Rick@Livernois
Old 10-13-2008, 03:18 PM   #1
deadlyforce11
Drives: 2001 Camaro RS
Question Can someone help me with my 2001 Camaro
I have a few problems with my Camaro i would like to fix. I was hoping someone could help me pin point what exactly is wrong.
1. After it rains i get the check engine light. I believe it is the O2 sensor but i am not positive.
2. Every time i hit a bump in the road my stereo and window's power go out.
3. Only my trunk speakers work. I think the amp or headunit is the problem.
4. Is there anyway to stop the squeaky suspension?
Thank you for reading this.
deadlyforce11 is offline   Reply With Quote
Old 10-13-2008, 03:27 PM   #2
Zieke
Camaro Deprived
Zieke's Avatar
Drives: 78 Camaro, 00 Tahoe, 10 Cobalt
Send a message via MSN to Zieke
im not able to help you with this. but heres my advice:
be patient. weve got a lot of guys on here that know there stuff.
they'll be on here soon. good luck.
My posts are of my opinion most of the time.
I am young and inexperienced. Please don't hate on me for it.
Joined Active Navy: 10-28-08
Zieke is offline   Reply With Quote
Old 10-14-2008, 02:24 AM   #3
camaro5's Avatar
Drives: 2019 Chevrolet Camaro
My friend:
1. Rain is the key here. Water is getting into one or more connections, not allowing the computer to get acceptable voltage readings. Get the code(s) read by a scanner -some are only $50.00, or you can ground the diagnostic terminal and the check engine light will flash the codes. Search Google for exact procedure.
2. Another bad connection, this one caused by physical movement from bumps. None of this is easy. You either remove interior panels and wiggle wiring until you make the problem occur, or simply run new fused wiring to feed it and bypass the intermittently bad connection.
3. Could be wiring, could be head unit. Try switching rear output to front speakers. If they come on, the HU is defective.
4. Silicone spray the problem area. Saturate it. Have a friend bounce the car as necessary while you locate and lubricate.
Good luck.
GM ASEP Graduate, A.S. Automotive Technology, CISCO Certified Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this info "as is". camaro5 does not provide any warranty of the info whatsoever, whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the info will be error-free.
camaro5 is offline   Reply With Quote
Old 10-14-2008, 07:35 AM   #4
deadlyforce11
Thank you so much. Ill see what i can do when i get some free time to check it out.
Old 10-14-2008, 10:29 AM   #5
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
2001 v6 camaro rs 3.8L.....
take your car to an autozone and have them scan your codes. just because the light isnt on, doesnt mean that the code isnt stored. that way you are just shooting in the dark. but it sounds like a bad ground somewhere
the stereo and window power going out sounds like bad/loose wiring or possibly even the RAP (Retained Accessory Power) module.
your front speakers could be blown, when I got my car i didnt even have front speakers in it.
as for the suspension, you could try to grease up the fittings, or replace the bushings all around.
I piss excellence
and fart awesomeness
Old 10-14-2008, 12:36 PM   #6
SimC33
Drives: 2001 Blk/Blk M6 Camaro SS #899
I am 99% sure that it is your BCM (body control module) It controls accessory funtions ex:windows, keyless entry, stereo. I have this EXACT problem in my car.
If you get in the passenger side look under the glovebox, pull the flap down that you could kick with your toe if you were sitting in the seat. Look up and you should see a black box looking thing with wires running to it...
http://www.saturnfans.com/photos/dat...thumbs/BCM.jpg
thats what it looks like, (sorry its so small) but get under there and wiggle the wires...if that cuts the stereo on and off its a loose connection to the BCM if that doesn't work, then it's a bad BCM and you will need to replace otherwise it will continue to cut out.
SimC33 is offline   Reply With Quote
Old 10-14-2008, 12:38 PM   #7
SimC33
Sorry I meant to quote you deadly...haha
Old 10-14-2008, 02:30 PM   #8
deadlyforce11
Thanks again everyone. I just wish i could get the time to look at it. lol school and work are no fun. =[
With the speakers i replace the front ones; I am pretty sure they are not getting power. I'm thinking of just redoing the whole audio system. I want to find a GPS touch screen head unit that would fit just like the stock radio does. Haven't found one of those yet. I have the cd changer as well and i kind of want to keep it. Oh well. I will figure it out.
2001, camaro, power, problem, repair
A Message to all Fbody Enthusiasts TAG UR IT 5th Gen Camaro SS LS LT General Discussions 12 02-02-2013 07:41 PM
Why the Camaro is Doomed!! TFord 5th Gen Camaro SS LS LT General Discussions 140 01-16-2010 08:07 PM
Hybrid Camaro, new fuel economy rules = way higher price? Cubanaso 5th Gen Camaro SS LS LT General Discussions 112 10-20-2009 10:21 PM
