BeckyD @ James Martin Chevy
Old 04-29-2010, 12:37 AM   #1
Basenji
Drives: Camaro
Low frequency vibration from 58 mph-68 mph
My 2ss Camaro (auto) has a problem with a low frequency vibration which starts at approximately 58 mph, loudest at 63 mph and disappears at approximately 68 mph. At around 90 mph a small amount of vibration can be felt. The first time my Camaro was in the shop was at approximately 1300 miles and they changed 3 of the tires. When I picked up my Camaro the vibration was still there. The next day I returned to the dealership and I was advised they could not locate the source of the vibration asked me to return the following Monday when the shop manager was at work. I returned on Monday and the shop manager went for a ride in my Camaro and he acknowledged he heard the vibration. He advised me he would call GM and see if they knew of any issues with the vibration. The next day I returned to the dealership and dropped me car off and the service department changed the back left axle. When I picked up my Camaro the vibration could still be heard. The sevice department was notified of the vibration the same day. I was told to keep my car over the weekend and return it on the following Monday. I dropped it off on Monday and on Wednesday I was advised by the service manager that GM was aware of the problem but they did not have a fix at this time. I was also told that 5 other Camaros (new) on the lot were checked for the vibration and all had the same problem to some degree. The vibration was found to be at 57 mhz.
Anyone have any suggestions on my next step or a possible cause or solution to the problem.
Basenji is offline   Reply With Quote
Old 04-29-2010, 01:07 AM   #2
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
For a minute there I thought it was the active fuel management (AFM). I wouldn't even know what 57MHZ feels like..lol
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 04-29-2010, 05:51 AM   #3
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
That is the AFM. Mine has it to but not as bad now since I cut the big butt resonator out and replaced it with X-Pipe.
Scott@Bjorn3D is offline   Reply With Quote
Old 04-29-2010, 08:33 AM   #4
Basenji
Drives: Camaro
The dealership does not believe the AMF is the cause of the vibration. The vibration does not change if the engine is in neutral and idling during the posted speeds.
Old 04-29-2010, 01:47 PM   #5
Basenji
Drives: Camaro
Anyone else having this issue?
Old 05-07-2010, 12:06 AM   #6
Basenji
Drives: Camaro
I was contacted by GM today and GM acknowledges the vibration problem with the Camaro and they advised their engineers were working on a fix. I was also advised that no more repairs would be attempted on my Camaro until such time a fix has been found. GM was unable to give any type of time table for a possible solution.
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 11-14-2015 05:07 AM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 04:09 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
