Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 04-24-2010, 07:58 PM   #1
wood0691
Drives: 79 Z28
79 Z28 tach
i have a 79 z28, 350, th350, with factory tach. has a accel super coil #140003. my questions is, why am i burning out tachs? i mean it completely smokes the board in about 20 seconds. not sure whats going on with it, any help would be greatly appreciated. Thanks
wood0691 is offline   Reply With Quote
Old 04-24-2010, 08:10 PM   #2
Mr Twisty
Mr Twisty's Avatar
Wrong area, but...
What did you wire the tach signal to? If you fried more than one, I imagine it's wired wrong.
-- Benjamin Franklin
Old 04-24-2010, 10:16 PM   #3
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Go to nastyz28.com and ask there.
LimaCharlie is offline   Reply With Quote
Old 04-24-2010, 10:28 PM   #4
ron10
Drives: 2010 2SS IOM L99
sounds like you have a short in the line.you may have the hot wire going to ground.trace your wires make sure they are not cut.if you think it is right,check it again.
Old 04-25-2010, 09:51 AM   #5
wood0691
Drives: 79 Z28
thanks guys, ive been on nastysz28 and cant get anywhere there, ive gotten more info here. sorry for the wrong posting area. but thanks again
Old 04-25-2010, 11:10 AM   #6
Mr Twisty
Mr Twisty's Avatar
You might consider putting an additional fuse in-line, I wonder why it's frying without blowing a fuse..... Was 79 an electronic tach? You should be getting your tach signal from the distributor, is this right?
Double check all your tach wiring.
Old 04-25-2010, 12:06 PM   #7
wood0691
Drives: 79 Z28
its not electronic and the signal is from the distributer. i think i have a short to ground cause the pink wire from the cluster that goes to the intrement panel reads continuity to ground on the hot wire. i cant know why im not blowing a fuse cause i cant find one inline with it. with i could find a schematic so i would know exactly what i was looking at LOL.........
Old 04-25-2010, 09:50 PM   #8
Mr Twisty
Mr Twisty's Avatar
Let's start over... Is it a cable drive tach? If so, then you should only have power wires for a gauge bulb. Maybe I should have said "electric" instead of "electronic" LOL
Quick search found this... Might help.
http://www.nastyz28.com/2gcog/tech/u14swap.html
or.....
http://www.nastyz28.com/camaro/wire/73w-rear.jpg
Old 04-25-2010, 10:00 PM   #9
ron10
don't know if you have found your problem yet,but it wouldn't hurt to install an inline fuse on your hot wire,at least that will stop you from burning out your tach.
Old 04-26-2010, 06:21 AM   #10
wood0691
Drives: 79 Z28
my bad mistercamaro, it is electric. i had a blond moment LOL. is there way to bypass the printed board? like take the tach out and go straight from the + and - on the battery and then to the distributor???
mr ron what size fuse will be good, the pink wire from the fuse block is whats feeding the cluster and its on a 10 amp fuse?
Old 04-26-2010, 06:55 AM   #11
ron10
i would think a 10A would be fine.
Old 04-26-2010, 07:13 AM   #12
Mr Twisty
Mr Twisty's Avatar
Only wire running to it is signal looks like. Are any of the other gauges or lights acting up?
Re-read your OP... What exactly is frying? How many times has it happened?
Check your wire colors on the gauge assy's connector with the photo on nastyz28.com... Wired the same?
Electrical problems are FUN
Old 04-26-2010, 07:56 AM   #13
wood0691
Drives: 79 Z28
everything is the same as the illastration but the #3 on mine isnt a double pink, it is a single pink. the #1 brown goes straight to the distributer marked tach, all the rest of the gauges seem to work fine. the temp gauge is unhooked and am useing an after market one but i cant see that making a differance. i have had this car for 3 weeks now so all that has been done to it i cant know.
Old 04-26-2010, 09:28 AM   #14
wood0691
Drives: 79 Z28
guess im gonna try to get another printed board, for some reason i feel like that is the problem. ive got 12 volts to the tach and a good ground, the brown wire is connected straight to the dist. adn i have tried it with out the radio filter so im bout out of options. i dont want a big aftermarget tach stuck out like a sore thumb on my column, I WANT MY FACTORY TACH TO WORK!!!!! UGH
Shno's House of Z Number 3 Camaro Z/28 Forum - Z/28 Specific Topics 17348 Yesterday 04:25 PM
Possible new option packages changes wanted for '11 '12 model years PYROLYSIS 5th Gen Camaro SS LS LT General Discussions 91 09-15-2010 05:15 PM
5th gen vs 4th gen JCO2185 Chevy Camaro vs... 158 07-26-2010 08:16 AM
Production Stats and information sherifdude USA - Southcentral 0 10-31-2009 03:07 PM
