Gen5DIY
Old 04-27-2010, 04:17 PM   #1
Bowtie Junkman
Bowtie Junkman's Avatar
Drives: 2000 Camaro SS
Specs on L99 vs LS3 ....
Ok ... I see alot of info on the LS3 ... comparing it to the LS2 ... cam specs, etc. ... but what about the L99?
Do they use the same heads as the LS3? If so, same valve size? Same 1.7 rockers? Exhaust manifolds same, too?
How about intake, injectors and throttle body? Specs? Same as LS3?
Cam specs on L99? Gross lift? Gross duration or duration at .050? Lobe center? Same aftermarket cams for LS3 work in L99 (with new lifters, of course)?
Same block/crank/rods/pistons as LS3?
Sorry if this has already been addressed, or there is a thread about it somewhere ... but all I could find as far as good quality specs only mentioned the LS3 ...
Thanks!
Bowtie Junkman is offline   Reply With Quote
Old 04-27-2010, 11:28 PM   #2
bumblebeecamaro
Car Lover By Nature
Drives: Mini Cooper S
the L99 uses the same block, crank, rods and pistons as the LS3. from my understanding, the only difference between the two is the camshaft.
I believe the LS3 has a slightly better camshaft which is where the extra 26HP comes from over the L99.
bumblebeecamaro is offline   Reply With Quote
Old 04-28-2010, 12:26 AM   #3
KIMBERSSGIRL1
2010 RS/SS Camaro Owner!
KIMBERSSGIRL1's Avatar
Drives: 2010 Camaro SS/RS
I thought I seen a thread on this here somewhere as well.
Yup! Here it is!
http://www.camaro5.com/forums/wiki.p...specifications
http://www.camaro5.com/forums/image.php?type=sigpic&userid=8797&dateline=1241027  111
KIMBERSSGIRL1 is offline   Reply With Quote
Old 04-28-2010, 12:26 PM   #4
Bowtie Junkman
Thanks! I figured there had to be a thread somewhere ...
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
Stereo GUIDE ALL READ WildBeast15 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 29 09-11-2010 01:14 AM
LS3 vs L99 mods ORANGE U NV Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 01-10-2010 09:45 AM
LS3 Tune Only Results .. Also stock LS3 vs. L99 dyno graph LPFSTheFett Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-05-2009 07:04 AM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 06:02 PM
