Caryle Racing
Old 06-20-2010, 02:52 AM   #15
Kreature
Kreature's Avatar
Drives: Summit White 1LT/RS
Originally Posted by kb9wte View Post
Here are some filter part numbers (for the 3.6L V6):
ACDelco PF2129
K&N HP-7003
Wix 57090
Fram CH8765
Thanks for the info!
Kreature is offline   Reply With Quote
Old 06-20-2010, 06:11 AM   #16
JSkibisky
Drives: 2010 1LT/RS
Originally Posted by ShadoChaser View Post
Thanks, Nice writeup !
According to my HELM Manual the Oil Drain Plug torque spec for the 3.6L is 18 lb-ft. (page 9-729 of Book 2).
Hope this helps.
ShadoChaser
... Thank you !!
JSkibisky is offline   Reply With Quote
Old 06-27-2010, 03:31 PM   #17
MIDNIGHTANGEL
Back4Revenge
MIDNIGHTANGEL's Avatar
Drives: BLACK CAMARO
Send a message via AIM to MIDNIGHTANGEL Send a message via Yahoo to MIDNIGHTANGEL
YOUR MY HERO! Hahaha I work on my cars but this is my first new car and didnt want to tamper with it so im coming right back here when I have to changeit again
I chose my 6 with Pride..
MIDNIGHTANGEL is offline   Reply With Quote
Old 07-03-2010, 06:31 PM   #18
azamazonqueen
azamazonqueen's Avatar
Drives: 2010 Camaro
Haha. Nice--it is my first new one too. But if a 24 year old chick can do it...
Anyways--I updated the original post with some parts info and the confirmed oil plug torque. Enjoy--I probably will pull this up when I do mine again since you get more than that standard 3,000
azamazonqueen is offline   Reply With Quote
Old 07-14-2010, 09:39 PM   #19
Morias
Drives: Imerial Blue 1LT
Thanks for the guide! I just changed my oil myself for the first time and your guide was awesome! Thank you!
And thanks Adub4185, ShadoChaser and TexHawk for the torque settings!
Morias is offline   Reply With Quote
Old 07-22-2010, 07:30 AM   #20
FC_GIBB
FC_GIBB's Avatar
Drives: 2012 Impala LTZ
good stuff! I Have gotten lazy and will just pay some1 to do it for me though :P
A veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to "'The United States of America", for an amount "up to, and including my life". That is honor, and there are way to many people in this country who no longer understand it.
FC_GIBB is offline   Reply With Quote
Old 07-22-2010, 09:07 AM   #21
TooCool5
TooCool5's Avatar
Originally Posted by azamazonqueen View Post
So I just did my first oil change this past weekend did this writeup since I had to piece it together for my V6 since it is NOT the same set up as the V8. If anyone has any questions, feel free to PM me and if I miss anything, just let me know and I'll add it to the writeup. I take no responsibility for anyone damaging their vehicle. If you are uncomfortable performing something like this, do yourself a favor and take it to someone who is. Special thanks to adub4185 for posting the V8 DIY oil change, bub for the filter pics so I knew I wasn't going crazy, and my dad for helping his daughter keep her car in shape (we rotated the tires too)!
What you need:
15 mm socket (for the oil plug)
15/16 in socket (didnít have a 23mm) (for oil filter)
Extension
Wrench
Torque wrench
6 quarts of 5w-30 (I use fully synthetic)
Oil Filter (ACDelco PF2129, K&N HP-7003, Wix 57090, Fram CH8765 or look up in index most places carry--thanks kb9wte)
Oil Tub
Towels
Funnel
Car ramps or jack and stands
Blocks (for rear tires)
  • Warm the car up to get the oil flowing. Be careful, if you do it to long its going to burn when you start working. I usually do a quick turn of the neighborhood to line it up with the car ramps.
  • Lift the front of the car. We have car ramps for the front wheels. Set the emergency brake and block the rear wheels.
  • Pop the hood. Open up the oil cap. Dip stick of you want.
  • Time to go under!!! You will find the oil plug on the passenger side of the pan actually on the side. Mine had the yellow mark on it.
