Old 04-26-2010, 01:38 PM   #1
eckerj
Drives: 2010 Camaro 2LT
Frustrated with GM & Dealers' Service
Hello,
Thought I would vent a bit here on the forums.
I own a 2LT that has a number of problems. I just got back from a
dealer's service department this morning. The end result is that
they will not service anything that they cannot verify.
Allow me to explain some of the problems:
1) After work last Friday, I begin my commute home and hop onto
the expressway. I'm cruising down the road and glance down at my
analog speedo to find it reading 140mph. Holy Smoke! I quickly check
the digital readout and find I'm at 70mph. I get off the expressway and
find a secluded spot, stop, turn off the engine and find the needle stuck
at 60mph. I turn it off and on again a few more times and it finally
settled in, stuck at 20mph. I drove home, let the car sit in the shade
a few hours, started the car and it's functioning normally.
I did read a few posts here about how the needles can be put on a bit
too firmly and with sufficient heat, they begin to stick.
2) At the end of summer last year, as I'm returning from a trip from
Atlanta to Dallas, my air conditioning unit froze up. It was in the 90's
and the air output of the AC went almost to zero. I then turned the AC
off and turned the thermostat over to the red. A few moments later,
water started spitting out the center vents. After a few more minutes
of getting rained on inside my car, I decided to try the AC and it started
working again. It worked like that for a little while and then froze up
again.
3) Also on my trips back and forth to Atlanta, I heard some sort of rattle
coming from the climate control system. Sounds like something is loose
behind the dash, near the firewall. Nothing that affects the performance
of the car, but definitely annoying.
4) I closely watch the PDIM software update thread and know I'm a few
revs behind. Since I use my iPhone quite a bit and been having reboot
problems with it over the past several months, I thought I'd go in for an
update.
So, I bring my laundry list of issues to the dealer this morning. They tell
me that they cannot address #1 and #2 until they can see the problem in
action. I'm somewhat taken aback, since I thought the speedo problem
would be serious enough to warrant attention. Their position is basically
the problem doesn't exist unless they can verify it.
I decided I didn't want them to even look at the car to try and address
#3 or #4 since the main reason I came in was #1 and #2.
So now I'm stuck with having to hope that my car fails at the same time
as I can make it to a dealership so they can say "Yep, that's a problem."
With my 1 hour commute and most service centers closed shortly after
I get out of work, my chances of reproducing the problem and being able
to show them is slim to none.
Somehow, I feel that if I was still living in Michigan, I would be able to
get these fixed without much hassle.
Does anyone know of a service center in the Dallas area that cares
about their customers?
Frustrated,
-Joe
eckerj is offline   Reply With Quote
Old 04-26-2010, 01:49 PM   #2
esperman
You Can Call Me Jay
esperman's Avatar
Drives: 2010 1LT RJT Manual w/CAI & Solo
again.
maybe you should have had this looked at ASAP last year? maybe the dealer isn't taking you seriously because of it.
esperman is offline   Reply With Quote
Old 04-26-2010, 01:58 PM   #3
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Check this thread out. http://www.camaro5.com/forums/showthread.php?t=71421
skuttduck is offline   Reply With Quote
Old 04-26-2010, 02:04 PM   #4
eckerj
Not having #2 checked out shouldn't have anything to do with them not
fixing #1.
By the time I was able to bring it to a dealership, the AC problem
wasn't rearing it's ugly head, so I basically would have been in the same
boat.
This attitude that service departments down here exude is pretty
nauseating. Only they know what's wrong, and if they can't see it,
it doesn't exist.
Of course, this is coming from the same region that makes people get
out of their car for an oil change at a quick-lube.
Old 04-26-2010, 02:06 PM   #5
eckerj
Originally Posted by skuttduck View Post
thanks! I'll give them a call!
Old 04-26-2010, 02:27 PM   #6
Stingr69
'69 Owned Since '79
Stingr69's Avatar
The A/C system appears to be indicating low pressure. The evaporator temp will go down so low that the heat exchanger will actually collect condensate and it will freeze on the coil. The coil can get so full of ice that it gets blocked and no air goes through it. The air flow will get real cold and then start spitting out water drops before it totaly gets blocked by ice. If you shut it off and wait a bit, the ice will melt and you will be back in business until the ice starts to collect again. This is hard on the system if you keep running it while the coil is iced up so have the refrigerant pressures checked. You may have a leak in the system.
