Cold Air Inductions
Old 04-30-2010, 08:22 PM   #1
Captain McFunk
Break Necks, Cash Checks
Captain McFunk's Avatar
Drives: 2010 black Camaro 2SS/RS
cutouts = sluggish?
Anyone with cutouts? Did any of you notice how freakin' slow your car was afterwards? It seems like mine turned into a COMPLETE slug with the cutouts open. I LOVE the sound, but my lord it doesn't go anywhere! Like a 7 second 0-60 or something. I was just curious if anyone else had this problem?
L99 with qtp cutouts.
2009 CTS-V - White Diamond - intake, exhaust, wheels, visual mods
Captain McFunk is offline   Reply With Quote
Old 04-30-2010, 08:28 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You need some back pressure.
Old 04-30-2010, 08:33 PM   #3
Captain McFunk
I figured since they dyno'd 18rwhp gain, that it would be at least somewhat quicker, but it feels MUCH slower. Almost like there's a bigger stall converter in it now.
Old 04-30-2010, 08:34 PM   #4
Apex Motorsports
How did the torque numbers look?
Old 04-30-2010, 08:36 PM   #5
Captain McFunk
17rwtq gain, that's why it's throwing me off.
Old 04-30-2010, 09:12 PM   #6
Apex Motorsports
Its hard to diagnose things over the internet, especially without first hard knowledge of your cars modifications and without the before and after dyno charts, but I'm thinking that while you peak power and torque numbers are higher you have lost in the lower rpm range due to the lack of back pressure. Does it feel like a dog when you take off but then comes alive as the revs build?
Old 04-30-2010, 09:15 PM   #7
Captain McFunk
There's no mods other than the cutouts. It definitely feels like a dog (doesn't even bark 1st with TC off), but it does slightly pick up, it just doesn't feel like what it used to. it feels like it takes FOREVER to get through 1st and 2nd gear!
Old 04-30-2010, 09:20 PM   #8
Baldilocks01SS
Camaro Club of Delaware
Baldilocks01SS's Avatar
Drives: 2001 Camaro SS
Cut outs are mostly for top end wide open power. Only time I ever open mine are 3/4 of the way thru a drag race.
Dyno: 392 HP @5170 RPM / 387 Lb.-Ft. @ 4620 RPM
Baldilocks01SS is offline   Reply With Quote
Old 04-30-2010, 09:25 PM   #9
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Mine has actually gained time with Noweeds,, but I have a tune to help benefit them.
You'll gain power in higher RPM range from them, starting out you won't have the back pressure.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 04-30-2010, 09:42 PM   #10
SShift
SShift's Avatar
Drives: Only Bowties!
If you are not tuned for cutouts you will need to run them open for a little bit for the computer to adjust to them. Also the loud exhaust may seem slower. Dyno and track times have proven it.
Also cutouts are not just for top end. Thats a myth like burning up valves. All depends on your engine output and your exhaust system.
SShift is offline   Reply With Quote
Old 04-30-2010, 09:49 PM   #11
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
I have noweeds and actually just made a post yesterday. I talked with andy at livernois which will be doing my maggie install this next week and tune and he said it is a perception that the car is slower do to the exhaust but a tune will help a little. He also said that I can have my supercharger tuned and it wont effect if they are open or closed. So if it makes more torque with them closed I will use that for a roll race and if it makes less torque down low I will use it for drag races so I can build power as I go and have less torque down low since the maggie already has plenty. He said I will not notice a diff once tune though except for the perception thing.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 04-30-2010, 10:11 PM   #12
BOBSS
Outlaw
BOBSS's Avatar
Drives: 2010SS
with the noweeds, you might see a gain because the outlet is still around 3 inches
with QTP you have the 4 inch oval + the mufflers' 2.5"
lower restriction, different behavior.
It would stand to reason that you gain torque at the top and lose it at the bottom, off the line.
mine dyno'd 5hp lower with the cutouts open.
I'f you're open during WOT, lord help you and everyone around you.
I have a tunnel near work, long enough to hold 4 cars
I can't imagine what it sounds like for those poor souls @ WOT
if you want the most while open, you need a O2 bung at the headers just for the wideband / tune sensor during the dyno tune
BOBSS is offline   Reply With Quote
Old 04-30-2010, 11:18 PM   #13
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
yall are forgetting cutouts are for upper HP you lose lots of lowend torque with them open. However once the car gets moving then you feel the power.
Jekyll-N-Hyde is offline   Reply With Quote
Old 04-30-2010, 11:22 PM   #14
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Here is something that works
http://www.camaro5.com/forums/showth...ight=downpipes
ADM PERFORMANCE is offline   Reply With Quote
QTP Electric Exhaust Cutouts Pictures and Videos!!! Quick Time Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 51 08-08-2015 10:09 PM
Whats the deal with exhaust cutouts? Bentley78 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 01-09-2011 04:14 PM
How to Install QTP Electric Cutouts Quick Time Camaro DIY & HOW-TO instructions & discussions 73 05-03-2010 01:19 PM
QTP electric cutouts 2SSRS@Gen5diy V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 4 12-26-2009 09:30 PM
Exhaust Cutouts Camaro007 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 06-02-2009 04:41 PM
