Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Marketplace > Members Classifieds - Parts for sale or wanted > Autos For Sale / Wanted
Old 04-28-2010, 11:30 AM   #1
neko95's Avatar
Drives: 2014 ZL1
69 RS For sale
Engine: Non matching 406cid, professionally built by Pakís racing engines. 400 sbc, bored .030 over, have cam card for specs, Elenbrock 750cfm carb, Flowmaster ceramic headers, Flame thrower distributor, 3 core radiator, new battery, high torque mini starter
Trans: Turbo 400 stock torque converter, shift kit, front seal leak, shifts as it should. I assume that itís original, but have not checked for numbers.
Rear end: 12 bolt positract, rebuilt 2 yrs ago 3:55 gear ratio Have the numbers and they match for a 69 Camaro.
Multi leaf springs, U-bolt connectors to springs, poly spring pads, welded in frame connectors
Rear drums, new pads, hardware, e-brake cables, cylinders
Front disc, calipers, pads, rotors, 2Ē drop spindles, bearing, seals new
Master cylinder, proportioning valve, stainless lines and hoses all new
Tubular A-arms, idler arm, 1 1/8Ē sway bar, inner and outer tie rods
Front end straighten to remove sag in engine bay and aligned after control arm replacement. All work completed summer 2007
Interior looks to be original, high back buckets, consol with gauges, speedo, clock, tac in dash all work. Installed rosewood dash fall of 2007. Driver seat has small spot where seam coming undone, not bad thou. Retro fitted headlight door operation with electric motors controlled by switch. Pins for retaining wiper switch broken, switch hanging in opening but still working. Headliner appears new and in good shape, carpet in good shape and have new front carpet if wanted to replace. Have plastic toe kick for around base of steering column but broken and looking for a replacement. As far as the sheet metal the only bad spot Iíve found is the toe kick pan under the gas and brake pedal. New pan about $50. Body in good shape with rear quarters and trunk pan replaced, paint has some chips. Cowl hood but cowl is non-operational. Ralley rims with center caps and trim rings, tires are good, no apparent dry rot and no leaks. Will also include all original parts removed, manuals and extra parts accumulated along the years. Control arms, carpet, harnesses, standard flat hood and lots of misc. Lots of receipts, car runs and drives nice but just donít have time to enjoy it and canít stand letting it sit. Few pic's at my site, PM if interested
2014 ZL1
neko95 is offline   Reply With Quote
Old 04-28-2010, 01:35 PM   #2
deljaso's Avatar
Drives: 2010 1LT/RS
I love to dream... Come on, give us a ballpark range for price!
deljaso is offline   Reply With Quote
2012/2013 Inventory - Fly in..Drive out or I can ship to you BeckyD@JamesMartinChevy Dealer Camaros for Sale 303 11-15-2015 09:46 PM
Whats the difference between Camaro SS vs. SS w/RS package? JBsC6 Camaro Price | Ordering | Tracking | Dealers Discussions 41 07-14-2015 06:07 PM
2SS with RS Package Question clg_98ta Camaro Price | Ordering | Tracking | Dealers Discussions 14 01-17-2010 12:03 PM
RS package getting dropped Foster26 Camaro Price | Ordering | Tracking | Dealers Discussions 48 08-03-2009 02:11 PM
