| Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions. |
Thread Tools |
![]() Drives: 2LT/RS Join Date: Apr 2010
When the A/C is turned on and set to cool no cold air comes. The car is only a month old. The service guy told me this is a common problem. Anyone else have this issue?
They told me its the A/C compressor not responding. |
#2 | |
![]() Drives: 2010 Camaro 2LT Join Date: Aug 2009
I brought it in today and the service guy said if he can't see it in action, it isn't broken. |
Did it blow cold air at the dealer. My A/C seemed that it was just running on fan and blowing warm air from outside.
Mine was blowing cold air this morning. I only had the problem after a long road-trip
(10+ hours) and virtually no air was coming out of any of the vents, even with the fan on high. I think our problems are different. Sounds like your compressor isn't working right... if it's reproducible, bring it to the dealer by all means... |
yeah i did they ordered the part. im trying to turn this issue into a lemon issue at the moment lol
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
sounds like you have a compressor problem.warranty issue.
#7 |
![]() ![]() ![]() ![]() Drives: 2010 SS RS, 1976 Type LT Join Date: Sep 2008
Below is all I noted in GM TechLink
#8 |
Thx for that last post. I had the correct settings. So i hope that once they replace the part it wont turn into a recurring problem.
#9 |
![]() Drives: 05/07 Chevy's Join Date: Aug 2009
Also make sure that the HVAC has the lastest software installed. The last update had a fix for "HVAC evaporator freeze-up". It should have been done with 09207A if you had that done. If you want PM me the last 8 of your vin and I can check if that was done
#10 |
I looked that that HVAC post and my VIN was above the range in that post
#11 |
![]() Drives: 2ss/rs cgm Join Date: May 2009
I have taken mine in two times due to a/c issues. already having problems again with warm air coming out when the a/c is on - usually on the hottest days. strange hissing sounds coming from under the dash when running the a/c and a sick putrid smell entering the cabin - makes me want to gag.
vin number 16408 - SS - not sure if i have a lemon or what but this is starting to really irritate me. |
#12 |
took it in 2 months ago and figured the a/c system wasn't properly charged out of the factory, no big deal...they fully charged it and also added some dye in case i had a recurring leak issue and needed to come back. One month later - almost to the day - same issue. Brought it back, almost empty again. they found no traces of a leak anywhere despite the dye. said they would like to keep it overnight. ok, fine. next day they call me and say they regret to inform me they were unable to find the leak and i could leave it there longer or pick it up. basically, there was nothing they could do. so i picked her up and said see ya next month. it's been 2 weeks since then...and it's happening again. i'm going to give it a little while and see what happens before i return to the dealer. i hope they can fix this problem. not having the a/c sucks, but being gassed with the sick smell - that's just not cool (no pun intended).
#13 |
brought her in today to the dealership, i get to rent another impala or whatever while
my baby is driven around by service techs and molested by strangers. they better fix it this time, my patience is running out. |
#14 | |
![]() Drives: 2010 LS3 2SS 2007 HD Streetglide Join Date: Mar 2010
#15 |
Camarogolfguy
Make sure the snowflake light on the right hand knob, west location is on (pushed in once).
#16 |
R.I.P. jesserayjames
no problems with mine, 90's and humid and still ice cold.
#17 |
Just got a call from the chevrolet service dept, it appears they found the leak - evaporator core. They have the part on order but it won't arrive until next week.
He informed me they would need to remove the entire front windshield, and then take apart everything just to get to it and this means I'm stuck in a rental until end of next week at minimum. meanwhile...i'm stuck driving a F&^%$ng HHR clown car... i don't like the idea of them taking apart my car - but i need the problem fixed...so i guess i have no choice but to deal with it. |
#18 |
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
I have similar problem, mine will get cool whenever it's turned on, however for a new car it's should be much cooler. Any clues with that issue
#19 |
SoCal HT5
No one has had it worse than I have ...... Ive taken mine in for AC not blowing cold air 5 times !!!!!!!!!!! so by california law its a lemon so now I am just waiting on GM rep to let me know whats going to happen next but yea PUNK i would have to agree with you on the lame ass rentals they give us. i had to drive a crappy ass cobalt everytime i took my car in ...im hoping GM makes a decision fast because this damn california heat is killing me
#20 |
![]() Drives: 2010 ss/rs camaro Join Date: Apr 2010
My A/C was working fine before i installed a new LS3 KB supercharged engine in my 2010 camaro but after it was installed the A/C compressor seems to work and its full of gas but only hot air is blowing, anyone know what?
#21 |
It seemed that every time the California Heat got around 90 degrees, the a/c would just blow hot air. I tried all the tricks with the knobs and switches but nothing worked. If you
are having this problem I would take it in - it's under warranty. We'll see how she works when i get her back in 1-2 weeks - or whenever. I just remember when i first got this car, it had the coldest a/c i had ever experienced. |
#22 |
I guess this is what happens when you pre-order a car, you get early production where all the kinks haven't been worked out.
#23 |
SoCal HT5
yeah it sucks =( im over here dying of heat and GM taking their sweet time to give me a replacement or my money back ..... coorporate america now a days ..
#24 |
what seems to be the problem causing that is it the compressor? i dont have warranty so i was thinking of buying from summit a new compressor http://www.summitracing.com/parts/FSS-78376/ would that solve the problem or not?
#25 |
Camaro & Stang Enthusiast
Drives: 2011 Mustang 5.0 in Kona Blue Join Date: Mar 2008
My AC unit never cooled properly since day 1 on my SS however I lived with it that way. Also when idling, the power to the AC unit would fluctuate. I bet mine had a bad compressor too...
Bought my Camaro from Eric Hall(817) 421-7266
| Thread Tools | |
| Lowering Alignment Issue | obe1 | Suspension / Brakes / Chassis | 38 | 03-05-2010 03:28 PM |
| New issue of Camaro Milestones magazine? | slick rick | 5th Gen Camaro SS LS LT General Discussions | 24 | 03-02-2010 11:43 PM |
| HVAC issue... Anyone had this problem? | nashstat | 5th Gen Camaro SS LS LT General Discussions | 8 | 01-27-2010 04:19 PM |
| Muffler Rattle / Baffle / Noise Issue - GM Replaced w/Brand New Muffler | Embalmer | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 10-07-2009 03:07 PM |
| TRANSMISSION ISSUE already | Sidewayz_510 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 08-18-2009 04:11 AM |
