Old 04-22-2010, 06:20 PM   #1
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
FRONT RADIUS ROD BUSH UPGRADE FROM EASY DIYer TO FULL RACE SETUP
The Zeta II platform on the Camaro is outstanding. For those that want to enhance the front performance, we offer several upgrades to improving the performance of the front radius rod bushing.
EP6578 PEDDERS FRONT SNUBBERS FOR OE RADIUS ROD
This kit is seriously easy to install and requires very little dissassembly. It is the perfect job for a DIYer.
The best front radius rod upgrade involves pressing out the OE subframe bushing and pressing in our Pedders complete subframe bushing kit
The above picture shows the Pedders EP6577 properly installed and properly lubed
THIS PICTURE SHOWS YOU THE OE SNUBBER INSTALLED
THIS PICTURE SHOWS YOU THE OE SNUBBER PARTIALLY REMOVED
THIS PICTURE SHOWS YOU THE OE SNUBBER REMOVED
AS A NOTE, THE OE SNUBBER POPS OFF WITH A SCREWDRIVER!
THIS PICTURE SHOWS THE PEDDERS AND OE SNUBBERS
THIS PICTURE SHOWS THE PEDDERS SNUBBER INSTALLED
Again, the snubber offers the OE front radius rod bushing a huge amount of support and is a perfect job for the DIYer. A complete install manual will be available for this very soon.
If you have any question, just ask
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 05-03-2010, 09:32 PM   #2
Info@PeddersUSA.com
I will be doing a training manual install on these next week if anyone wantt so see the process.
thanks
mike
dms
Old 08-25-2013, 11:39 AM   #3
ss/rs-matt
ss/rs-matt's Avatar
Drives: 2011 2SS/RS LS3
What are the benefits of this upgrade and how do I decide which one will work best for me?
"Want to know whats cooler than your murdered out Honda Civic? ...Any Audi." Daniel Tosh
ss/rs-matt is offline   Reply With Quote
Old 08-25-2013, 08:32 PM   #4
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
the benefits are a tighter steering feel and more control in the front wheels
there are 4 levels of bushings the standard inserts, the hd inserts, the full bushing replacement and hd bushing replacement..
deciding on which is right for you i feel depends on several factors.
1 budget
2 use of your car
3 the want factor
the standard insert is easily the cheapest both part and labor as it goes up the levels the full bushings are more expensive and requires specialized tools to remove them such as a press
depending on how you drive. if you just tool around the and casually drive your camaro the standard insert will be a good upgrade
adding some power mods will have you driving the car harder and /or light track use hd inserts or full replacements are where you want to be
if you are on the track often then the hd inserts are right for you
camaro4mybday is offline   Reply With Quote
Old 08-25-2013, 10:12 PM   #5
ss/rs-matt
ss/rs-matt's Avatar
Thank you….I think the inserts will be a good upgrade for me.
Subframe Bush Upgrades. From Simple DIYer to Full Race Capable Info@PeddersUSA.com Suspension / Brakes / Chassis 16 05-03-2010 09:29 PM
New to Suspension (look over list please) Brokenlizrd Suspension / Brakes / Chassis 19 04-23-2010 11:31 PM
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
BUDWEISER SHOOTOUT LINE UP CamaroScotty General Automotive + Other Cars Discussion 22 02-07-2009 07:03 PM
Payment and Shipping info for 1st Edition Camaro5 shirts TAG UR IT Camaro5 Store Merchandise 154 10-18-2008 03:00 AM
