Rick@Livernois
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 04-21-2010, 08:47 AM   #1
JusticePete
Needs Lowering
JusticePete's Avatar
Drives: Pedders USA Camaro Justice
Exclamation GM Manufacturing Change for the Camaro -- by Pedders USA, LLC
GM has replaced P/N 13219091 (black rubber in the pictures) with P/N 20859337 beige foam in the pictures.
The new GM bit is an excellent design. Having said that, both are discarded when installing Pedders Xa coilovers and the change in the cabin noise level is imperceptible to most Camaro owners. Even in complete OE trim with nothing but Xa coilovers the noise level change is so small no one has ever made mention of it. We think this change was driven to use the robust Camaro strut mount with other GM platforms. The Camaro strut mount and new part is shared with the Buick Lacrosse. We found this out back in December when we ordered spare 13219091 (rubber rings) and were shipped 20859337. We cross referenced the 20859337 and found it fit the new Buick. We found the first at a dealership yesterday April 21, 2009.
The new GM part is roughly 5mm larger in diameter and that does mean that Pedders 220032 front lowering coil upper eye will NOT fit the new mount. Using the Xa coilover billet mount to demonstrate the difference gives you a good idea of how much the new GM part changes the upper coil eye requirements.
Pedders will make the required changes to our 220032 which will probably result in a new part number. We will keep you posted
What this means to a Camaro owner is that if you have recently taken delivery of your Camaro (within the last thirty days or less) you should inspect the coil to strut mount before ordering lowering coils. If you see a black rubber part between the OE coil and strut mount you can use Pedders 220032 front lowering coil. If you see a beige / off white ring in this area you will need a revised lowering coil with an upper eye roughly 5mm larger in diameter. This was an early R & D picture when Pedders was testing with and without the rubber ring installed. You can see the rubber between the billet aluminum and OE strut mount.
If you are a Camaro owner with no intention of lowering your Camaro, go drive your car and enjoy it. If you are a Camaro owner who plans on lowering, Pedders Xa coilovers will fit both the rubber and urethane style mounts because we don't use them If you have the new urethane mounts, a revised solution is on the way. Maybe the best part of this is that the new Buick LaCrosse has a bit of Camaro in it which is only fair because my Camaro has a bit of Cadillac in it.
Old 04-21-2010, 12:31 PM   #2
RichJ.
Shop Owner
Drives: 1 ton silverado
Thanks Pete for posting this info.
RichJ. is offline   Reply With Quote
Old 04-21-2010, 12:51 PM   #3
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Good information
mike
dms
Rob Anderson - Business Development
rob@peddersusa.com
Info@PeddersUSA.com is offline   Reply With Quote
Old 04-21-2010, 01:56 PM   #4
Xanthos
Almost-Original Postwhore
Xanthos's Avatar
Drives: Stick
Good to know. Thanks!
- X
Xanthos is offline   Reply With Quote
Old 04-21-2010, 02:07 PM   #5
OUTATIME
OUTATIME's Avatar
Drives: 2010 IOM 2SS/RS
I wonder if this is at all related to the "clunking" suspension noises people have been talking about?
OUTATIME is offline   Reply With Quote
Old 04-21-2010, 02:22 PM   #6
JusticePete
Needs Lowering
We do install the Xa coilovers WITHOUT any upper insulator going direct from the billet aluminum ring to the OE strut mount. There is no clunk from this style of installation. If all the OE parts are in place and functioning, it should not make any noise.
Old 04-21-2010, 02:45 PM   #7
Info@PeddersUSA.com
I have already received inquiries on how to better identify the 2 insulators on the car. So here are some more pictures to assist.
With a flash light, and the Camaro in the air you should be able to tell easily. The picture below shows what the front strut looks like with the wheels off
The upper part of the strut goes into what I would call a bucket and this is where you can see the upper insulator. This is what it looks like with a Pedders Xa coil over installed:
Here is what an entire front strut looks like out of the Camaro. You can see the top piece is the strut mount assembly and the OE insulators are between the strut mount and the coil itself. It will be seriously easy to spot the new style in the car because of the color of the new style insulator being white or beige in color
This picture shows a closeup of the front Camaro strut mount, insulator and coil. The picture shows the black insulator that is between the coil and the strut mount.
if you have any questions, just ask
thanks
mike
dms
rob@peddersusa.com
Old 04-21-2010, 03:03 PM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Interesting... Thanks for the heads-up.
Old 04-21-2010, 08:44 PM   #9
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
since my car is being built this week should it have the new bushing
camaro4mybday is offline   Reply With Quote
Old 04-21-2010, 09:04 PM   #10
JusticePete
Needs Lowering
Sounds right to me.
Old 04-21-2010, 09:31 PM   #11
sting808
Drives: 4 wheels
Will the new mount be backwards compatible with the black rubber version? (too much play/slop?)
If so, can I get the new version? My car was built in Nov 09, but I'd like the option to use universal GM parts since the black rubber version may be discontinued. My XA Street Extreme II Plus system is not installed since still waiting on swaybarB. I'm hoping to schedule installation in late June since I won't be available from end of May to mid-June.
Please advise.
sting808 is offline   Reply With Quote
Old 04-21-2010, 09:34 PM   #12
JusticePete
Needs Lowering
Please advise.
No worries mate. Your Xa system will NOT use either the rubber or urethane insulators so you have no worries. We want you to discard the insulator with the Xa or new Supercar coilovers and use the billet aluminum mount directly to the FRP bearing inside the strut mount.
camaro, coils, lowering springs, pedders, suspension
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 451 Today 05:37 PM
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
