HeadlightArmor
Old 04-24-2010, 12:41 PM   #1
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
Quick question on tvs pulleys
Stock diameter crank what psi would be seen on a stock ls3 with a 3.2" pulley and a 3.4" pulley. I can't seem to find that chart anywhere that gave that info out. I know i've seen it in the past.
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 04-24-2010, 01:11 PM   #2
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I think the 3.4 will be around 10psi and the 3.2 12psi but not 100 percent. Just what i remember.
MODS:
Old 04-24-2010, 01:13 PM   #3
boostedyards86
anyone able to verify this?
Old 04-24-2010, 01:31 PM   #4
10aSSee D
10aSSee D's Avatar
The reason i say this is because i ordered the 3.6 and it is the 8psi pulley and i think the smaller you go it goes up 2psi.
MODS:
Old 04-24-2010, 01:52 PM   #5
FloMoCamaro
FloMoCamaro's Avatar
Drives: 2010 Camaro SS
The boost will differ a little from car to car. I have the 3.6 and I pull 7.5 lbs. on the street. The 2 lbs. per pulley size sounds about right.
FloMoCamaro is offline   Reply With Quote
Old 04-24-2010, 03:01 PM   #6
jrpxxii
jrpxxii's Avatar
This should answer all your questions.
The stock boost for any Magnacharger TVS 2300 Supercharger Kit installed upon any 2010 Camaro 6.2L V8 with a 3.80" Magnacharger Pulley installed on it is only 6 psi at wide open throttle.
PLEASE NOTE: If running Long-Tube Headers, you will loose 2 PSI of Boost and to gain that back, choose a pulley 2 sizes smaller!
- 3.60" pulley: expect 2.0 psi. more boost over stock pulley -Total boost 8.0 psi
- 3.40" pulley: expect 4.0 psi. more boost over stock pulley -Total boost 10.0 psi
- 3.20" pulley: expect 6.0 psi. more boost over stock pulley -Total boost 12.0 psi
- 3.10" pulley: expect 7.0 psi. more boost over stock pulley -Total boost 13.0 psi
- 3.00" pulley: expect 8.0 psi. more boost over stock pulley -Total boost 14.0 psi
- 2.90" pulley: expect 9.0 psi. more boost over stock pulley -Total boost 15.0 psi
- 2.80" pulley: expect 10.0 psi. more boost over stock pulley -Total boost 16.0 psi
- 2.70" pulley: expect 11.0 psi. more boost over stock pulley -Total boost 17.0 psi
WARNING: The only way to install the 2.70" Pulley is to have the Jackshaft Housing machined down for it to fit properly. Some Jackshaft Housing Castings are made differently in sizes and do vary, as to what the smallest pulley you can use without maching. The smallest size we recommend is 2.80", without any machining performed on the jackshaft housing casting area.
Old 04-24-2010, 10:59 PM   #7
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
if you lose 2 psi of boost with long tube headers why would you drop two sizes in pulleys if the next size down gives you 2 psi so in my case i have the 3.8 stock pulley with longtubes i would use the 3.6 to get the 2psi back right or am i missing something
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 04-24-2010, 11:01 PM   #8
jrpxxii
jrpxxii's Avatar
Exactly.
Old 04-25-2010, 04:54 AM   #9
boostedyards86
just because you are loosing psi doesn't mean your not making more power than prior... Psi on roots blowers is not really a good thing.
Old 04-25-2010, 04:55 AM   #10
boostedyards86
But thank you for the information, that is what i was looking for.
Old 04-25-2010, 09:21 PM   #11
Carlos Garza
Carlos Garza's Avatar
Drives: 2010 Camaro SS RS
On my LS3 we are installing a maggie with 1 7/8" AR headers with high flow cats and the 3.6 pulley, so I guess I should expect around 6 psi and 550 rwhp...? I'm keeping the stock internals and will be installing a meth kit, could I go with a 3.4 pulley?
Carlos Garza is offline   Reply With Quote
Old 04-26-2010, 10:45 PM   #12
Bob Johnson
Bob Johnson's Avatar
Drives: 2010 Camaro
No doubt these figures come from South Florida Pulley Headquarters at this link for additional help:
http://www.southfloridapulleyhq.com/...le_pulleys.htm
Bob Johnson is offline   Reply With Quote
Old 04-27-2010, 07:57 PM   #13
carguy
Carguy
Drives: 57Chevy,67,80,2@10's camaro's,04SSR
This all depends on alot of variables. I have an LS3 and an L99 car Both with TVS 2300's Long Tubes and Flo though Cats as well as Corsa exhaust.
I did tunes and baselines on Both. I tried adding a 3.6 pulley on my LS3 but I ran out of Fuel at 5800 RPM. A Fuel pump upgrade is needed to get the benefit from the added boost. A lean out condition at 5800 RPM made the tune extremely unsafe. I had to go back to the 3.8 until I can get my Fuel system upgraded which I am working on Now. My L99 had no problem with the 3.6 pulley upgrade and started to lean out at 6400 RPM. It would still bennefit from more fuel for higher RPM usage and better shift point calibration but since it is my wifes car I chose to leave it alone. Runs awesome compared to pre tune and boost upgrade.
Here are my Pulls .....
Keep in Mind L99 has 3.6 Pulley LS3 Still Has 3.8 until I get more fuel
L99
LS3
carguy is offline   Reply With Quote
Old 04-27-2010, 08:57 PM   #14
Carlos Garza
Thanks for the info CARGUY; I forgot to mention I'm also installing a kenne bell boost a pump and a meth kit. Hopefully, the KB BAP will help me run the 3.6 pulley without running out of fuel.
Quick Question About upgraded wheels LSX-80MM Wheels and Tires Talk Sponsored by The Tire Rack 2 11-02-2009 04:07 PM
Quick question on tracking??? wlivingston04 Camaro Price | Ordering | Tracking | Dealers Discussions 4 10-06-2009 07:05 PM
just a quick question Fotowns Finest Camaro Price | Ordering | Tracking | Dealers Discussions 23 10-01-2009 01:48 PM
quick question about sunroof... NightmareSS Cosmetics and Lighting Modification Discussions 3 04-22-2009 11:05 AM
New Member, Quick Question NateZ 5th Gen Camaro SS LS LT General Discussions 10 10-11-2007 11:59 AM
