autoguy
4th Generation Camaros 1993-2002
Old 10-09-2008, 08:08 PM   #1
DOOREV800
DOOREV800's Avatar
Drives: 2010 Camaro SS LS3
Question DTC'S
Anyone have or can guide me to some schematics. I have the following codes:
26- Evap Purge Circuit
27-Egr Sol. Circuit
77-Fan 1 Circuit
I have a 95 z28. I did all the basic checks-Fuses,connectors,ect. Something tells me they are all related. When I clear the codes they all come back together right away. Need to start tracing the wires.Thanks!
DOOREV800 is offline   Reply With Quote
Old 10-09-2008, 08:39 PM   #2
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
clean out your evap purge solenoid
bottom left picture in this diagram. take a small shopvac and pull the purge lines and suck the crap out of them. they get clogged over time and mess stuff up
http://shbox.com/1/evap_system.jpg
http://shbox.com/1/evap_sol.jpg
your EGR valve is probably worn.
fire up the motor, once its warmed up, reach behind the intake to the EGR valve and depress the valve inside the EGR valve, if the motor rpm/sound doesnt change at all, then you need to replace the valve.
also check the vacuum line for the egr solenoid as well
http://shbox.com/1/opti_vacuum_conn.jpg
http://shbox.com/1/egr1.jpg
for the fan, replace the relay in the fuse box under the hood.
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 10-09-2008, 08:46 PM   #3
DOOREV800
DOOREV800's Avatar
I will give it a try. Thanks!
Old 10-09-2008, 09:00 PM   #4
CamaroSpike23
The Jalopy Jedi
sure thing.
thats what im here for.
and if you want some reading material about your car and various things LT1 wise
www.shbox.com
www.zmydust.com
www.projectlt10.com
read it.... know it.... live it.... love it.... read it again...lol
I piss excellence
Old 10-11-2008, 03:39 PM   #5
CamaroSpike23
The Jalopy Jedi
any updates?
I piss excellence
Old 11-18-2008, 04:23 PM   #6
DarrenJ
DarrenJ's Avatar
Drives: '67 Camaro ZZ4 & 2010 IOM 2SS
You guys are way too cool! Never seen so many willing to assist with no strings attached!!!
If I can ever be of assistance with a 1st gen, let me know.
I'm not trolling the 4th gen forum, I have a 99 Z-28 also. Posted photos of my '67 ove in the 1st gen area.
I have a 2SS/RS orange, orange int, hurst ordered.
DarrenJ is offline   Reply With Quote
