| USA - Texas Lone Star State |
Thread Tools |
![]() Drives: 2010 Camaro 2SS RS Join Date: Oct 2009
Ethanol Free Gas Locations in TX
Here's a website that lists stations that sell ethanol free gas. It's a user driven site so and texas has less than 30 locations added. If you know where some stations are that sell non ethanol gas add it to the site.
http://pure-gas.org/index.jsp?stateprov=TX |
![]() Drives: 2010 2LT/RS White Join Date: Apr 2010
good info, i was discussing with someone the other day on the effects of ethanol. None in austin, though..BOOOOO
vroom vroom
![]() Drives: 74 cuda, 98 camaro ss,2010 2ss Join Date: Jun 2009
sorry, but what does ethanol do to our gas guzzling V8 engines?
[SIGPIC]
Stainless works 3 inch catted headers/exhaust, Diablosport Chip |
In a nut shell, lower MPG and less power.
with all the summer travel plans I thought it might be worth a bump.
#6 |
![]() Drives: 2000 camaro Z28 & 2010 SS w/ RS Join Date: Apr 2010
it's only good for the environment... not so good for a performance engine. that's why the dealer should have told all new camaro owners to put 93 gas in the cars. tisk tisk.
Cristykay07
[SIGPIC][/SIGPIC] loves 4th and 5th gens. |
#7 |
We lose approx. 1% MPG with each percent of ethanol in our gas. Not sure what kind of performance hit, but I'm sure there is one. And, its very difficult to find gas in central Tx w/o the standard 10% ethanol - but you can tell because the pumps that have it are required by law to have warning stickers.
#8 |
IAMACE
Got a bad tank
I filled up at a Shell in Ft. Worth with 10% ethanol in their 93 and the difference is staggering. I had been commuting back and forth from Waco getting around 28 mpg in my SS then when I got that tank it dropped to around 19-21 cruising at only 65-70. Keep in mind 96 degree heat but still... My L99 is really sensitive to the ethanol and I notice quite a large performance difference as well. Im wondering if a fuse pull will be necessary after this tank is cycled through.
And the Exxon across from Baylor campus is where I fill up and my car like
#9 |
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
How can they legally sell gas with 10% ethanol in it at the same price as gas with no ethanol in it?
And, how can gas have 10% ethanol in it if it's still 93 octane?
#10 | |
IAMACE
I don't know but I'm sure the gas companies are loving to charge us for the 93 ![]() And they sleep better knowing they're doing good for the environment
#11 |
I just dyno'ed 385 at the wheels on gas from the Chevron in Round Rock TX. On the corner of 79 and sunrise. I'll check tomorrow if I can find out if it has ethenol in it.
If it does, I'll find somewhere that does not and re-dyno my car, and see if I pick up any hp.
2012 ZL1 #1092
Black on Black 10 spoke M6 ECF 8.6" lower pulley (no tune) 552 rwhp 05/22/2012 (6000) Vehicle delivered to customer. |
#12 |
Just checked, it has a sign on the pump that says up to 10% ethanol.
Wish I'd noticed that sign before I used that gas to baseline my car. It could have 0% ethanol one time, then 10% the next.
2012 ZL1 #1092
#13 |
![]() Drives: 2010 Black M6 RS/2SS Join Date: Oct 2009
Yea the Texaco in Cresson Texas on Motorsports Ranch on HWY377 goes from 10% ethanol to regular every now and then.
2010 Blk/Blk RS/2SS w/CGM Stripes 5% tint
ADM Performance H/C/I M6 3.91s 479rwhp 435rwtq |
#14 |
![]() Drives: Black 2SS/RS L99 Join Date: Mar 2010
Also, I read somewhere that this stuff is making lawn mowers run allot hotter and blowing the motor.
#15 | |
![]() Drives: 2010 SS Join Date: Feb 2010
As for lawnmowers, I know you can take a lawnmower engine, drill out the carburator, and run alcohol fuel. This will double the horse power of the engine. They do it with go-cart racing all the time. |
#16 |
I used to be Dragoneye...
Ethanol actually has potential to make MORE hp than gas, it's essentially racing fuel with 104 Octane or so.....the Corvette racing team even uses E85 in their cars...