  • Place the oil tub under. Have it over to the passenger side tire a little since when it comes out it projects a bit. Use the 15mm socket and loosen.
  • Let the oil drain. Clean off the plug with a clean towel.
  • Once it is down to a drip, wipe off the area and replace the plug using your hand (avoid stripping!). I tightened it as far as I could then use the wrench. Adub4185 says to torque the plug to 18 lb-ft at least for the V8 (this is now confirm by the Camaro Bible--HELM). (if you know the specification for the V6 let me know!)
  • Now onto the filter. This creeped me out at first when I bought it. I had a 99 Camaro and expected the filter to be in a housingónot anymore. Also, it is NOT under the car. Thanks to bub for posting pics so I knew where I was looking. The housing is on the drivers side next to the engine cover.
  • Us the 15/16 socket and extension to take off the top of the housing. Oil filter should come off with it.
  • Pop the filter off the housing top and let both drain. Clean off the housing too and all threads.
  • Use some oil to lub up the oil ring around the upper housing piece. Pop the new filter into the top piece.
  • Start it off by hand. Tighten to 25 Newton meters (it even says that on the top of the housing) with the torque wrench (or 18.5 ft-lbs--thanks Texhawk)
  • Get all your new oil together and a funnel. The tube is curved (see pic below) so take it easy when pouring the oil in since the funnel probably will not fit perfectly.
  • put on and tighten the oil cap and place the dipstick back in if you removed it. Close the hood, remove the blocks, lower the car, put all your tools away and your done! Start your car up and check for leaks. If there are any, kill the engine and tighten up anything lose. Make sure to dispose of the used oil properly, Auto Zone is a fav of mine.
I don't agree with this write up. You should be doing the upper filter first so that if any dirty oil drains into the pan while removing the filter, it will be removed when you pull the pan plug.
Old 07-22-2010, 12:30 PM   #22
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
minor detail - still a very good write up
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 07-22-2010, 01:35 PM   #23
keVboy39
keVboy39's Avatar
Drives: 04 SMG BMW M3
cool
keVboy39 is offline   Reply With Quote
Old 07-22-2010, 01:39 PM   #24
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
Should also replace the "O" ring on the filter housing when changing the oil. I use the NAPA GOLD #7090 filter, usually there's a new O ring in the box with the filter. (another minor detail, but the O ring could leak if damaged)
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 07-23-2010, 01:20 AM   #25
jmaryt
Drives: 2010 cgm LS
$15.95 at a local chevy dealer!..(hot damn!) why mess with it?
jmaryt is offline   Reply With Quote
Old 07-23-2010, 07:09 AM   #26
Rocks RS
Rocks RS's Avatar
Drives: 2010 Camaro 2LT/RS
This was great. I used it and changed the oil in my car, for the first time in my life, and I am no spring chicken.
2010 Camaro 2LT / RS - Black w/IO interior & M6
Sporting MRT V1, Hurst short throw, and Injen long tube and loving it!!!
Also, over 125,000 miles and going.
Rocks RS is offline   Reply With Quote
Old 07-23-2010, 09:49 AM   #27
TooCool5
TooCool5's Avatar
Why mess with it? Because at the Dealer the lowest man on the totem pole does oil changes.
He may:
Put the wrong oil in.
Cross tread the plug.
Put only 5 qts in.
Use the wrong oil.
Take your car out for a spin, etc etc.
Lots of reasons to do it yourself the right way.
Old 07-23-2010, 11:30 AM   #28
Rdditten
Rdditten's Avatar
Drives: 2010 ABM Camaro 2LT RS, STS TURBO
Send a message via AIM to Rdditten Send a message via Yahoo to Rdditten
Ever watch the local chevy dealer do and oil change? How about using channel locks where a wrench should be used for one.
Rdditten is offline   Reply With Quote
camaro, change, filter, oil, v6 oil
CAMARO WIKI Tran Wiki 55 03-28-2017 12:04 PM
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 06:11 PM
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 04:15 PM
2010 Camaro V6 Oil and Oil Filter Change azamazonqueen Camaro DIY & HOW-TO instructions & discussions 0 04-25-2010 07:20 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
