GM Parts House
Old 05-01-2010, 10:08 PM   #1
madmaxx18
madmaxx18's Avatar
Drives: 07_tundra/08_zo6
JBA MIDPIPES REVIEW
They looked great out of the box and I couldn't wait to get started. I Didn't understand why it had a set of 2 grade 8s and 2 steel bolts. I don't like the fact that they didn't weld the bolt on or put a floating nut plate on the mid pipes. They appeared to be set up nice with no instructions not that you need em anyway. The stock ones are a pain in the ass to take off. I suggest you take off the back most sensors and then disconnect the front ones on both sides. Makes it alot easier to deal with. Then when you have the pipes off take out the front sensors from the old pipes that you left installed and install them on the new ones. Then put the new pipes in. I found it easiest to install the new from underneath the car. When I installed the driver side new pipe I was a little pissed off that they didn't take the time to weld the front o2 sensor point at the right position. So it has 1/16'' clearence from the wires touching the tranny and 1/8'' clearence from the o2 sensor hitting the tranny. Other than that drivers side wasn't to terrible to install. Next was the passenger side install it was lined up right for the o2 sensors. The only problem with it was that the connection point to the catback exhaust was off by an inch. So I managed to fanagle it some and get it to hook up. The aft bolt is a pain to tighten down but it can be expected. After I hooked it all up I fired her up and checked for leaks. The sound is alot louder than it did with my borla sport catback and throttle response and low end power felt a little different. Would I recommend this kit to anyone no way unless JBA welds the foward driverside o2 sensor on the pipe at a 12 or 10 oclock position. Not entirely sure I would have to look again but it would clear nicely then if they weld it at the proper position. If they fix this then I would recommend buying it. Wednesday if I get a chance I will take more pics and next Friday after my vacation I will post if my 2000 mile drive kicks codes or not.
[JBA1812SYC] 2010 Camaro v8 2.5” Mids pipes for use with factory manifolds or
JBA shorty headers: 1812S , 1812SJS , or 1812SJT
With high flow performance Cats
madmaxx18 is offline   Reply With Quote
Old 05-13-2010, 07:59 PM   #2
madmaxx18
madmaxx18's Avatar
Well after putting about 1500 miles on the car during vacation the car is def. louder. It sounds like a muscle car now and has alot of drone between 70-85. I hated having to drive10 hrs straight with the noise in the car. I still don't recommend them to anyone else unless jba fixes the drivers side front mount point so it doesnt touch the o2 sensor wires. I def. feel a difference on low end power and little on the top and no engine codes or anything.
Old 05-13-2010, 08:01 PM   #3
2010 4 DW
Drives: White 2010 RS/SS
I put them on my car and did not have any problems.
Maybe you got a Monday part.
DW
2010 4 DW is offline   Reply With Quote
Old 05-13-2010, 10:20 PM   #4
madmaxx18
madmaxx18's Avatar
Must have been. lol
Old 05-13-2010, 10:37 PM   #5
ron10
Drives: 2010 2SS IOM L99
thanks for the info.
Old 05-13-2010, 11:29 PM   #6
wow
Old 05-14-2010, 12:33 AM   #7
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
Some videos please!
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 05-14-2010, 11:18 AM   #8
madmaxx18
madmaxx18's Avatar
I will see what I can do.
Old 05-15-2010, 07:42 PM   #9
madmaxx18
madmaxx18's Avatar
others are still uploading
Old 05-16-2010, 12:10 AM   #10
madmaxx18
madmaxx18's Avatar
Old 05-16-2010, 01:24 AM   #11
linkwpc
The punching cat
linkwpc's Avatar
oooo nice! You also need some reving ones too. How do you like it so far? Too loud now? Or just right?
Old 05-16-2010, 08:43 AM   #12
NinoSS
Drives: 2SS/RS CGM LS3
Sounds perfect...
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 05-16-2010, 11:08 AM   #13
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Sounds good. I wonder why some stuff will throw codes, and some won't. I guess placement of the cats is key.
g-townmach is offline   Reply With Quote
Old 05-16-2010, 11:50 AM   #14
madmaxx18
madmaxx18's Avatar
These are mid pipes and from what Ive heard about the mid pipes is they don't set codes. Now that I'm finally used to the drone(1500 miles of driving) in the car its actually not that bad my friend talking in the vids owns a 2000 cobra. He actually thinks it sounds just right not to loud or to quiet. I think it sounds just about right aswell. It wasn't very loud with just the borla kit on should have made vids before I put the mid pipes in. I had one of revs at idle just gotta make a new one without license plates showing. The going thing amongst friends now is that it sounds like a V-8 without those stock midppipes in. They say it actually has the sound of a muscle car now. I would say that it would only be slightly louder with long tubes added in than what its at now.
Installed 3in JBA catback: Evaluation g-townmach Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 11-24-2015 10:29 AM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 100 11-13-2010 04:51 PM
77880 gets JBA shorties, MBRP catback, Roto Fab, Lots of Pics! HeavyD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 04-29-2010 02:37 PM
JBA releases exhausts, headers and midpipes. Bewenched Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-16-2009 04:04 PM