-Mark.
Old 04-26-2010, 02:33 PM   #7
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Everyone needs to remember that dealerships are franchise-owned operations. GM does not own them and sets basic standards for them to operate. If you don't like the service department, send in your GM survey with low scores. GM will pay them according to their customer service. GM had nothing to do with your poor experience. Find another dealer.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 04-26-2010, 02:53 PM   #8
eckerj
It's true that bad experiences at dealerships shouldn't necessarily
reflect bad on the manufacturer. However, the dealer indicated
that the reason they could not fix two of my problems was because
GM instructed them not to repair items that were not verified by
the dealer as broken.
Was this just a line from the dealer? Probably. But it still reflects
poorly on GM.
Old 04-26-2010, 05:08 PM   #9
eckerj
Update:
Just got off the phone with GM Customer Assistance and they said my only options
are:
1) Wait for the speedo and AC to fail and bring it in to the dealership to prove
that the problem exists
-or-
2) Drop it off at the dealership for 2 to 3 days so they can try and replicate the
problem.
Looks like I'm stuck with #1, since I would be the one to pay for a rental car,
and I refuse to pay for a rental in order to have my car fixed.
You want to know what's really sad? I now have to drive around with my AC blasting,
leaving my car sit in the sun, and hope and pray that these things fail on my car
AND that I'll be able to get it into a dealership while it's failing.
All this is completely unacceptable to me. So incredibly stressful. But what can
I do? Not a damn thing.
Old 04-26-2010, 05:15 PM   #10
Eric Baker
Drives: Black/Black 2SS/RS 6M
Just an FYI. ALL dealers work like that. They can't fix your car no matter what brand unless they can verify that a problem exists. If they choose to fix a complaint going by the customers word, and it's found to not be the problem, they are out that money for whatever time/parts were needed. Nobody's willing to just lose money.
Eric Baker is offline   Reply With Quote
Old 04-26-2010, 05:46 PM   #11
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Well, yes and no about all dealers are like that. I'm in the bunch of people having clutch issue - multiple threads. Took it to my dealer, we drove it, of course, it didn't stick. He said bring it back. I went in today, said the same thing, they looked it over, asked a few questions, I handed him a list of parts that other people have had replaced - NO TSB, mind you - and he is ordering parts today for an install as soon as they come in...
So...it depends on your relationship with your service person...etc...
good luck!
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 04-26-2010, 06:33 PM   #12
eckerj
Thanks...
I just can't afford (time and money) to take time off work to bring it
to the dealership so they can diagnose it. In the mean-time, I'll have
to resign myself to the fact that I'm a beta-tester for GM.
Never thought I'd come to the point of wishing things would fail on
my car every time I turn the ignition key. My luck, it'll only fail the day
after it's out of warranty.
Old 04-26-2010, 07:52 PM   #13
jputer
jputer's Avatar
Drives: 2016 1LT Garnet Red
The speedometer issue could be documented with a picture of your dash with the digital readout on "0" and the analog on anything else. Whip that iPhone out and get it while it is "abnormal".
On the A/C issue. R134A works at much higher pressures than the old R12. Sometimes hot, high humidity conditions will cause it to ice up the evaperator when you least expect it to. More of an ambient temp and humidity issue than a "low charge".
2011 1LT/RS Summit White A6
jputer is offline   Reply With Quote
Old 04-26-2010, 08:36 PM   #14
eckerj
Thanks for the suggestion! I'll definitely do that the next time it happens...
Now I gotta hope for some scorchingly sunny weather...
Are you a stupid [cable] customer? (BEWARE: sarcasm) The_Blur Off-topic Discussions 32 03-16-2011 09:11 AM
Need help, weird vibration, very frustrated lre107 Suspension / Brakes / Chassis 4 11-19-2009 02:36 PM
YOUR WARRANTY INFORMATION Kwaz1335 5th Gen Camaro SS LS LT General Discussions 2 11-02-2009 06:23 PM
Any dealers doing discounts yet? Cyberfan Camaro Price | Ordering | Tracking | Dealers Discussions 7 07-29-2009 10:07 PM
GM Service Satisfaction Mr. Wyndham General Automotive + Other Cars Discussion 6 07-29-2008 03:50 PM
