GM Parts House
Old 04-28-2010, 02:17 PM   #1
G.E.
G.E.'s Avatar
Drives: black on black twenty ten ss/rs
Tire/air monitor issue.
My car told me that my tire needed some air, it was about 4-6 psi low. So I filled it up a little bit then hit reset/relearn on my tire psi. After a while an orange light came up and the message saying that I need to service my tire monitor system. Is there anythng I can do to fix it or do I need to just take it to a dealership?
I GOT MINE! Where's yours? :(
G.E. is offline   Reply With Quote
Old 04-28-2010, 02:31 PM   #2
mcotton
mcotton's Avatar
Drives: 2010 Camaro
I had the same issue, followed the manual on resetting with no luck. My dealer is on my way home from work and I just go in and say fill up the tires and 5min later they have it done. The mechanic told me they have a machine they use to do the tires and that he never tried the manual way (the way you and I have to do it) :-)
So just take it in and they will reset it for you.
Mike
mcotton is offline   Reply With Quote
Old 04-28-2010, 02:34 PM   #3
Reeko
Drives: 69 Camaro RS Conv. 2010 Camaro SS
Why do you need to reset/relearn if you just added air?
I thought that was only the case if you replaced the sensors.
Reeko is offline   Reply With Quote
Old 04-28-2010, 02:36 PM   #4
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
You should not hit the reset/relearn button when adding air to the tire. The sensor will pick up the additional air after a few miles and the reading will change on the DIC. You should use the reset/relearn button when you are mounting new tires.
Now that you hit the reset/relearn button, you must reset all four tires (sensors).....you can do it yourself, the procedure is in your owners manual (too lengthy to type out here).
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 04-28-2010, 02:55 PM   #5
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 04-28-2010, 03:45 PM   #6
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
to do it without the dealer sensor... reset the monitors, starting with the driver front tire let air out until it honks, then rotate around the car clockwise and do the same to the other 3 tires.
but you do not have to reset it after just airing them up... they do take a few minutes to see the change in pressure which is too long IMO.
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
