Old 04-28-2010, 08:58 AM   #1
99-LS1-SS
Waiting...
Drives: 2009 G8 GXP M6
Question about stock bottom end reliability (LS3)
I've got a G8 GXP with the LS3 and M6. It is essentially the same power train as the M6 LS3 Camaros. I've got 1 7/8" ARH long tubes and a cold air intake. I've recently put a TVS 2300 on my car. Currently, I'm running at 6.5 lbs of boost. My tune is very conservative with my AFR a pretty steady 11.1 at WOT and ~15-16 degrees of timing with no knock.
I haven't had my car dyno'd yet but I would guess I'm in the high 400's and maybe (but I doubt it) low 500's as far as rwhp goes.
I know nothing is guaranteed when boost is introduced but, I would like to know how much horsepower the stock LS3 will handle with a reasonable amount of reliability. How much power will these engines handle for ~50-60K? I'm hoping to be solidly in the mid 500's but I don't want to do that if means my engine could grenade at any moment. I don't have the funds right now to buy a forged motor. That will have to be a couple of years from now.....I hope!
From what the people at Magnuson told me, one size smaller pulley (1 tenth of an inch) is roughly equivalent to .5 lbs of boost. I'm running a 3.7" pulley up front with a 1:1 ratio on the back. I'm considering going down to a 3.4" or 3.3" pulley to put my boost around 8-8.5 lbs. Am I asking too much of this engine?
My car isn't a track car, it's a daily driven, run relatively hard car that has the oil changed religiously every 3000 miles.
I have all of the supporting mods regarding the fuel system so that shouldn't be an issue. I have a hybrid twin intank Walbro 342s with LS9 injectors. I run on one pump all the time and the second pump comes in at 4 lbs of boost. My fuel system should be good up to mid 600's without upgrading line size.
SOLD 2009 Maverick Silver G8 GXP M6
Engine Mods: TVS 2300 Magnacharger 6.5lbs, ARH 1 7/8" long tubes with catted x-pipe Roto-Fab Intake, Custom Fuel System, Tuned by Me
Drivetrain Mods: Stage 4 Monster Clutch, GForce 300M Race Axles
Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms and toe rods
Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
99-LS1-SS is offline   Reply With Quote
Old 04-28-2010, 09:00 AM   #2
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Talk to Kyle Gilmour....
Hylton is offline   Reply With Quote
Old 04-28-2010, 09:07 AM   #3
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I think you will be fine .. especially with the fuel mods !!
Crowley
Crowley is offline   Reply With Quote
Old 04-28-2010, 09:17 AM   #4
Pope Designs
Drives: 2013 ZL1 Rally Yellow
I am running 654 rwhp with 7psi. I have upgraded the entire top end and have a dual fuel pump as well. My tune is conservative and so far I am doing fine. I drive it pretty hard.
Here are my mods:
Pro Charger
Injectors
Cam
Push Rods / Springs
Ported Heads
Fast Intake
Ported TB
Headers
Full Cat Back w/ Cat Delete
Fastlane Duel Fuel Pump
Tune
My car runs great. Will it last, who knows. I know for a fact the Vettes push my HP and more and seem to hold up great. I know my clutch needs to be replaced but it seems to be fine for the moment. I also plan to add a cooling mist system as well. After that I am done. If it breaks it breaks. I don't feel like spending $5000 to build my bottom end on the possibility it might break.
Cheers,
Bryan
Pope Designs is offline   Reply With Quote
Old 04-28-2010, 09:35 AM   #5
Cole@Fastlane
Cole@Fastlane's Avatar
Drives: 2010 LSX shootout champions
We have a customer with a dual pump set up and our single turbo set up running 620 RWHP and 675 RWTQ and has over 20,000 miles on it.We did a leak down on it a couple weeks ago and the engine is doing fine.This is on a 2010 camaro bone stock LS3.
Cole@Fastlane is offline   Reply With Quote
Old 04-28-2010, 09:36 AM   #6
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Look at my sig. Stock bottom end motor still going strong.
Old 04-28-2010, 09:45 AM   #7
TC
TC's Avatar
Drives: 2010 VR 2SS-RS
You should be fine, I'm at about 610 at 7.5 pounds of boost. Stayed on the safe side with the tune for now.
Andro- how many pounds of boost are you running.
TC is offline   Reply With Quote
Old 04-28-2010, 09:46 AM   #8
Cole@Fastlane
You are pushing it for sure.We decided to test the limits on one a few months back.The last good pull we made was 788 rwhp then turned up the boost 1 lb and the rod bolts broke.
Old 04-28-2010, 10:29 AM   #9
Pope Designs
Thanks for all your info. How does my setup look to you??
Bryan
Old 04-28-2010, 10:41 AM   #10
LasT_ResorT_G8
-11 second club-
LasT_ResorT_G8's Avatar
Drives: Pontiac G8 GT
Imo if anybody is worried about the stock bottom end with boost, Id most definitely throw some forged rods and pistons in the mix.. Just a little more peace of mind for any FI build...
--Be EzE Car Club--
Show: 8k hids, 20% tint, billet prototypes catch can, GXP rear diffuser
Go: TSP 402
11 second club 11.989 @114.51 1.744 60' w/cammed L76
New numbers to come
It's FI time
LasT_ResorT_G8 is offline   Reply With Quote
Old 04-28-2010, 10:44 AM   #11
99-LS1-SS
Waiting...
I will have a forged motor at some point. I just don't want to be forced into it right now.
boost, reliability, stock ls3, supercharger
2010 LS3 stock short block $2,500? nuptualnemesis V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 4 06-26-2011 12:24 AM
Rear End Question Camaro_Psycho V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 18 05-24-2010 11:40 PM
LS3 reliability HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 03-26-2010 03:39 PM
UPDATE: Icon Autosports Inc. 738 RWHP 699 LB/FT 2010 SS Stock Internal LS3!!! taqwache Forced Induction - V8 71 10-02-2009 03:03 AM
LS3 Transmission Question Seawolf 5th Gen Camaro SS LS LT General Discussions 13 06-12-2009 03:16 PM