...the problem right now is that engines are not optimized for the stuff. Mostly because it's not not nearly as available as gas...if they were, this conversation wouldn't be happening, I bet. ![]() 10% really shouldn't make a noticeable difference though. They've been designing engines and computer systems since '85 to deal with the stuff. The biggest change would be a drop in fuel economy....I'm talking 1 solid mpg...MAYBE 2. |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 ABM 2SS/RS M6, 98Z28 M6 Join Date: Jan 2008
Edited "Sorry I should have said 10-15% is bad, e85 does not have this issue as bad".
Not sure about hotter, but it does gum up thier fuel systems. Fact ethonal attracts moisture. When it breaks down it forms a gel gunk. The little needle holes in the carbs are stopped up with the gel, starved for fuel, they won't run and have to be cleaned. You have to remember that fuel in mowers, trimmers and such tends to be more exposed to the elements, so it breaks down faster.
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve! Ordered 5/23/2009 3400 with TPW of 08/03/09 3800 8/11/2009 Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior |
#18 |
Just Cruisin'
Drives: 2010 Synergy Camaro Join Date: Mar 2010
IS there a difference on the HP and MPG gains when using 87 vs 89 or 91 octane on the V6?
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels ![]() |
#19 |
Hello!
#20 |
Romanian Outlaw
Drives: 13 ZL1 , 12 Z71, 00 Pete Join Date: Apr 2010
Does anyone know a pump in Waco ethanol free?!??
#21 |
The EPA finally requirements finally hit Waco last fall. I'd link the article but there's a fee to view the archives.
1.) Ethanol blend makes way to Waco gas stations Author: J.B. Smith Tribune-Herald staff writer Ethanol blends have quietly made their way to Waco-area gasoline pumps this fall, and that has Bob Potter fuming. Potter, a retired defense worker who lives in Hewitt, calls the 10 percent ethanol blend a "snake oil concoction"that hurts his gas mileage and maybe his engine. "I'm not getting my money's worth,"he said. "I don't see any difference in price with the ethanol blend. Publish Date: December 18, 2009 | Word Count: 881 | Document ID: 12182009-wac-ethanol |
#22 |
Romanian Outlaw
This shit is sum bs that the goverment ta get ur money fukin scammers is all I say!!!
#23 |
![]() ![]() Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
The upside of E85 is 101 to 104 octane rating, cleanburning, keeps injectors and fuel system clean. Higher octane means more spark advance and cooler fuel/air charge in cylinders combining to give more HP. Not meant for older cars/mowers with steel fuel tanks, rubber hoses, etc. Our cars have poly plastic fuel tanks, fuel pumps, plastic evap lines, etc as they are not affected by use of etanol. E85 is not as caustic as is methanol. Also the price per gallon is somewhat less than gasolene (10-15%). The downside is approx 30% less mileage. E85 has 15% fuel added to aide in very cold climates with cold start issues. Also availability limited in many parts of the USA. Fillups more frequent. Requires an entirely different tune in our ECM's. Lastly the fuel delivery system plus injectors need upgrading in order to handle added volume of E85 over gasolene. Just my 2 cents. Could be a good thing but not in a daily driver.
ADM built Silver 2SS/RS Man/6
1.9 L, ZL-1 Blower, ADM LSA Heads CTS-V front 6-Piston Calipers, ADM Dual Fuel Delivery ADM/LPE Dual-Disc Clutch, GM 3.91 Rear Gears |
#24 |
Romanian Outlaw
Idk it's jus bs since it hasn't changed the price
#25 | |
![]() Drives: 2010 2LT/RS A6 Join Date: Dec 2009
A couple of points: 1. Since 93oct is ~4.4% gain in mpg over 87oct, but 93oct costs ~11% more than 87, the "cheapest" gas is clearly 87oct. 2. Several forumites have noticed that the V6 retards alot more timing with 87oct versus 93oct--suggests more power with 93 oct. Also note our cars are NOT E-85 compatible. Ethanol is a corrosive, hygroscopic boondoggle thrust upon us by mindless twits, whose pockets are lined by corn growers...growers that cannot even remotely produce enough corn to handle both food and fuel demands. Ethanol is much more expensive to produce than straight gasoline. Also a UT "Enginner," BS '96 |
| Thread Tools | |
