Billet Custom
Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions.
Old 10-10-2008, 08:40 AM   #1
odie23
Drives: Jeep
Warranty Disclosure of Non-GM Products
For those interested, found on Solstice site.
DISCLOSURE OF NON-GM PRODUCTS
Part 1 - Consumer and selling dealership acknowledge that this disclosure of information is required in any
situation where the consumer, if purchasing or leasing and the GM dealer is either selling or leasing to the
customer or the customer has purchased or had installed:
• A modified motor vehicle - a new or used motor vehicle which has been modified from its
original build by General Motors by any upfitter, servicing entity/business or dealer regardless of the
extent of the modification
• Any accessory, product or part not produced, marketed or warranted by General Motors
• Any Service Contract, extended repair policy not specifically provided by General Motors
The consumer acknowledges that General Motors will not be responsible for any vehicle modifications not
developed by General Motors, for any non-GM accessories installed on the vehicle nor will General
Motors warranty or cover damages these modifications or accessories cause to other parts or systems of the
vehicle. The consumer also acknowledges that in the case of non-GM Service Contracts or extended
service policies sold by the dealer that those contract(s) may or may not be accepted by other GM
dealerships and that GM will in no way be responsible for such non-GM contracts.
Consumer (buyer/lessee) acknowledges that this vehicle is being disclosed to the owner for the following
reasons and that these disclosures are being made at the time of sale of the motor vehicle, or disclosed at
the time of purchase of the modification/non-GM accessory/non-GM Service contract.
• VEHICLE MODIFICATION - This vehicle has been modified from its original build as
produced by General Motors through a vehicle up fitter and may have components on the
vehicle that will not be covered under the GM New Vehicle Limited Warranty due to those
modifications. It is the upfitter’s responsibility to provide any applicable warranty on these
components. (Check all that apply per up fitter invoice)
UP FITTER COMPANY NAME __________________________________________________ _____________________________
__ Exterior Paint
__ Exterior Trim Pieces
__ Tow Equipment
__Exterior Decals
__Engine Modifications
__ Vehicle Lift Kit
__ Interior Trim Pieces __ Interior Gauge Facings __ Tires/Wheels
__ Suspension Modifications __ Audio/Visual Packages
__ Vehicle Calibrations __ Exhaust System Components
__Exterior/Interior Badging __ Step Bars ___Grille Bars
__ Under hood Items ___Exterior/Interior Lighting & Switches
__ Aftermarket Installed Component wiring __ Shocks/Struts
Part II - Non-GM Accessories sold or installed prior to/at time of/following original vehicle sale
(description of item and manufacturer name)
Item 1 - ______________________________________ _____________________
Item 2 - ______________________________________ _____________________
Item 3 - ______________________________________ _____________________
Item 4 - ______________________________________ _____________________
Item 5 - _______________________________________ _____________________
General Motors Service Policies and Procedures
Dated
1/07
Part III - Non-GM Service Contract or Service Agreement
Name of Provider _________________________________
Contract # _______________________________________
Part IV - Notice to Buyer on Vehicle Modifications
Modifications to your vehicle including but not limited to: the installation of wheel/tire combinations not
certified by General Motors or for which a GM provided vehicle calibration is not available directly from
General Motors may have an adverse affect on engine operation, vehicle performance, vehicle operation,
vehicle stopping distances, proper operation of the ABS braking systems, transmission operation and fuel
mileage. Vehicle operational conditions or failures caused by non-GM certified (see GM tire/wheel label)
wheel & tire combination are not covered under the terms of the GM New Vehicle Limited Warranty.
Please note that Duramax Diesel powered vehicles equipped with the Allison automatic transmission are
limited to only to the P245/75/R16 GM factory build wheel & tire combination.
Addition of aftermarket power enhancements including but not limited to introduced calibrations not
provided by General Motors are not condoned by General Motors and may result in engine, transmission,
driveline, rear or front differential, transfer case, fuel system or emission/performance warranty coverage
being voided.
Installation of nitrous oxide induction, propane induction, non-GM engineered/supplied superchargers,
blowers, turbo chargers, after coolers, engine headers, camshafts, rocker arms, air induction systems, non-
GM approved fuel injectors, over-drive or under-drive accessory drive systems, aftermarket drive pulleys
or harmonic balancers, flywheel, clutch assemblies, or non-GM certified engine or transmission
calibrations may result in engine, transmission, driveline, rear or front differential, driveline and/or transfer
case, fuel system or emission warranty coverage on the affected components being voided or repairs declined
under the GM New Vehicle Limited warranty and subsequent performance and/or emission warranties.
Installation of aftermarket lighting systems, audio or video systems or alarm systems which cause
interference with or failure of GM electrical systems or vehicle components are not covered under the
Vehicle VIN (17 digits) __________________________________________________
Sales or Service Representative Signature ____________________________________
Customer Signature __________________________________________________ ___
Customer Printed Name _________________________________________________
Date ___________________________
Dated
1/07
odie23 is offline   Reply With Quote
GM's Super Bowl ad will highlight 100,000-mile warranty KILLER74Z28 General Automotive + Other Cars Discussion 8 05-01-2009 12:14 AM
Toyota, Where's the Warranty? KILLER74Z28 General Automotive + Other Cars Discussion 11 07-09-2008 09:33 PM
Lifetime Powertrain Waranty....from Chrysler?!!? Mr. Wyndham General Automotive + Other Cars Discussion 22 08-16-2007 04:16 PM
GM Adds Used-Car Powertrain Warranty KILLER74Z28 General Automotive + Other Cars Discussion 3 02-06-2007 07:56 AM
