 2012 Camaro SS
I know what an O2 sensor is. But whats a a/f sensor?
-Tim
AirGoya is offline   Reply With Quote
Old 10-09-2008, 08:33 PM   #13
Full Fledged Member
Drives: '00-Z28
Thats why you get the PLX wideband.....
http://www.plxdevices.com/AppNotes/PLXApp004.pdf
'72 Cutlass - Toy
Old 10-09-2008, 09:32 PM   #14
CamaroSpike23
Truth Enforcer
there's narrow band and wide band o2 sensors, they are both a/f sensors
narrow band, like nearly all cars have are normally referred as just "o2's"
and they either read rich or lean, hence the term narrow band
a wide band o2 sensor is comonnly called a "wideband" or "air/fuel sensor" it reads more in depth and allows for more precise tuning of the air fuel ratio.
bout as simple as I can make it.
I piss excellence
IRS question 454lsxss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2008 10:06 PM
question on engines... Shadow-phoenix General Automotive + Other Cars Discussion 0 04-23-2008 05:45 PM
Noob Camaro Question goose7919 5th Gen Camaro SS LS LT General Discussions 13 09-23-2007 09:26 PM
Gotta question bout my z28 lm1power Off-topic Discussions 1 09-15-2006 03:58 PM
